Is there a data race problem while acquiring a mutex with priority inheritance protocol
Saurabh Gadia
gadia at usc.edu
Fri Jul 24 02:41:47 UTC 2015
#if defined(RTEMS_SMP)
RTEMS_INLINE_ROUTINE void _Thread_Lock_restore_default(
Thread_Control *the_thread
_Atomic_Fence( ATOMIC_ORDER_RELEASE );
_Thread_Lock_set_unprotected( the_thread, &the_thread->Lock.Default );
what does this atomic fence does when we set Lock.current=Default in
threadimpl.h?
Thanks,
Saurabh Gadia
On Thu, Jul 23, 2015 at 7:38 PM, Saurabh Gadia <gadia at usc.edu> wrote:
> Yes. I guess I was right about the data race problem we are facing in our
> model. It is also present in rtems:
> _Thread_queue_Extract_locked( &the_mutex->Wait_queue, the_thread );
> line 188 in _CORE_mutex_Surrender() in coremutexsurrender.c where it sets
> holder.Lock->current = holder.Lock->Default. If you get time please have a
> look at it.
> Thanks,
> Saurabh Gadia
> On Thu, Jul 23, 2015 at 7:26 PM, Saurabh Gadia <gadia at usc.edu> wrote:
>> Actually there might exists the same data race problem now in rtems. i.e
>> when holder!=NULL we acquire holder.Lock->current in 2nd code snippet: lock
>> = _Thread_Lock_acquire( the_thread, &lock_context );
>> but if mutex on which holder is waiting gets assigned to holder then
>> current value of holder changes to default lock!! Lets check that.
>> Thanks,
>> Saurabh Gadia
>> On Thu, Jul 23, 2015 at 7:21 PM, Saurabh Gadia <gadia at usc.edu> wrote:
>>> So based on this structure:
>>> typedef struct {
>>> * @brief The current thread lock.
>>> ISR_lock_Control *current;
>>> * @brief The default thread lock in case the thread is not blocked on
>>> a
>>> * resource.
>>> ISR_lock_Control Default;
>>> * @brief Generation number to invalidate stale locks.
>>> Atomic_Uint generation;
>>> } Thread_Lock_control;
>>> present in TCB is same as having holder.trylock corresponding to *current
>>> *in above structure when holder is waiting. So need to check what rtems
>>> does to avoid data race for this *current member* when it becomes
>>> Default after holder gets access to waiting resource.
>>> Thanks,
>>> Saurabh Gadia
>>> On Thu, Jul 23, 2015 at 7:16 PM, Saurabh Gadia <gadia at usc.edu> wrote:
>>>> As per thread initialization in threadinitialize.c we should acquire
>>>> default lock i.e the_thread->Lock.Default. Am I right?
>>>> Thanks,
>>>> Saurabh Gadia
>>>> On Thu, Jul 23, 2015 at 6:58 PM, Saurabh Gadia <gadia at usc.edu> wrote:
>>>>> basically every time we try to acquire mutex there should be lock
>>>>> acquisition related executing thread.
>>>>> Thanks,
>>>>> Saurabh Gadia
>>>>> On Thu, Jul 23, 2015 at 6:47 PM, Saurabh Gadia <gadia at usc.edu> wrote:
>>>>>> hi,
>>>>>> Scenario:
>>>>>> thread t1: current_priority = 5, mutex acquired = m1, m2
>>>>>> thread t2: current_priority = 3, mutex_acquired = None
>>>>>> flow: thread t1 tries to acquire mutex m3 and thread t2 tries to
>>>>>> acquire mutex m1 which is already acquired by thread t1 simultaneously on
>>>>>> SMP.
