[PATCH 2/2] score: Introduce Thread_queue_Heads
Mon Jul 20 06:02:31 UTC 2015
Move the storage for the thread queue heads to the threads.  Each thread
provides a set of thread queue heads allocated from a dedicated memory
pool.  In case a thread blocks on a queue, then it lends its heads to
the queue.  In case the thread unblocks, then it takes a free set of
threads from the queue.  Since a thread can block on at most one queue
this works.  This mechanism is used in FreeBSD.  The motivation for this
change is to reduce the memory demands of the synchronization objects.
On a 32-bit uni-processor configuration the Thread_queue_Control size is
now 8 bytes, compared to 64 bytes in RTEMS 4.10 (other changes reduced
the size as well).
 cpukit/libcsupport/src/resource_snapshot.c     |   4 +-
 cpukit/libmisc/monitor/mon-object.c            |   4 +-
 cpukit/posix/include/rtems/posix/pthreadimpl.h |   6 +-
 cpukit/posix/src/killinfo.c                    |  47 ++++----
 cpukit/posix/src/pthread.c                     |   6 +-
 cpukit/rtems/include/rtems/rtems/tasksimpl.h   |   4 +-
 cpukit/rtems/src/taskcreate.c                  |   2 +-
 cpukit/rtems/src/taskdelete.c                  |   5 +-
 cpukit/rtems/src/taskident.c                   |   7 +-
 cpukit/rtems/src/taskmp.c                      |   7 +-
 cpukit/rtems/src/tasks.c                       |   6 +-
 cpukit/sapi/include/confdefs.h                 |   2 +
 cpukit/score/include/rtems/score/objectimpl.h  |   7 ++
 cpukit/score/include/rtems/score/thread.h      |   2 +
 cpukit/score/include/rtems/score/threadimpl.h  |  26 ++++-
 cpukit/score/include/rtems/score/threadq.h     |  30 ++---
 cpukit/score/include/rtems/score/threadqimpl.h |  40 ++++---
 cpukit/score/src/thread.c                      |  43 +++++++-
 cpukit/score/src/threadinitialize.c            |  24 +++-
 cpukit/score/src/threadq.c                     |   5 +-
 cpukit/score/src/threadqops.c                  | 147 +++++++++++++++++++++----
 cpukit/score/src/threadrestart.c               |  13 ++-
 testsuites/sptests/spobjgetnext/init.c         |   2 +-
 testsuites/sptests/sptask_err04/task1.c        |   2 +-
 testsuites/sptests/spthreadq01/init.c          |   4 +-
 25 files changed, 317 insertions(+), 128 deletions(-)
diff --git a/cpukit/libcsupport/src/resource_snapshot.c b/cpukit/libcsupport/src/resource_snapshot.c
index 6bba226..5475139 100644
--- a/cpukit/libcsupport/src/resource_snapshot.c
+++ b/cpukit/libcsupport/src/resource_snapshot.c
@@ -63,7 +63,7 @@ static const Objects_Information *const objects_info_table[] = {
   &_Dual_ported_memory_Information,
   &_Region_Information,
   &_Semaphore_Information,
-  &_RTEMS_tasks_Information,
+  &_RTEMS_tasks_Information.Objects,
   &_Timer_Information
   #ifdef RTEMS_POSIX_API
@@ -75,7 +75,7 @@ static const Objects_Information *const objects_info_table[] = {
     &_POSIX_RWLock_Information,
     &_POSIX_Semaphore_Information,
     &_POSIX_Spinlock_Information,
-    &_POSIX_Threads_Information,
+    &_POSIX_Threads_Information.Objects,
     &_POSIX_Timer_Information
   #endif
diff --git a/cpukit/libmisc/monitor/mon-object.c b/cpukit/libmisc/monitor/mon-object.c
index 1e54c22..72e9f1e 100644
--- a/cpukit/libmisc/monitor/mon-object.c
+++ b/cpukit/libmisc/monitor/mon-object.c
@@ -75,7 +75,7 @@ static const rtems_monitor_object_info_t rtems_monitor_object_info[] =
       (rtems_monitor_object_dump_fn)        rtems_monitor_init_task_dump,
     { RTEMS_MONITOR_OBJECT_TASK,
-      (void *) &_RTEMS_tasks_Information,
+      (void *) &_RTEMS_tasks_Information.Objects,
       sizeof(rtems_monitor_task_t),
       (rtems_monitor_object_next_fn)        rtems_monitor_manager_next,
       (rtems_monitor_object_canonical_fn)   rtems_monitor_task_canonical,
@@ -132,7 +132,7 @@ static const rtems_monitor_object_info_t rtems_monitor_object_info[] =
 #if defined(RTEMS_POSIX_API)
     { RTEMS_MONITOR_OBJECT_PTHREAD,
-      (void *) &_POSIX_Threads_Information,
+      (void *) &_POSIX_Threads_Information.Objects,
diff --git a/cpukit/posix/include/rtems/posix/pthreadimpl.h b/cpukit/posix/include/rtems/posix/pthreadimpl.h
index d0dc330..f95ac9c 100644
--- a/cpukit/posix/include/rtems/posix/pthreadimpl.h
+++ b/cpukit/posix/include/rtems/posix/pthreadimpl.h
@@ -44,7 +44,7 @@ extern "C" {
  * The following defines the information control block used to manage
  * this class of objects.
