[rtems-source-builder commit] rtems4.11: OpenMP support for ARM, PowerPC, SPARC
Mon Jul 20 06:01:15 UTC 2015
On 19/07/15 01:57, Chris Johns wrote:
> On 18/07/2015 11:38 pm, Sebastian Huber wrote:
>> ----- Chris Johns <chrisj at rtems.org> schrieb:
>>> On 18/07/2015 1:20 am, Joel Sherril wrote:
>>>> diff --git a/rtems/config/4.11/rtems-arm.bset b/rtems/config/4.11/rtems-arm.bset
>>>> index 1e06796..c0bd04a 100644
>>>> --- a/rtems/config/4.11/rtems-arm.bset
>>>> +++ b/rtems/config/4.11/rtems-arm.bset
>>>> @@ -17,6 +17,11 @@
>>>>   %define enable_obsolete 1
>>>> +# Enable OpenMP support
>>>> +%define with_libgomp
>>> I think this forces the option to be always on. Should a user be able to
>>> disable the option with --without-libgomp ?
>> More options more problems.
> The more defaults we turn on the more regression testing we need to do.
The libgomp test suite is part of the GCC test suite, so it makes no big
difference to run it with libgomp enabled or not. It just takes a bit
longer to execute and you need an SMP target to do the run-time tests.
Since OpenMP makes only sense on SMP targets, this is not a real issue.
> The wiki page for OpenMP shows the test results status is unclear.
The problem was the OpenMP 3.1 Validation Suite itself. The libgomp
support for RTEMS uses the POSIX configuration in GCC 4.9.3 which works
really well in terms of correctness. In terms of performance there are
severe problems, see https://devel.rtems.org/ticket/2274.
<http://web.cs.uh.edu/%7Eopenuh/download/>
> If we default to off and a user enables the feature that is different.
> The need for regression testing and test results is not as critical.
>>   I don't think there are serious reasons to disable this option.  If you don't need OpenMP, then you waste a couple of minutes in tool build time and some megabytes of disk storage.
> I am not concerned about the time to build or disk space. I am concerned
> about a change so close to the release plus I have not seen any test
> results. I know it is difficult to make available features while they
> are being worked on however it is also reasonable for users to expect it
> basically works when on by default so it is the default status that
> concerns me and what it says.
The --enable-libgomp has absolutely no impact to your application if you
don't enable OpenMP (-fopenmp).
> Are there test results that can be published for all the arch's enabled ?
> How do we run the tests so we can regression test ?
> FWIW gcc testing and the gcc testsuite is a big item we need to address
> in a formal way so the whole regression testing of tools from building
> to test results is available to all users and not hidden away on
> developer machines with custom scripts.
> Chris
Yes, regular and automated GCC tests are definitely something we need.
We have the scripts available in the rtems-testing repository. It just
needs someone with enough time to polish the scripts and setup a machine
which does regular test runs and publish the results.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
