[SPAM] Re: Issues on FreeBSD
Thu Jul 23 10:39:01 UTC 2015
It lists an IP address in AU (144.132.189.169) as the one that
spamhaus doesn't like.
http://ipaddress.is/144.132.189.1#.VbDDtPlViko
I am on a corporate guest network in the UK but sent that via OAR.
So I think something at Telstra is at fault this time.
What do you think?
--joel
On 7/23/2015 5:24 AM, Chris Johns wrote:
> Spam detection software, running on the system "corb.contemporary.net.au",
> has identified this incoming email as possible spam.  The original
> message has been attached to this so you can view it or label
> similar future email.  If you have any questions, see
> The administrator of that system for details.
> Content preview:  On 23/07/2015 5:50 pm, Joel Sherrill wrote: > > + mips tools
>     do not build > https://gcc.gnu.org/bugzilla/show_bug.cgi?id=66032 Is this
>     the same issue ? [...]
> Content analysis details:   (3.7 points, 2.7 required)
>   pts rule name              description
> -1.9 BAYES_00               BODY: Bayes spam probability is 0 to 1%
>                              [score: 0.0000]
>   0.0 URIBL_BLOCKED          ADMINISTRATOR NOTICE: The query to URIBL was blocked.
>                              See
>                              http://wiki.apache.org/spamassassin/DnsBlocklists#dnsbl-block
>                               for more information.
>                              [URIs: gnu.org]
>   3.3 RCVD_IN_PBL            RBL: Received via a relay in Spamhaus PBL
>                              [144.132.189.169 listed in zen.spamhaus.org]
>   1.3 RCVD_IN_RP_RNBL        RBL: Relay in RNBL,
>                              https://senderscore.org/blacklistlookup/
>                            [144.132.189.169 listed in bl.score.senderscore.com]
>   1.0 RDNS_DYNAMIC           Delivered to internal network by host with
>                              dynamic-looking rDNS
