RPi Graphic testing
QIAO YANG yangqiao0505 at me.com
Mon Jul 20 18:50:32 UTC 2015
So it has got the right pointer for frame buffer.
Please set the macros
BCM2835_FBMEM_BASE to 0x1C006000
and BCM2835_FBMEM_SIZE to 0x500000
according to your log.
in file c/src/lib/libbsp/arm/raspberrypi/include/raspberrypi.h
It’s not possible to setup memory map dynamically and the area is not fixed. I don’t have a better way to deal with it other than set a huge range to cover all possibilities.
waiting for your further report
> On Jul 20, 2015, at 8:38 PM, Pavel Pisa <pisa at cmp.felk.cvut.cz> wrote:
> Hello Qiao Yang and other,
> On Monday 20 of July 2015 15:06:23 Pavel Pisa wrote:
>> Hello Qiao Yang,
>> I have spent more time with attempt to test
>> your RPi code but I am not sucesfull.
>> I have tried direct boot to application binary
>> as well as U-boot based start.
>> I expect that problem source can be version
>> of my primary bootloader
> I have tested the build and it seems that real problem
> is really mismatch between VideoCore area sent
> to the monitor and RTEMS view because application
> seems to run OK, detects monitor
> U-Boot 2014.10-rc2-g600877e-dirty (Sep 25 2014 - 09:57:12)
> DRAM:  448 MiB
> [+] framebuffer initialize
> [+] framebuffer use display resolution 1280*1024
> [#]fb_var_screeninfo: xres : 1280
> [#]fb_var_screeninfo: yres : 1024
> [#]fb_var_screeninfo: bpp : 32
> [#]fb_fix_screeninfo: smem_start : 1C006000
> [#]fb_fix_screeninfo: smem_len : 500000
> [#]fb_fix_screeninfo: line_length : 160
> [#]_RPI_initVideo: maxCol : 160
> [#]_RPI_initVideo: maxRow : 64
> [#]_RPI_initVideo: fb_mem : 1C006000
> and correctly advances to the Init() and test application,
> even character output is called right way to the RPi graphic
> console support. Stack trace for curiosity
> #0  _RPI_outch (c=48 '0') at ../../../../../../../../../../git/rtems-yangqiao/c/src/lib/libbsp/arm/raspberrypi/console/outch.c:347
> #1  0x0000a320 in fbcons_write_polled (c=48 '0', minor=<optimized out>)
> at ../../../../../../../../../../git/rtems-yangqiao/c/src/lib/libbsp/arm/raspberrypi/console/fbcons.c:79
> #2  fbcons_write_support_polled (minor=<optimized out>, buf=0x10a6df "0\001", len=1)
> at ../../../../../../../../../../git/rtems-yangqiao/c/src/lib/libbsp/arm/raspberrypi/console/fbcons.c:102
> #3  0x0000f8c0 in oproc (c=<optimized out>, tty=tty at entry=0x10eb50)
> at ../../../../../../../../git/rtems-yangqiao/c/src/../../cpukit/libcsupport/src/termios.c:1192
> #4  0x0000feb4 in rtems_termios_write (arg=0x10a700)
> at ../../../../../../../../git/rtems-yangqiao/c/src/../../cpukit/libcsupport/src/termios.c:1214
> #5  0x000177ec in rtems_deviceio_write (iop=0x103d70 <rtems_libio_iops+112>, buf=<optimized out>, nbyte=<optimized out>, major=<optimized
> out>, minor=1) at ../../../../../../../../git/rtems-yangqiao/c/src/../../cpukit/libcsupport/src/sup_fs_deviceio.c:109
> #6  0x0001704c in device_write (iop=<optimized out>, buffer=<optimized out>, count=<optimized out>)
> at ../../../../../../../../git/rtems-yangqiao/c/src/../../cpukit/libfs/src/imfs/deviceio.c:82
> #7  0x0001a274 in __swrite (ptr=0x105a08, cookie=0x105c40, buf=0x10a897 "0", n=1)
> at ../../../../../../../src/gcc-4.9/newlib/libc/stdio/stdio.c:97
> #8  0x0001b95c in __sfvwrite_r (ptr=0x105a08, fp=0x105c40, uio=0x10a7e8) at ../../../../../../../src/gcc-4.9/newlib/libc/stdio/fvwrite.c:99
> #9  0x0001a408 in __sprint_r (ptr=<optimized out>, fp=0x105c40, uio=0x10a7e8)
> at ../../../../../../../src/gcc-4.9/newlib/libc/stdio/vfprintf.c:437
> #10 0x0001b204 in _vfiprintf_r (data=0x105a08, fp=fp at entry=0x105c40, fmt0=fmt0 at entry=0x41 "", ap=...)