-POSIX_EXTERN Objects_Information  _POSIX_Threads_Information;
+POSIX_EXTERN Thread_Information  _POSIX_Threads_Information;
  * This variable contains the default POSIX Thread attributes.
@@ -171,7 +171,7 @@ RTEMS_INLINE_ROUTINE Thread_Control *_POSIX_Threads_Allocate(void)
   _Thread_Kill_zombies();
   return (Thread_Control *)
-    _Objects_Allocate_unprotected( &_POSIX_Threads_Information );
+    _Objects_Allocate_unprotected( &_POSIX_Threads_Information.Objects );
@@ -200,7 +200,7 @@ RTEMS_INLINE_ROUTINE void _POSIX_Threads_Free (
   Thread_Control *the_pthread
-  _Objects_Free( &_POSIX_Threads_Information, &the_pthread->Object );
+  _Objects_Free( &_POSIX_Threads_Information.Objects, &the_pthread->Object );
diff --git a/cpukit/posix/src/killinfo.c b/cpukit/posix/src/killinfo.c
index d08e686..a90f4b1 100644
--- a/cpukit/posix/src/killinfo.c
+++ b/cpukit/posix/src/killinfo.c
@@ -70,11 +70,11 @@ int killinfo(
   Thread_Control              *the_thread;
   Thread_Control              *interested;
   Priority_Control             interested_priority;
-  Chain_Control               *the_chain;
   Chain_Node                  *the_node;
   siginfo_t                    siginfo_struct;
   siginfo_t                   *siginfo;
   POSIX_signals_Siginfo_node  *psiginfo;
+  Thread_queue_Heads          *heads;
    *  Only supported for the "calling process" (i.e. this node).
@@ -140,32 +140,35 @@ int killinfo(
   /* XXX violation of visibility -- need to define thread queue support */
-  the_chain = &_POSIX_signals_Wait_queue.Queue.Heads.Fifo;
+  heads = _POSIX_signals_Wait_queue.Queue.heads;
+  if ( heads != NULL ) {
+    Chain_Control *the_chain = &heads->Heads.Fifo;
-  for ( the_node = _Chain_First( the_chain );
-        !_Chain_Is_tail( the_chain, the_node ) ;
-        the_node = the_node->next ) {
+    for ( the_node = _Chain_First( the_chain );
+          !_Chain_Is_tail( the_chain, the_node ) ;
+          the_node = the_node->next ) {
-    the_thread = THREAD_CHAIN_NODE_TO_THREAD( the_node );
-    api = the_thread->API_Extensions[ THREAD_API_POSIX ];
+      the_thread = THREAD_CHAIN_NODE_TO_THREAD( the_node );
+      api = the_thread->API_Extensions[ THREAD_API_POSIX ];
-    #if defined(DEBUG_SIGNAL_PROCESSING)
-      printk( "Waiting Thread=%p option=0x%08x mask=0x%08x blocked=0x%08x\n",
-        the_thread, the_thread->Wait.option, mask, api->signals_blocked);
-    #endif
+      #if defined(DEBUG_SIGNAL_PROCESSING)
+        printk( "Waiting Thread=%p option=0x%08x mask=0x%08x blocked=0x%08x\n",
+          the_thread, the_thread->Wait.option, mask, api->signals_blocked);
+      #endif
-     * Is this thread is actually blocked waiting for the signal?
-    if (the_thread->Wait.option & mask)
-      goto process_it;
+       * Is this thread is actually blocked waiting for the signal?
+      if (the_thread->Wait.option & mask)
+        goto process_it;
-     * Is this thread is blocked waiting for another signal but has
-     * not blocked this one?
-    if (~api->signals_blocked & mask)
-      goto process_it;
+       * Is this thread is blocked waiting for another signal but has
+       * not blocked this one?
