[PATCH 2/2] bsp/tms570 Use bitfields instead of hard-coded values
Pavel Pisa pisa at cmp.felk.cvut.cz
Fri Jul 17 17:22:14 UTC 2015
Hello Joel,
I have been with Premek when he tested these on the target.
[PATCH 1/2] bsp/tms570: skipped 32bit field definitions and corrected single bit fields
   This one clean header files. There has been unnecessary defines
   of whole registers as fields and mistake in single bit definitions.
   I am not happy that this slipped, we have discused and planned use
   of BSP_BIT32 long time ago but we have found mistake during attempt
   to clean BSP a little more and get rid of hardcoded values.
   Patch is huge so it blocks on list moderator approval.
   If you do not have it received then I or Premek send it offlist
   gzipped.
   This makes already implemented code much more readable.
If these patches can make to common base it would be nice.
Best wishes,
             Pavel