> at ../../../../../../../src/gcc-4.9/newlib/libc/stdio/vfprintf.c:1774
> #11 0x00019f00 in fiprintf (fp=0x105c40, fmt=0x100398 "%s%02lu:%02lu:%02lu   %02lu/%02lu/%04lu%s")
> at ../../../../../../../src/gcc-4.9/newlib/libc/stdio/fiprintf.c:50
> #12 0x00008ba4 in Test_task (unused=<optimized out>)
> at ../../../../../../../../../git/rtems-yangqiao/c/src/../../testsuites/samples/ticker/tasks.c:44
> #13 0x00019810 in _Thread_Handler () at ../../../../../../../../git/rtems-yangqiao/c/src/../../cpukit/score/src/threadhandler.c:95
> #14 0x000197a0 in TOD_TICKS_PER_SECOND_method ()
> at ../../../../../../../../git/rtems-yangqiao/c/src/../../cpukit/score/src/coretodtickspersec.c:28
> #15 0x00002008 in ?? ()
> #16 0x00002008 in ?? ()
> As for ATAGS, on my system it seems that argument passed by U-boot is consistent. Memory content
> 0x100:	0x00000005 0x54410001
> 0x108:  0x00000000 0x00000000 0x00000000
>  ATAG_CORE block, 5 words complete, all zeros
> 0x114:  0x00000004 0x54410002 0x1c000000 0x00000000
>  ATAG_MEM block, 4 words
>  __u32   size = 0x1c000000 ... 448 MiB
>  __u32   start = 0x00000000
> 0x124:  0x00000067 0x54410009
>  ATAG_CMDLINE block, 0x67 words ... 412 - 8 bytes
>  next ATAG at 0x124 + 0x067 * 4 => 0x2c0
> 0x12c:	"dma.dmachans=0x7f35 bcm2708_fb.fbwidth=1280 bcm2708_fb.fbheight=1024 bcm2708.boardrev=0xf bcm2708.serial=0x53a65607
> smsc95xx.macaddr=B8:27:EB:A6:56:07 sdhci-bcm2708.emmc_clock_freq=250000000 vc_mem.me"...
> 0x1f4:	"m_base=0x1ec00000 vc_mem.mem_size=0x20000000  dwc_otg.lpm_enable=0 console=ttyAMA0,115200 kgdboc=ttyAMA0,115200 root=/dev/mmcblk0p2
> rootfstype=ext4 elevator=deadline rootwait ro init=/sbin/init-overla"...
> 0x2bc:	"y"
> 0x2bd:	0x00	0x00	0x00
> 0x2c0:  0x00	0x00	0x00	0x00	0x00	0x00	0x00
>    ATAG_NONE, end of the list, all OK
> 0x2c8:	0x00	0x00	0x00	0x00	0x00	0x00
> 0x2cd:	0x00	0x00	0x00	0x00	0x00	0x00	0x00	0x00
> 0x2d5:	0x00	0x00	0x00	0x00	0x00	0x00	0x00	0x00
> 0x2dd:	0x00	0x00	0x00	0x00	0x00	0x00	0x00	0x00
> 0x2e5:	0x00	0x00	0x00	0x00	0x00	0x00	0x00	0x00
> 0x2ed:	0x00	0x00	0x00	0x00	0x00	0x00	0x00	0x00
> 0x2f5:	0x00	0x00	0x00	0x00	0x00	0x00	0x00	0x00
> 0x2fd:	0x00	0x00	0x00	0x00	0x00	0x00	0x00	0x00
> 0x305:	0x00	0x00	0x00	0x00	0x00	0x00	0x00	0x00
> 0x30d:	0x00	0x00	0x00	0x00	0x00	0x00	0x00	0x00
> 0x315:	0x00	0x00	0x00	0x00	0x00	0x00	0x00	0x00
> 0x31d:	0x00	0x00	0x00	0x00
> No garbage after command line end. The parameters are reorganized by U-boot,
> More of these added i.e. dma.dmachans, FB parameters etc. My original parameters
> start at dwc_otg.lpm_enable=0 and U-boot modified ones are removed.
> Do the added VideoCore parameters match your expectation?
> It seems to be VideoCore internal data/code area from the first glimpse?
> vc_mem.mem_base=0x1ec00000
> The values are used in Linux kernel and for older kernels ( < 4.0 ) seems to be
> only source of the value. See
> https://github.com/raspberrypi/linux/blob/rpi-3.18.y/arch/arm/mach-bcm2708/vc_mem.c
> Other mechanism is used for never kernels. There has been information that
> dynamic allocation would be used for this memory on newer kernels.
> Do these values match what you expect?
> Genrally, RTEMS should tune its memory map according
> to the boot loader provided parameters.
> Best wishes,
>              Pavel