+      if (~api->signals_blocked & mask)
+        goto process_it;
diff --git a/cpukit/posix/src/pthread.c b/cpukit/posix/src/pthread.c
index 02d86b5..dc31449 100644
--- a/cpukit/posix/src/pthread.c
+++ b/cpukit/posix/src/pthread.c
@@ -370,19 +370,17 @@ void _POSIX_Threads_Manager_initialization(void)
     CPU_COPY( attr->affinityset, affinity->set );
   #endif
-  _Objects_Initialize_information(
+  _Thread_Initialize_information(
     &_POSIX_Threads_Information, /* object information table */
     OBJECTS_POSIX_API,           /* object API */
     OBJECTS_POSIX_THREADS,       /* object class */
     Configuration_POSIX_API.maximum_threads,
                                  /* maximum objects of this class */
-    _Thread_Control_size,        /* size of this object's control block */
     true,                        /* true if names for this object are strings */
     _POSIX_PATH_MAX              /* maximum length of each object's name */
 #if defined(RTEMS_MULTIPROCESSING)
-    false,                       /* true if this is a global object class */
-    NULL                         /* Proxy extraction support callout */
+    false                        /* true if this is a global object class */
 #endif
diff --git a/cpukit/rtems/include/rtems/rtems/tasksimpl.h b/cpukit/rtems/include/rtems/rtems/tasksimpl.h
index b8f91d3..d35f681 100644
--- a/cpukit/rtems/include/rtems/rtems/tasksimpl.h
+++ b/cpukit/rtems/include/rtems/rtems/tasksimpl.h
@@ -49,7 +49,7 @@ extern "C" {
  *  The following instantiates the information control block used to
  *  manage this class of objects.
-RTEMS_TASKS_EXTERN Objects_Information _RTEMS_tasks_Information;
+RTEMS_TASKS_EXTERN Thread_Information _RTEMS_tasks_Information;
  *  @brief RTEMS Task Manager Initialization
@@ -88,7 +88,7 @@ RTEMS_INLINE_ROUTINE Thread_Control *_RTEMS_tasks_Allocate(void)
-    _Objects_Allocate_unprotected( &_RTEMS_tasks_Information );
+    _Objects_Allocate_unprotected( &_RTEMS_tasks_Information.Objects );
diff --git a/cpukit/rtems/src/taskcreate.c b/cpukit/rtems/src/taskcreate.c
index 65a8d33..f8107be 100644
--- a/cpukit/rtems/src/taskcreate.c
+++ b/cpukit/rtems/src/taskcreate.c
@@ -177,7 +177,7 @@ rtems_status_code rtems_task_create(
   if ( is_global ) {
     _Objects_MP_Open(
       the_global_object,
       name,
       the_thread->Object.id
diff --git a/cpukit/rtems/src/taskdelete.c b/cpukit/rtems/src/taskdelete.c
index dc9a2a1..7a06c51 100644
--- a/cpukit/rtems/src/taskdelete.c
+++ b/cpukit/rtems/src/taskdelete.c
@@ -38,7 +38,10 @@ rtems_status_code rtems_task_delete(
     case OBJECTS_LOCAL:
         if ( the_thread->is_global ) {
-          _Objects_MP_Close( &_RTEMS_tasks_Information, the_thread->Object.id );
+          _Objects_MP_Close(
+            the_thread->Object.id
           _RTEMS_tasks_MP_Send_process_packet(
             RTEMS_TASKS_MP_ANNOUNCE_DELETE,
             the_thread->Object.id,
diff --git a/cpukit/rtems/src/taskident.c b/cpukit/rtems/src/taskident.c
index 28b7406..c4f1770 100644
--- a/cpukit/rtems/src/taskident.c
+++ b/cpukit/rtems/src/taskident.c
@@ -44,7 +44,12 @@ rtems_status_code rtems_task_ident(
     return RTEMS_SUCCESSFUL;
-  status = _Objects_Name_to_id_u32( &_RTEMS_tasks_Information, name, node, id );
+  status = _Objects_Name_to_id_u32(
+    name,
+    node,
+    id
   return _Status_Object_name_errors_to_status[ status ];
diff --git a/cpukit/rtems/src/taskmp.c b/cpukit/rtems/src/taskmp.c
index 339544c..a1386d9 100644
--- a/cpukit/rtems/src/taskmp.c
+++ b/cpukit/rtems/src/taskmp.c
@@ -198,7 +198,7 @@ void _RTEMS_tasks_MP_Process_packet (
     case RTEMS_TASKS_MP_ANNOUNCE_CREATE:
       ignored = _Objects_MP_Allocate_and_open(
                   the_packet->name,
                   the_packet->Prefix.id,
                   true
@@ -209,7 +209,10 @@ void _RTEMS_tasks_MP_Process_packet (
