[PATCH V2 1/2] RTEMS GPIO API definition and implementation.
Andre Marques andre.lousa.marques at gmail.com
Mon Jul 27 16:01:43 UTC 2015
Changes relative to the previous patch set:
- Moved GPIO pin interrupts to rtems chains, instead of a local linked list;
- Restructured the pin tracking structure, separating the interrupt information for each pin meaning that a pin without any interrupt enabled only requires 8 bytes, while keeping interrupt information (handling information, handler chain control, ...) requires 24 additional bytes (total of 32 bytes per pin with interrupts enabled);
-  Added support for 'parallel' pin function assignment, allowing the function assignment to be set for multiple pins in a single GPIO hardware call. If a BSP does not support this feature it becomes a sequence of individual calls per pin. Also added support for GPIO pin groupings, allowing to write and read byte data to a series of pins which behave as a single entity;
- Added bank tracking structure to maintain the bank lock and bank level interrupt information (threaded/normal handling, interrupt counter);
- Changed GPIO settings to BSP defined constants, reducing dynamic memory allocation;
- Switched interrupt tasks for a rtems interrupt server, with the possibility of using normal interrupts (user handlers being called within ISR context).
 c/src/lib/libbsp/Makefile.am           |    3 +-
 c/src/lib/libbsp/preinstall.am         |    4 +
 c/src/lib/libbsp/shared/gpio.c         | 1977 ++++++++++++++++++++++++++++++++
 c/src/lib/libbsp/shared/include/gpio.h |  948 +++++++++++++++
 4 files changed, 2931 insertions(+), 1 deletion(-)
 create mode 100644 c/src/lib/libbsp/shared/gpio.c
 create mode 100644 c/src/lib/libbsp/shared/include/gpio.h
diff --git a/c/src/lib/libbsp/Makefile.am b/c/src/lib/libbsp/Makefile.am
index 3cab4d7..a039a98 100644
--- a/c/src/lib/libbsp/Makefile.am
+++ b/c/src/lib/libbsp/Makefile.am
@@ -9,7 +9,7 @@ EXTRA_DIST = MERGE.PROCEDURE bsp.am
 EXTRA_DIST += shared/bootcard.c shared/bspclean.c \
     shared/bsplibc.c shared/bsppost.c shared/console-polled.c \
     shared/console.c shared/gnatinstallhandler.c shared/sbrk.c \
-    shared/tod.c
+    shared/tod.c shared/gpio.c
 EXTRA_DIST += shared/vmeUniverse/vmeUniverse.c \
     shared/vmeUniverse/vmeUniverse.h \
     shared/vmeUniverse/vmeUniverseDMA.h \
@@ -35,6 +35,7 @@ include_bsp_HEADERS =
 include_bsp_HEADERS += shared/include/default-initial-extension.h
 include_bsp_HEADERS += shared/include/fatal.h
 include_bsp_HEADERS += shared/include/console-termios.h
+include_bsp_HEADERS += shared/include/gpio.h
 include $(srcdir)/preinstall.am
 include $(top_srcdir)/automake/subdirs.am
diff --git a/c/src/lib/libbsp/preinstall.am b/c/src/lib/libbsp/preinstall.am
index 651f136..bbcb7c5 100644
--- a/c/src/lib/libbsp/preinstall.am
+++ b/c/src/lib/libbsp/preinstall.am
@@ -30,3 +30,7 @@ $(PROJECT_INCLUDE)/bsp/console-termios.h: shared/include/console-termios.h $(PRO
 	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/console-termios.h
 PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/console-termios.h
+$(PROJECT_INCLUDE)/bsp/gpio.h: shared/include/gpio.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/gpio.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/gpio.h
diff --git a/c/src/lib/libbsp/shared/gpio.c b/c/src/lib/libbsp/shared/gpio.c
new file mode 100644
index 0000000..a87b39f
--- /dev/null
+++ b/c/src/lib/libbsp/shared/gpio.c
@@ -0,0 +1,1977 @@
+ * @file gpio.c
+ * @ingroup rtems_gpio
+ * @brief RTEMS GPIO API implementation.
+ *  Copyright (c) 2014-2015 Andre Marques <andre.lousa.marques at gmail.com>
+ *  The license and distribution terms for this file may be
+ *  found in the file LICENSE in this distribution or at
+ *  http://www.rtems.org/license/LICENSE.
+#include <rtems/score/atomic.h>
+#include <rtems/chain.h>
+#include <bsp/irq-generic.h>
+#include <bsp/gpio.h>
+#include <assert.h>
+#include <stdlib.h>
+ * @brief GPIO API mutex attributes.
