Prototype implementation for self-contained objects
Sebastian Huber
Thu Jul 23 12:54:40 UTC 2015
https://lists.rtems.org/pipermail/devel/2015-July/011989.html
Its fully functional and well tested. It is based on the FreeBSD support:
https://git.rtems.org/rtems-libbsd/tree/rtemsbsd/include/machine/rtems-bsd-muteximpl.h
https://git.rtems.org/rtems-libbsd/tree/rtemsbsd/rtems/rtems-bsd-muteximpl.c
It is used to implement the Newlib internal locks and the libgomp (GCC OpenMP
support) operating system services.
There is one issue I am not that happy about. There are two thread queue
definitions:
1. in Newlib <sys/lock.h>
struct _Thread_queue_Queue {
struct _Thread_queue_Heads *_heads;
struct _Ticket_lock_Control _Lock;
2. in <rtems/score/threadq.h>
typedef struct {
Thread_queue_Heads *heads;
* @brief Lock to protect this thread queue.
* It may be used to protect additional state of the object embedding this
* thread queue.
* @see _Thread_queue_Acquire(), _Thread_queue_Acquire_critical() and
* _Thread_queue_Release().
#if defined(RTEMS_SMP)
SMP_ticket_lock_Control Lock;
#endif
} Thread_queue_Queue;
In RTEMS the lock is optional. In Newlib the storage must be always present
for the lock to be independent of the actual RTEMS build configuration. I
ensure with static assertions that the layout of these two structures is
compatible (see top of cpukit/score/src/mutex.c). For the Newlib definition it
would be sufficient to provide a structure with arbitrary content. Only the
alignment and size must fit (see glibc header files for objects shared by
user/kernel space). For debugging purposes it is quite handy to have an
identical layout. I use a cast to get the score definition, e.g.
static Thread_queue_Queue *_Futex_Get_thread_queue(
struct _Futex_Control *futex
return (Thread_queue_Queue *) &futex->_Queue;
This may, however, lead to strict aliasing problems. I am not sure how to
solve this technically best.