     case RTEMS_TASKS_MP_ANNOUNCE_DELETE:
-      _Objects_MP_Close( &_RTEMS_tasks_Information, the_packet->Prefix.id );
+        the_packet->Prefix.id
       _MPCI_Return_packet( the_packet_prefix );
       break;
diff --git a/cpukit/rtems/src/tasks.c b/cpukit/rtems/src/tasks.c
index 5ed8915..e5a80ee 100644
--- a/cpukit/rtems/src/tasks.c
+++ b/cpukit/rtems/src/tasks.c
@@ -204,19 +204,17 @@ User_extensions_Control _RTEMS_tasks_User_extensions = {
 void _RTEMS_tasks_Manager_initialization(void)
     &_RTEMS_tasks_Information, /* object information table */
     OBJECTS_CLASSIC_API,       /* object API */
     OBJECTS_RTEMS_TASKS,       /* object class */
     Configuration_RTEMS_API.maximum_tasks,
     false,                     /* true if the name is a string */
     RTEMS_MAXIMUM_NAME_LENGTH  /* maximum length of an object name */
-    true,                      /* true if this is a global object class */
+    true                       /* true if this is a global object class */
 #endif
diff --git a/cpukit/sapi/include/confdefs.h b/cpukit/sapi/include/confdefs.h
index 8115a85..4b438ff 100644
--- a/cpukit/sapi/include/confdefs.h
+++ b/cpukit/sapi/include/confdefs.h
@@ -2969,6 +2969,8 @@ const rtems_libio_helper rtems_fs_init_helper =
 #define CONFIGURE_MEMORY_FOR_TASKS(_tasks, _number_FP_tasks) \
     _Configure_Object_RAM(_tasks, sizeof(Configuration_Thread_control)) \
+      + _Configure_From_workspace(_Configure_Max_Objects(_tasks) \
+        * sizeof(Thread_queue_Heads)) \
       + _Configure_Max_Objects(_number_FP_tasks) \
         * _Configure_From_workspace(CONTEXT_FP_SIZE) \
diff --git a/cpukit/score/include/rtems/score/objectimpl.h b/cpukit/score/include/rtems/score/objectimpl.h
index a5a3b7e..1919cd1 100644
--- a/cpukit/score/include/rtems/score/objectimpl.h
+++ b/cpukit/score/include/rtems/score/objectimpl.h
@@ -718,6 +718,13 @@ Objects_Maximum _Objects_Active_count(
   const Objects_Information *information
+RTEMS_INLINE_ROUTINE Objects_Maximum _Objects_Extend_size(
+  const Objects_Information *information
+  return information->auto_extend ? information->allocation_size : 0;
  * This function returns true if the api is valid.
diff --git a/cpukit/score/include/rtems/score/thread.h b/cpukit/score/include/rtems/score/thread.h
index f9ba3a0..2f0b35e 100644
--- a/cpukit/score/include/rtems/score/thread.h
+++ b/cpukit/score/include/rtems/score/thread.h
@@ -349,6 +349,8 @@ typedef struct {
    * @see _Thread_Lock_set() and _Thread_Wait_set_operations().
   const Thread_queue_Operations *operations;
+  Thread_queue_Heads *spare_heads;
 }   Thread_Wait_information;
diff --git a/cpukit/score/include/rtems/score/threadimpl.h b/cpukit/score/include/rtems/score/threadimpl.h
index 4dcef0b..7b8f89c 100644
--- a/cpukit/score/include/rtems/score/threadimpl.h
+++ b/cpukit/score/include/rtems/score/threadimpl.h
@@ -32,6 +32,7 @@
 #include <rtems/score/sysstate.h>
+#include <rtems/score/freechain.h>
 #include <rtems/config.h>
 #ifdef __cplusplus
@@ -54,11 +55,17 @@ extern "C" {
 SCORE_EXTERN void *rtems_ada_self;
+typedef struct {
+  Objects_Information Objects;
+  Freechain_Control Free_thread_queue_heads;
+} Thread_Information;
-SCORE_EXTERN Objects_Information _Thread_Internal_information;
+SCORE_EXTERN Thread_Information _Thread_Internal_information;
  *  The following points to the thread whose floating point
@@ -89,6 +96,19 @@ SCORE_EXTERN struct _reent **_Thread_libc_reent;
   RTEMS_CONTAINER_OF( node, Thread_Control, Resource_node )
 #endif
+void _Thread_Initialize_information(
+  Thread_Information  *information,
+  Objects_APIs         the_api,
+  uint16_t             the_class,
+  uint32_t             maximum,
+  bool                 is_string,
+  uint32_t             maximum_name_length
+#if defined(RTEMS_MULTIPROCESSING)
+  bool                 supports_global
+#endif
  *  @brief Initialize thread handler.
