[PATCH] GSoC: Cache configurations Raspberry Pi 2 support
Rohini Kulkarni
krohini1593 at gmail.com
Fri Jul 24 18:39:49 UTC 2015
On Fri, Jul 24, 2015 at 7:03 PM, Gedare Bloom <gedare at gwu.edu> wrote:
> On Fri, Jul 24, 2015 at 3:30 AM, Rohini Kulkarni <krohini1593 at gmail.com>
> wrote:
> > On 24 Jul 2015 12:35, "Sebastian Huber" <
> sebastian.huber at embedded-brains.de>
> > wrote:
> >> On 23/07/15 23:24, Rohini Kulkarni wrote:
> >>> I could finally get back to this issue. I used Pi 1 for debugging, but
> >>> the reason for this problem will apply to Pi 2 also.
> >>> With text section set to ARMV7_MMU_CODE_CACHED ( which implies read
> only)
> >>> , a data abort exception occurs with memset() inside
> bsp_start_clear_bss()
> >>> function. An illegal write access to an address according to me.
> >> Which exception and which address? Something is not working here.
> > This is a part of the debugging output. When I used
> ARMV7_MMU_CODE_CACHED.
> > (gdb) s
> > bsp_start_clear_bss ()
> > at ../../../../../.././raspberrypi/lib/include/bsp/start.h:126
> > 126 memset(bsp_section_bss_begin, 0, (size_t) bsp_section_bss_size);
> What are the values of bsp_section_bss_begin, and bsp_section_bss_size?
> Apparently, the memset is trying to write into the .text (code)
> section, which is a very bad thing to do indeed.
> > (gdb) s
> > memset (m=0x1157e0, c=0, n=64176)
These memset parameters indicate the start location bsp_section_bss_begin
and size of bss section bsp_section_bss_size.
> at ../../../../../gcc-4.9.2/newlib/libc/string/memset.c:59
> > 59 ../../../../../gcc-4.9.2/newlib/libc/string/memset.c: No such file
> or
> > directory.
> > (gdb) s
> > 49 in ../../../../../gcc-4.9.2/newlib/libc/string/memset.c
> > (gdb) s
> > _ARMV4_Exception_data_abort_default ()
> > at
> ../../../../../../../../rtems-local/rtems/c/src/../../cpukit/score/cpu/arm/armv4-exception-default.S:71
> > 71 sub sp, #MORE_CONTEXT_SIZE
> > When I set text section flag to ARMV7_MMU_READ_WRITE, the system starts
> > successfully.
> >> Sebastian Huber, embedded brains GmbH
> >> Address : Dornierstr. 4, D-82178 Puchheim, Germany
> >> Phone : +49 89 189 47 41-16
> >> Fax : +49 89 189 47 41-09
> >> E-Mail : sebastian.huber at embedded-brains.de
> >> PGP : Public key available on request.
> >> Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
> > devel mailing list
> > devel at rtems.org
Rohini Kulkarni
URL: <http://lists.rtems.org/pipermail/devel/attachments/20150725/d1fd78fd/attachment.html>
