[PATCH 8/8] score: Add scheduler <sys/lock.h> support
Thu Jul 23 12:54:48 UTC 2015
 cpukit/score/Makefile.am                       |  1 +
 cpukit/score/src/sched.c                       | 70 ++++++++++++++++++++++++++
 testsuites/sptests/spsyslock01/init.c          | 17 +++++++
 testsuites/sptests/spsyslock01/spsyslock01.doc |  5 ++
 4 files changed, 93 insertions(+)
 create mode 100644 cpukit/score/src/sched.c
diff --git a/cpukit/score/Makefile.am b/cpukit/score/Makefile.am
index 6f0c4db..5c35611 100644
--- a/cpukit/score/Makefile.am
+++ b/cpukit/score/Makefile.am
@@ -349,6 +349,7 @@ libscore_a_SOURCES += src/profilingisrentryexit.c
 libscore_a_SOURCES += src/mutex.c
 libscore_a_SOURCES += src/once.c
 libscore_a_SOURCES += src/resourceiterate.c
+libscore_a_SOURCES += src/sched.c
 libscore_a_SOURCES += src/semaphore.c
 libscore_a_SOURCES += src/smpbarrierwait.c
 libscore_a_SOURCES += src/kern_tc.c
diff --git a/cpukit/score/src/sched.c b/cpukit/score/src/sched.c
new file mode 100644
index 0000000..e694564
--- /dev/null
+++ b/cpukit/score/src/sched.c
@@ -0,0 +1,70 @@
+ * Copyright (c) 2015 embedded brains GmbH.  All rights reserved.
+ *  embedded brains GmbH
+ *  Dornierstr. 4
+ *  82178 Puchheim
+ *  Germany
+ *  <rtems at embedded-brains.de>
+#if HAVE_CONFIG_H
+  #include "config.h"
+#endif
+#include <sys/lock.h>
+#include <rtems/score/schedulerimpl.h>
+#if HAVE_STRUCT__THREAD_QUEUE_QUEUE
+int _Sched_Count( void )
+  return (int) _Scheduler_Count;
+int _Sched_Index( void )
+  Thread_Control *executing = _Thread_Get_executing();
+  return (int) _Scheduler_Get_index( _Scheduler_Get( executing ) );
+int _Sched_Name_to_index( const char *name, size_t len )
+  uint32_t name_32 = 0;
+  size_t i = 0;
+  while ( i < 4 && i < len ) {
+    name_32 |= ( (uint32_t) ( (uint8_t) *name ) ) << ( ( 3 - i ) * 8 );
+    ++name;
+    ++i;
+  for ( i = 0 ; i < _Scheduler_Count ; ++i ) {
+    const Scheduler_Control *scheduler = &_Scheduler_Table[ i ];
+    if ( scheduler->name == name_32 ) {
+      return (int) i;
+  return -1;
+int _Sched_Processor_count( int index )
+  size_t i = (size_t) index;
+  if ( i < _Scheduler_Count ) {
+    return _Scheduler_Get_processor_count( &_Scheduler_Table[ i ] );
+  } else {
+    return 0;
+#endif /* HAVE_STRUCT__THREAD_QUEUE_QUEUE */
diff --git a/testsuites/sptests/spsyslock01/init.c b/testsuites/sptests/spsyslock01/init.c
index 57f6d35..1309847 100644
--- a/testsuites/sptests/spsyslock01/init.c
+++ b/testsuites/sptests/spsyslock01/init.c
@@ -209,6 +209,20 @@ static void test_futex(test_context *ctx)
   rtems_test_assert(ctx->eno == 0);
+static void test_sched(void)
+  rtems_test_assert(_Sched_Index() == 0);
+  rtems_test_assert(_Sched_Name_to_index("", 0) == -1);
+  rtems_test_assert(_Sched_Name_to_index("b", 1) == -1);
+  rtems_test_assert(_Sched_Name_to_index("bl", 2) == -1);
+  rtems_test_assert(_Sched_Name_to_index("blu", 3) == -1);
+  rtems_test_assert(_Sched_Name_to_index("blue", 4) == 0);
+  rtems_test_assert(_Sched_Name_to_index("blueX", 5) == 0);
+  rtems_test_assert(_Sched_Processor_count(-1) == 0);
+  rtems_test_assert(_Sched_Processor_count(0) == 1);
+  rtems_test_assert(_Sched_Processor_count(1) == 0);
 static void mid_task(rtems_task_argument arg)
   rtems_test_assert(0);
@@ -332,6 +346,7 @@ static void test(void)
   test_prio_inv_recursive(ctx);
   test_sem(ctx);
   test_futex(ctx);
+  test_sched();
   send_events(ctx, EVENT_MTX_DEADLOCK);
@@ -363,6 +378,8 @@ static void Init(rtems_task_argument arg)
 #define CONFIGURE_RTEMS_INIT_TASKS_TABLE
+#define CONFIGURE_SCHEDULER_NAME rtems_build_name('b', 'l', 'u', 'e')
 #define CONFIGURE_INIT
 #include <rtems/confdefs.h>
diff --git a/testsuites/sptests/spsyslock01/spsyslock01.doc b/testsuites/sptests/spsyslock01/spsyslock01.doc
index bf59ceb..c8ab182 100644
--- a/testsuites/sptests/spsyslock01/spsyslock01.doc
+++ b/testsuites/sptests/spsyslock01/spsyslock01.doc
@@ -22,9 +22,14 @@ directives:
   - _Futex_Wait()
   - _Futex_Wake()
   - _Futex_Destroy()
+  - _Sched_Count()
+  - _Sched_Index()
+  - _Sched_Name_to_index()
+  - _Sched_Processor_count()
 concepts:
   - Ensure that self-contained mutexes and recursive mutexes work.
   - Ensure that self-contained semaphores work.
   - Ensure that self-contained futexes work.
+  - Ensure that <sys/lock.h> scheduler support works.
1.8.4.5