@@ -154,7 +174,7 @@ void _Thread_Stack_Free(
  *        guaranteed to be of at least minimum size.
 bool _Thread_Initialize(
-  Objects_Information                  *information,
   Thread_Control                       *the_thread,
   const struct Scheduler_Control       *scheduler,
   void                                 *stack_area,
@@ -736,7 +756,7 @@ RTEMS_INLINE_ROUTINE uint32_t _Thread_Get_maximum_internal_threads(void)
 RTEMS_INLINE_ROUTINE Thread_Control *_Thread_Internal_allocate( void )
-    _Objects_Allocate_unprotected( &_Thread_Internal_information );
+    _Objects_Allocate_unprotected( &_Thread_Internal_information.Objects );
diff --git a/cpukit/score/include/rtems/score/threadq.h b/cpukit/score/include/rtems/score/threadq.h
index 599a81c..e3aee58 100644
--- a/cpukit/score/include/rtems/score/threadq.h
+++ b/cpukit/score/include/rtems/score/threadq.h
@@ -52,6 +52,14 @@ typedef struct {
     RBTree_Control Priority;
   } Heads;
+  Chain_Control Free_chain;
+  Chain_Node Free_node;
+} Thread_queue_Heads;
+typedef struct {
    * @brief Lock to protect this thread queue.
@@ -80,17 +88,6 @@ typedef void ( *Thread_queue_Priority_change_operation )(
- * @brief Thread queue initialize operation.
- * @param[in] queue The actual thread queue.
- * @see _Thread_Wait_set_operations().
-typedef void ( *Thread_queue_Initialize_operation )(
-  Thread_queue_Queue *queue
  * @brief Thread queue enqueue operation.
@@ -119,7 +116,7 @@ typedef void ( *Thread_queue_Extract_operation )(
  * @brief Thread queue first operation.
+ * @param[in] heads The thread queue heads.
  * @retval NULL No thread is present on the thread queue.
  * @retval first The first thread of the thread queue according to the insert
@@ -128,7 +125,7 @@ typedef void ( *Thread_queue_Extract_operation )(
 typedef Thread_Control *( *Thread_queue_First_operation )(
@@ -150,13 +147,6 @@ typedef struct {
   Thread_queue_Priority_change_operation priority_change;
-   * Called by object initialization routines.
-  Thread_queue_Initialize_operation initialize;
    * Called by object routines to enqueue the thread.
diff --git a/cpukit/score/include/rtems/score/threadqimpl.h b/cpukit/score/include/rtems/score/threadqimpl.h
index 330b18c..e1060e4 100644
--- a/cpukit/score/include/rtems/score/threadqimpl.h
+++ b/cpukit/score/include/rtems/score/threadqimpl.h
@@ -33,6 +33,14 @@ extern "C" {
+RTEMS_INLINE_ROUTINE void _Thread_queue_Queue_initialize(
+  Thread_queue_Queue *queue
+  queue->heads = NULL;
+  _ISR_lock_Initialize( &queue->Lock, "Thread Queue" );
 RTEMS_INLINE_ROUTINE void _Thread_queue_Queue_acquire_critical(
   Thread_queue_Queue *queue,
   ISR_lock_Context   *lock_context
@@ -322,7 +330,13 @@ RTEMS_INLINE_ROUTINE Thread_Control *_Thread_queue_First_locked(
   Thread_queue_Control *the_thread_queue
-  return ( *the_thread_queue->operations->first )( &the_thread_queue->Queue );
+  Thread_queue_Heads *heads = the_thread_queue->Queue.heads;
+    return ( *the_thread_queue->operations->first )( heads );
+  } else {
+    return NULL;
@@ -375,9 +389,7 @@ void _Thread_queue_Initialize(
 #if defined(RTEMS_SMP)
   #define THREAD_QUEUE_FIFO_INITIALIZER( designator, name ) { \
       .Queue = { \
-        .Heads = { \
-          .Fifo = CHAIN_INITIALIZER_EMPTY( designator.Queue.Heads.Fifo ) \
+        .heads = NULL, \
         .Lock = ISR_LOCK_INITIALIZER( name ), \
       .operations = &_Thread_queue_Operations_FIFO \
@@ -385,33 +397,19 @@ void _Thread_queue_Initialize(
   #define THREAD_QUEUE_PRIORITY_INITIALIZER( designator, name ) { \
       .Queue = { \
-        .Heads = { \
-          .Priority = RBTREE_INITIALIZER_EMPTY( \
-            designator.Queue.Heads.Priority \
+        .heads = NULL, \
       .operations = &_Thread_queue_Operations_priority \
 #else
