[rtems-source-builder commit] rtems4.11: OpenMP support for ARM, PowerPC, SPARC
Sat Jul 18 13:38:34 UTC 2015
----- Chris Johns <chrisj at rtems.org> schrieb:
> On 18/07/2015 1:20 am, Joel Sherril wrote:
> > diff --git a/rtems/config/4.11/rtems-arm.bset b/rtems/config/4.11/rtems-arm.bset
> > index 1e06796..c0bd04a 100644
> > --- a/rtems/config/4.11/rtems-arm.bset
> > +++ b/rtems/config/4.11/rtems-arm.bset
> > @@ -17,6 +17,11 @@
> >  %define enable_obsolete 1
> > +# Enable OpenMP support
> > +%define with_libgomp
> I think this forces the option to be always on. Should a user be able to
> disable the option with --without-libgomp ?
More options more problems.  I don't think there are serious reasons to disable this option.  If you don't need OpenMP, then you waste a couple of minutes in tool build time and some megabytes of disk storage.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
