[PATCH 5/6] RSB: add nanoX bset
QIAO YANG yangqiao0505 at me.com
Sun Jul 19 20:49:56 UTC 2015
 rtems/config/4.11/graphics/microwindows.bset      | 20 +++++++
 rtems/config/graphics/microwindows-0.93-dev-1.cfg | 19 ++++++
 source-builder/config/microwindows-1.cfg          | 71 +++++++++++++++++++++++
 3 files changed, 110 insertions(+)
 create mode 100644 rtems/config/4.11/graphics/microwindows.bset
 create mode 100644 rtems/config/graphics/microwindows-0.93-dev-1.cfg
 create mode 100644 source-builder/config/microwindows-1.cfg
diff --git a/rtems/config/4.11/graphics/microwindows.bset b/rtems/config/4.11/graphics/microwindows.bset
new file mode 100644
index 0000000..edae6d7
--- /dev/null
+++ b/rtems/config/4.11/graphics/microwindows.bset
@@ -0,0 +1,20 @@
+# Build set for Nano-X Window System
+%define release 1
+# RTEMS Version
+%define rtems_version 4.11
+# The RTEMS URL paths.
+%include rtems-urls.bset
+# Build microwindows.
+graphics/microwindows-0.93-dev-1.cfg
diff --git a/rtems/config/graphics/microwindows-0.93-dev-1.cfg b/rtems/config/graphics/microwindows-0.93-dev-1.cfg
index 0000000..c0cdc86
--- /dev/null
+++ b/rtems/config/graphics/microwindows-0.93-dev-1.cfg
@@ -0,0 +1,19 @@
+# microwindows 0.92
+%if %{release} == %{nil}
+ %define release 1
+%endif
+%include %{_configdir}/rtems-bsp.cfg
+# microwindows Version
+%define microwindows_version 0.93-dev
+# microwindows Build configuration
+%include %{_configdir}/microwindows-1.cfg
diff --git a/source-builder/config/microwindows-1.cfg b/source-builder/config/microwindows-1.cfg
index 0000000..b1944f3
--- /dev/null
+++ b/source-builder/config/microwindows-1.cfg
@@ -0,0 +1,71 @@
+# microwindows
+# This configuration file configure's, make's and install's microwindows.
+%define release 1
+%endif
+Name:      microwindows-v%{microwindows_version}-%{_host}-%{release}
+Summary:   microwindows is an Open Source Window System
+Version:   %{microwindows_version}
+Release:   %{release}
+URL:     http://www.microwindows.org/
+BuildRoot: %{_tmppath}/%{name}-root-%(%{__id_u} -n)
+# microwindows Source
+%source set microwindows git://github.com/alex-sever-h/microwin.git
+%patch add microwindows https://raw.githubusercontent.com/yangqiao/rtems-tools/graphics/tools/4.11/microwindows/microwindows-0.93-dev.diff
+%hash md5 microwindows-0.93-dev.diff aea54ac45389ca06c956215bad32c24c
+%patch add microwindows https://raw.githubusercontent.com/yangqiao/rtems-tools/graphics/tools/4.11/microwindows/microwindows-0.93-dev-without-keyboard.diff
+%hash md5 microwindows-0.93-dev-without-keyboard.diff c78aacc33e9b346d5ac78b2b35f17809
+# Prepare the source code.
+%prep
+  build_top=$(pwd)
+  source_dir_microwindows="microwin"
+  %source setup microwindows -q -n microwin
+  %patch setup microwindows -p1
+  cd ${build_top}
+# Build the source code.
+# The configure should be run in the source dir
+%build
+  build_top=$(pwd)
+  %{build_directory}
+  mkdir -p ${build_dir}/src
+  cd ${build_dir}/src
+  cp -r ${build_top}/${source_dir_microwindows}/src/* .
+  #%{host_build_flags}
+  export RTEMS_MAKEFILE_PATH=%{_exec_prefix}
+  make -f Makefile.rtems CONFIG=`pwd`/Configs/config.rtems -k all
+  cd ${build_top}
+%install
+  build_top=$(pwd)
+  %{__rmdir} $SB_BUILD_ROOT
+  mkdir -p $SB_BUILD_ROOT/%{_includedir}
+  mkdir -p $SB_BUILD_ROOT/%{_libdir}
+  mkdir -p $SB_BUILD_ROOT/%{_bindir}
+  cp -r include/* $SB_BUILD_ROOT/%{_includedir}
+  cp -r lib/*.a $SB_BUILD_ROOT/%{_libdir}
+  cp -r bin/* $SB_BUILD_ROOT/%{_bindir}
2.1.0
URL: <http://lists.rtems.org/pipermail/devel/attachments/20150719/1308d211/attachment.html>