>>>>>> Action:
>>>>>> thred t1 finds that m3 ->holder==NULL, so following code snippet of
>>>>>> coremuteximpl.h executes on one processor:
>>>>>> RTEMS_INLINE_ROUTINE int _CORE_mutex_Seize_interrupt_trylock_body(
>>>>>> CORE_mutex_Control *the_mutex,
>>>>>> Thread_Control *executing,
>>>>>> ISR_lock_Context *lock_context
>>>>>> /* disabled when you get here */
>>>>>> executing->Wait.return_code = CORE_MUTEX_STATUS_SUCCESSFUL;
>>>>>> if ( !_CORE_mutex_Is_locked( the_mutex ) ) {
>>>>>> the_mutex->holder = executing;
>>>>>> the_mutex->nest_count = 1;
>>>>>> if ( _CORE_mutex_Is_inherit_priority( &the_mutex->Attributes ) ||
>>>>>> _CORE_mutex_Is_priority_ceiling( &the_mutex->Attributes ) ){
>>>>>> #ifdef __RTEMS_STRICT_ORDER_MUTEX__
>>>>>> /* Doesn't this lead to data race. If the executing thread is holder
>>>>>> os some other mutex and its priority is promoted by other
>>>>>> thread
>>>>>> _Chain_Prepend_unprotected( &executing->lock_mutex,
>>>>>> &the_mutex->queue.lock_queue );
>>>>>> *the_mutex->queue.priority_before =
>>>>>> executing->current_priority;*
>>>>>> #endif
>>>>>> executing->resource_count++;
>>>>>> if ( !_CORE_mutex_Is_priority_ceiling( &the_mutex->Attributes ) )
>>>>>> _Thread_queue_Release( &the_mutex->Wait_queue, lock_context );
>>>>>> return 0;
>>>>>> And thread t2 tries to acquire m1 and following snippet of
>>>>>> threadchangepriority.c executes:
>>>>>> /////// (the_thread is holder for mutex m1 and new_priority ==
>>>>>> priority of thread t2 ==3)
>>>>>> lock = _Thread_Lock_acquire( the_thread, &lock_context );
>>>>>> * For simplicity set the priority restore hint unconditionally
>>>>>> since this is
>>>>>> * an average case optimization. Otherwise complicated atomic
>>>>>> operations
>>>>>> * would be necessary. Synchronize with a potential read of the
>>>>>> resource
>>>>>> * count in the filter function. See also _CORE_mutex_Surrender(),
>>>>>> * _Thread_Set_priority_filter() and
>>>>>> _Thread_Restore_priority_filter().
>>>>>> the_thread->priority_restore_hint = true;
>>>>>> _Atomic_Fence( ATOMIC_ORDER_ACQ_REL );
>>>>>> * Do not bother recomputing all the priority related information
>>>>>> if
>>>>>> * we are not REALLY changing priority.
>>>>>> if ( ( *filter )( the_thread, &new_priority, arg ) ) {
>>>>>> uint32_t my_generation;
>>>>>> my_generation = the_thread->priority_generation + 1;
>>>>>> * the_thread->current_priority = new_priority;*
>>>>>> the_thread->priority_generation = my_generation;
>>>>>> ( *the_thread->Wait.operations->priority_change )(
>>>>>> the_thread,
>>>>>> new_priority,
>>>>>> the_thread->Wait.queue
>>>>>> So can interleaving of highlighted code result in data race? From my
>>>>>> perspective and from JPF model experience this is a data race and we need
>>>>>> to have locking on executing thread and holder thread if it exists for
>>>>>> mutex while acquiring any mutex.
>>>>>> So for 2nd case when there is already holder we do acquire holder
>>>>>> lock by calling *lock = _Thread_Lock_acquire( the_thread,
>>>>>> &lock_context ); *in 2nd snippet but we should do the same on
>>>>>> executing thread when holder==NULL in 1st code snippet.
>>>>>> Am I right? or is there something I am missing?
>>>>>> Thanks,
>>>>>> Saurabh Gadia
URL: <http://lists.rtems.org/pipermail/devel/attachments/20150723/1dd8c7da/attachment-0001.html>