-      .Queue = { \
-        .Heads = { \
+      .Queue = { .heads = NULL }, \
-      .Queue = { \
-        .Heads = { \
 #endif
diff --git a/cpukit/score/src/thread.c b/cpukit/score/src/thread.c
index ef9788c..e1d6d5c 100644
--- a/cpukit/score/src/thread.c
+++ b/cpukit/score/src/thread.c
@@ -20,6 +20,7 @@
 #include <rtems/score/interr.h>
+#include <rtems/score/wkspace.h>
 #define THREAD_OFFSET_ASSERT( field ) \
   RTEMS_STATIC_ASSERT( \
@@ -40,6 +41,42 @@ THREAD_OFFSET_ASSERT( Timer );
 THREAD_OFFSET_ASSERT( receive_packet );
 #endif
+  uint32_t             maximum,
+  bool                 is_string,
+#endif
+  _Objects_Initialize_information(
+    &information->Objects,
+    the_api,
+    the_class,
+    maximum,
+    _Thread_Control_size,
+    is_string,
+    maximum_name_length
+    #if defined(RTEMS_MULTIPROCESSING)
+      supports_global,
+      NULL
+    #endif
+  _Freechain_Initialize(
+    &information->Free_thread_queue_heads,
+    _Workspace_Allocate_or_fatal_error,
+    _Objects_Maximum_per_allocation( maximum ),
+    sizeof( Thread_queue_Heads )
 void _Thread_Handler_initialization(void)
   rtems_stack_allocate_init_hook stack_allocate_init_hook =
@@ -69,18 +106,16 @@ void _Thread_Handler_initialization(void)
    *  per CPU in an SMP system.  In addition, if this is a loosely
    *  coupled multiprocessing system, account for the MPCI Server Thread.
     &_Thread_Internal_information,
     OBJECTS_INTERNAL_API,
     OBJECTS_INTERNAL_THREADS,
     _Thread_Get_maximum_internal_threads(),
     false,                      /* true if names for this object are strings */
     8                           /* maximum length of each object's name */
     #endif
diff --git a/cpukit/score/src/threadinitialize.c b/cpukit/score/src/threadinitialize.c
index c6985f01..9019e1f 100644
--- a/cpukit/score/src/threadinitialize.c
+++ b/cpukit/score/src/threadinitialize.c
@@ -30,7 +30,7 @@
   const Scheduler_Control              *scheduler,
   void                                 *stack_area,
@@ -76,6 +76,7 @@ bool _Thread_Initialize(
   #endif
   the_thread->Start.tls_area = NULL;
+  the_thread->Wait.spare_heads = NULL;
    *  Allocate and Initialize the stack for this thread.
@@ -135,6 +136,20 @@ bool _Thread_Initialize(
   #endif
+   *  Get thread queue heads
+  the_thread->Wait.spare_heads = _Freechain_Get(
+    _Workspace_Allocate,
+    _Objects_Extend_size( &information->Objects ),
+    sizeof( *the_thread->Wait.spare_heads )
+  if ( the_thread->Wait.spare_heads == NULL ) {
+    goto failed;
+  _Chain_Initialize_empty( &the_thread->Wait.spare_heads->Free_chain );
    *  Initialize the thread timer
   _Watchdog_Preinitialize( &the_thread->Timer );
@@ -239,7 +254,7 @@ bool _Thread_Initialize(
    *  Open the object
-  _Objects_Open( information, &the_thread->Object, name );
+  _Objects_Open( &information->Objects, &the_thread->Object, name );
    *  We assume the Allocator Mutex is locked and dispatching is
@@ -260,6 +275,11 @@ failed:
   _Workspace_Free( the_thread->Start.tls_area );
+  _Freechain_Put(
   #if ( CPU_HARDWARE_FP == TRUE ) || ( CPU_SOFTWARE_FP == TRUE )
     _Workspace_Free( fp_area );
   #endif
diff --git a/cpukit/score/src/threadq.c b/cpukit/score/src/threadq.c
index fc50601..27d4d58 100644
--- a/cpukit/score/src/threadq.c
+++ b/cpukit/score/src/threadq.c
@@ -50,8 +50,6 @@ void _Thread_queue_Initialize(
-  _ISR_lock_Initialize( &the_thread_queue->Queue.Lock, "Thread Queue" );
   if ( the_discipline == THREAD_QUEUE_DISCIPLINE_PRIORITY ) {
     operations = &_Thread_queue_Operations_priority;
   } else {
@@ -60,5 +58,6 @@ void _Thread_queue_Initialize(
   the_thread_queue->operations = operations;
-  ( *operations->initialize )( &the_thread_queue->Queue );
+  _Thread_queue_Queue_initialize( &the_thread_queue->Queue );