+#define MUTEX_ATTRIBUTES (     \
+  RTEMS_LOCAL                  \
+  | RTEMS_PRIORITY             \
+  | RTEMS_BINARY_SEMAPHORE     \
+  | RTEMS_INHERIT_PRIORITY     \
+  | RTEMS_NO_PRIORITY_CEILING  \
+#define CREATE_LOCK(name, lock_id) rtems_semaphore_create(   \
+  name,                                                      \
+  1,                                                         \
+  MUTEX_ATTRIBUTES,                                          \
+  0,                                                         \
+  lock_id                                                    \
+#define ACQUIRE_LOCK(m) assert ( rtems_semaphore_obtain(m,               \
+                                                        RTEMS_WAIT,      \
+                                                        RTEMS_NO_TIMEOUT \
+                                                        ) == RTEMS_SUCCESSFUL )
+#define RELEASE_LOCK(m) assert ( rtems_semaphore_release(m) == RTEMS_SUCCESSFUL )
+ * @brief Object containing relevant information about a GPIO group.
+ * Encapsulates relevant data for a GPIO pin group.
+struct rtems_gpio_group
+  rtems_chain_node node;
+  uint32_t *digital_inputs;
+  uint32_t digital_input_bank;
+  uint32_t input_count;
+  uint32_t *digital_outputs;
+  uint32_t digital_output_bank;
+  uint32_t output_count;
+  uint32_t *bsp_speficifc_pins;
+  uint32_t bsp_specific_bank;
+  uint32_t bsp_specific_pin_count;
+  rtems_id group_lock;
+ * @brief Object containing relevant information to a list of user-defined
+ *        interrupt handlers.
+ * Encapsulates relevant data for a GPIO interrupt handler.
+typedef struct
+  /* User-defined ISR routine. */
+  rtems_gpio_irq_state (*handler) (void *arg);
+  /* User-defined arguments for the ISR routine. */
+  void *arg;
+} gpio_handler_node;
+ * @brief Object containing relevant information of a pin's interrupt
+ *        configuration/state.
+ * Encapsulates relevant data of a GPIO pin interrupt state.
+typedef struct
+  /* Currently active interrupt. */
+  rtems_gpio_interrupt active_interrupt;
+  /* ISR shared flag. */
+  rtems_gpio_handler_flag handler_flag;
+  /* Linked list of interrupt handlers. */
+  rtems_chain_control handler_chain;
+  /* Switch-deboucing information. */
+  uint32_t debouncing_tick_count;
+  rtems_interval last_isr_tick;
+} gpio_pin_interrupt_state;
+ * @brief Object containing information on a GPIO pin.
+ * Encapsulates relevant data about a GPIO pin.
+typedef struct
+  rtems_gpio_function pin_function;
+  /* GPIO pull resistor configuration. */
+  rtems_gpio_pull_mode resistor_mode;
+  /* If true inverts digital in/out applicational logic. */
+  bool logic_invert;
+  /* True if the pin is on a group. */
+  bool on_group;
+  /* Interrupt data for a pin. This field is NULL if no interrupt is enabled
+   * on the pin. */
+  gpio_pin_interrupt_state *interrupt_state;
+} gpio_pin;
+ * @brief Object containing relevant information regarding a GPIO bank state.
+ * Encapsulates relevant data for a GPIO bank.
+typedef struct
+  uint32_t bank_number;
+  uint32_t interrupt_counter;
+  rtems_id lock;
+  /* If TRUE the interrupts on the bank will be called
+   * by a rtems interrupt server, otherwise they will be handled
+   * in the normal ISR context. */
+  bool threaded_interrupts;
+} gpio_bank;
+static gpio_pin gpio_pin_state[BSP_GPIO_PIN_COUNT];
+static Atomic_Flag init_flag = ATOMIC_INITIALIZER_FLAG;
+static gpio_bank gpio_bank_state[GPIO_BANK_COUNT];
+static Atomic_Uint threaded_interrupt_counter = ATOMIC_INITIALIZER_UINT(0);
+static rtems_chain_control gpio_group;
+#define BANK_NUMBER(pin_number) pin_number / BSP_GPIO_PINS_PER_BANK
+#define PIN_NUMBER(pin_number) pin_number % BSP_GPIO_PINS_PER_BANK
+static int debounce_switch(gpio_pin_interrupt_state *interrupt_state)
+  rtems_interval time;
+  time = rtems_clock_get_ticks_since_boot();
+  /* If not enough time has elapsed since last interrupt. */
+  if (
+      (time - interrupt_state->last_isr_tick) <
+      interrupt_state->debouncing_tick_count
+    return -1;
+  interrupt_state->last_isr_tick = time;
+  return 0;