diff --git a/cpukit/score/src/threadqops.c b/cpukit/score/src/threadqops.c
index e0be491..d19067f 100644
--- a/cpukit/score/src/threadqops.c
+++ b/cpukit/score/src/threadqops.c
@@ -17,6 +17,7 @@
 #endif
+#include <rtems/score/assert.h>
 #include <rtems/score/rbtreeimpl.h>
@@ -37,37 +38,110 @@ static void _Thread_queue_Do_nothing_extract(
   /* Do nothing */
-static void _Thread_queue_FIFO_initialize(
+static void _Thread_queue_Queue_enqueue(
+  Thread_queue_Queue *queue,
+  Thread_Control     *the_thread,
+  void             ( *initialize )( Thread_queue_Heads * ),
+  void             ( *enqueue )( Thread_queue_Heads *, Thread_Control * )
-  _Chain_Initialize_empty( &queue->Heads.Fifo );
+  Thread_queue_Heads *heads = queue->heads;
+  Thread_queue_Heads *spare_heads = the_thread->Wait.spare_heads;
+  if ( heads == NULL ) {
+    _Assert( spare_heads != NULL );
+    _Assert( _Chain_Is_empty( &spare_heads->Free_chain ) );
+    heads = spare_heads;
+    queue->heads = heads;
+    ( *initialize )( heads );
+  _Chain_Prepend_unprotected( &heads->Free_chain, &spare_heads->Free_node );
+  ( *enqueue )( heads, the_thread );
-static void _Thread_queue_FIFO_enqueue(
+static void _Thread_queue_Queue_extract(
+  void             ( *extract )( Thread_queue_Heads *, Thread_Control * )
+  _Assert( heads != NULL );
+  the_thread->Wait.spare_heads = RTEMS_CONTAINER_OF(
+    _Chain_Get_first_unprotected( &heads->Free_chain ),
+    Thread_queue_Heads,
+    Free_node
+  if ( _Chain_Is_empty( &heads->Free_chain ) ) {
+  ( *extract )( heads, the_thread );
+static void _Thread_queue_FIFO_do_initialize(
+  _Chain_Initialize_empty( &heads->Heads.Fifo );
+static void _Thread_queue_FIFO_do_enqueue(
+  Thread_queue_Heads *heads,
   _Chain_Append_unprotected(
-    &queue->Heads.Fifo,
+    &heads->Heads.Fifo,
     &the_thread->Wait.Node.Chain
+static void _Thread_queue_FIFO_do_extract(
+  _Chain_Extract_unprotected( &the_thread->Wait.Node.Chain );
+static void _Thread_queue_FIFO_enqueue(
+  _Thread_queue_Queue_enqueue(
+    queue,
+    the_thread,
+    _Thread_queue_FIFO_do_initialize,
+    _Thread_queue_FIFO_do_enqueue
 static void _Thread_queue_FIFO_extract(
-  _Chain_Extract_unprotected( &the_thread->Wait.Node.Chain );
+  _Thread_queue_Queue_extract(
+    queue,
+    the_thread,
+    _Thread_queue_FIFO_do_extract
 static Thread_Control *_Thread_queue_FIFO_first(
-  Chain_Control *fifo = &queue->Heads.Fifo;
+  Chain_Control *fifo = &heads->Heads.Fifo;
   return _Chain_Is_empty( fifo ) ?
     NULL : THREAD_CHAIN_NODE_TO_THREAD( _Chain_First( fifo ) );
@@ -79,56 +153,85 @@ static void _Thread_queue_Priority_priority_change(
   _RBTree_Extract(
-    &queue->Heads.Priority,
+    &heads->Heads.Priority,
     &the_thread->Wait.Node.RBTree
   _RBTree_Insert(
     &the_thread->Wait.Node.RBTree,
     _Thread_queue_Compare_priority,
     false
-static void _Thread_queue_Priority_initialize(
+static void _Thread_queue_Priority_do_initialize(
-  _RBTree_Initialize_empty( &queue->Heads.Priority );
+  _RBTree_Initialize_empty( &heads->Heads.Priority );
-static void _Thread_queue_Priority_enqueue(
-  Thread_queue_Queue *queue,
+static void _Thread_queue_Priority_do_enqueue(
   _RBTree_Insert(
     false
-static void _Thread_queue_Priority_extract(
+static void _Thread_queue_Priority_do_extract(
   _RBTree_Extract(
+static void _Thread_queue_Priority_enqueue(
+    queue,
+    the_thread,
+    _Thread_queue_Priority_do_initialize,
+    _Thread_queue_Priority_do_enqueue
+static void _Thread_queue_Priority_extract(
+    queue,
+    the_thread,
+    _Thread_queue_Priority_do_extract
 static Thread_Control *_Thread_queue_Priority_first(
   RBTree_Node *first;
-  first = _RBTree_First( &queue->Heads.Priority, RBT_LEFT );
+  first = _RBTree_First( &heads->Heads.Priority, RBT_LEFT );
   return first != NULL ? THREAD_RBTREE_NODE_TO_THREAD( first ) : NULL;
@@ -145,7 +248,6 @@ const Thread_queue_Operations _Thread_queue_Operations_default = {
 const Thread_queue_Operations _Thread_queue_Operations_FIFO = {
   .priority_change = _Thread_queue_Do_nothing_priority_change,
-  .initialize = _Thread_queue_FIFO_initialize,
   .enqueue = _Thread_queue_FIFO_enqueue,
   .extract = _Thread_queue_FIFO_extract,
   .first = _Thread_queue_FIFO_first
@@ -153,7 +255,6 @@ const Thread_queue_Operations _Thread_queue_Operations_FIFO = {
 const Thread_queue_Operations _Thread_queue_Operations_priority = {
   .priority_change = _Thread_queue_Priority_priority_change,
-  .initialize = _Thread_queue_Priority_initialize,
   .enqueue = _Thread_queue_Priority_enqueue,
   .extract = _Thread_queue_Priority_extract,
   .first = _Thread_queue_Priority_first
diff --git a/cpukit/score/src/threadrestart.c b/cpukit/score/src/threadrestart.c
index b98b638..abd809d 100644
--- a/cpukit/score/src/threadrestart.c
+++ b/cpukit/score/src/threadrestart.c
@@ -93,6 +93,9 @@ static void _Thread_Make_zombie( Thread_Control *the_thread )
 static void _Thread_Free( Thread_Control *the_thread )
+  Thread_Information *information = (Thread_Information *)
+    _Objects_Get_information_id( the_thread->Object.id );
   _User_extensions_Thread_delete( the_thread );
@@ -112,6 +115,11 @@ static void _Thread_Free( Thread_Control *the_thread )
   _Workspace_Free( the_thread->Start.fp_context );
 #endif
+  _Freechain_Put(
    *  Free the rest of the memory associated with this task
    *  and set the associated pointers to NULL for safety.
@@ -124,10 +132,7 @@ static void _Thread_Free( Thread_Control *the_thread )
   _ISR_lock_Destroy( &the_thread->Lock.Default );
 #endif
-  _Objects_Free(
-    _Objects_Get_information_id( the_thread->Object.id ),
-    &the_thread->Object
+  _Objects_Free( &information->Objects, &the_thread->Object );
 static void _Thread_Wait_for_execution_stop( Thread_Control *the_thread )
diff --git a/testsuites/sptests/spobjgetnext/init.c b/testsuites/sptests/spobjgetnext/init.c
index 2695190..924d65e 100644
--- a/testsuites/sptests/spobjgetnext/init.c
+++ b/testsuites/sptests/spobjgetnext/init.c
@@ -75,7 +75,7 @@ rtems_task Init(
   TEST_BEGIN();
-  info      = &_RTEMS_tasks_Information;
+  info      = &_RTEMS_tasks_Information.Objects;
   main_task = rtems_task_self();
   puts( "Init - _Objects_Get_next - NULL object information" );
diff --git a/testsuites/sptests/sptask_err04/task1.c b/testsuites/sptests/sptask_err04/task1.c
index 92ddb6d..f7bd98b 100644
--- a/testsuites/sptests/sptask_err04/task1.c
+++ b/testsuites/sptests/sptask_err04/task1.c
@@ -99,7 +99,7 @@ rtems_task Task_1(
     puts( "TA1 - rtems_task_get_note - RTEMS_INVALID_ID" );
     status = rtems_task_get_note(
-      _RTEMS_tasks_Information.minimum_id + (3L<<OBJECTS_API_START_BIT),
+      _RTEMS_tasks_Information.Objects.minimum_id + (3L<<OBJECTS_API_START_BIT),
       RTEMS_NOTEPAD_LAST,
       &notepad_value
diff --git a/testsuites/sptests/spthreadq01/init.c b/testsuites/sptests/spthreadq01/init.c
index 2c27057..b0a3420 100644
--- a/testsuites/sptests/spthreadq01/init.c
+++ b/testsuites/sptests/spthreadq01/init.c
@@ -36,10 +36,10 @@ static rtems_task Init(
   _Thread_Enable_dispatch();
   /* is there more to check? */
-  rtems_test_assert( _Chain_Is_empty( &fifo_queue.Queue.Heads.Fifo ) );
+  rtems_test_assert( fifo_queue.Queue.heads == NULL );
   rtems_test_assert( fifo_queue.operations == &_Thread_queue_Operations_FIFO );
-  rtems_test_assert( _RBTree_Is_empty( &fifo_queue.Queue.Heads.Priority ) );
+  rtems_test_assert( prio_queue.Queue.heads == NULL );
   rtems_test_assert(
     prio_queue.operations == &_Thread_queue_Operations_priority
1.8.4.5