+/* Returns the amount of pins in a bank. */
+static uint32_t get_bank_pin_count(uint32_t bank)
+  /* If the current bank is the last bank, which may not be completely filled. */
+  if ( bank == GPIO_BANK_COUNT - 1 ) {
+    return GPIO_LAST_BANK_PINS;
+  return BSP_GPIO_PINS_PER_BANK;
+/* GPIO generic bank ISR. This may be called directly as response to an
+ * interrupt, or by the rtems interrupt server task if the GPIO bank
+ * uses threading interrupt handling. */
+static void generic_bank_isr(void *arg)
+  rtems_chain_control *handler_list;
+  rtems_chain_node *node;
+  rtems_chain_node *next_node;
+  gpio_handler_node *isr_node;
+  rtems_vector_number vector;
+  uint32_t event_status;
+  uint32_t bank_start_pin;
+  uint8_t handled_count;
+  uint8_t rv;
+  uint8_t i;
+  bank_number = *((uint32_t*) arg);
+  assert ( bank_number >= 0 && bank_number < GPIO_BANK_COUNT );
+  /* Calculate bank start address in the pin_state array. */
+  bank_start_pin = bank_number * BSP_GPIO_PINS_PER_BANK;
+  vector = rtems_gpio_bsp_get_vector(bank_number);
+  /* If this bank does not use threaded interrupts we have to
+   * disable the vector. Otherwise the interrupt server does it. */
+  if ( gpio_bank_state[bank_number].threaded_interrupts == false ) {
+    /* Prevents more interrupts from being generated on GPIO. */
+    bsp_interrupt_vector_disable(vector);
+  /* Obtains a 32-bit bitmask, with the pins currently reporting interrupts
+   * signaled with 1. */
+  event_status = rtems_gpio_bsp_interrupt_line(vector);
+  /* Iterates through the bitmask and calls the corresponding handler
+   * for active interrupts. */
+  for ( i = 0; i < get_bank_pin_count(bank_number); ++i ) {
+    /* If active, wake the corresponding pin's ISR task. */
+    if ( event_status & (1 << i) ) {
+      interrupt_state = gpio_pin_state[bank_start_pin + i].interrupt_state;
+      assert ( interrupt_state != NULL );
+      handled_count = 0;
+      if ( gpio_bank_state[bank_number].threaded_interrupts ) {
+        ACQUIRE_LOCK(gpio_bank_state[bank_number].lock);
+      /* If this pin has the debouncing function attached, call it. */
+      if ( interrupt_state->debouncing_tick_count > 0 ) {
+        rv = debounce_switch(interrupt_state);
+        /* If the handler call was caused by a switch bounce,
+         * ignores and move on. */
+        if ( rv < 0 ) {
+            RELEASE_LOCK(gpio_bank_state[bank_number].lock);
+          continue;
+      handler_list = &interrupt_state->handler_chain;
+      node = rtems_chain_first(handler_list);
+      /* Iterate the ISR list. */
+      while ( !rtems_chain_is_tail(handler_list, node) ) {
+        isr_node = (gpio_handler_node *) node;
+        next_node = node->next;
+        if ( (isr_node->handler)(isr_node->arg) == IRQ_HANDLED ) {
+          ++handled_count;
+        node = next_node;
+      /* If no handler assumed the interrupt,
+       * treat it as a spurious interrupt. */
+      if ( handled_count == 0 ) {
+        bsp_interrupt_handler_default(rtems_gpio_bsp_get_vector(bank_number));
+    bsp_interrupt_vector_enable(vector);
+/* Verifies if all pins in the received pin array are from the same bank and
+ * have the defined GPIO function. Produces bitmask of the received pins. */
+static rtems_status_code get_pin_bitmask(
+  uint32_t *pins,
+  uint32_t pin_count,
+  uint32_t *bank_number,
+  uint32_t *bitmask,
+  rtems_gpio_function function
+  uint32_t pin_number;
+  uint32_t bank;
+  uint8_t i;
+  if ( pin_count < 1 ) {
+    return RTEMS_UNSATISFIED;
+  *bitmask = 0;
+  for ( i = 0; i < pin_count; ++i ) {
+    pin_number = pins[i];
+    if ( pin_number < 0 || pin_number >= BSP_GPIO_PIN_COUNT ) {
+      return RTEMS_INVALID_ID;
+    bank = BANK_NUMBER(pin_number);
+    if ( i == 0 ) {
+      *bank_number = bank;
+      ACQUIRE_LOCK(gpio_bank_state[bank].lock);
+    else if ( bank != *bank_number ) {
+      RELEASE_LOCK(gpio_bank_state[*bank_number].lock);
+    if (
+        gpio_pin_state[pin_number].pin_function != function ||
+        gpio_pin_state[pin_number].on_group
+      RELEASE_LOCK(gpio_bank_state[bank].lock);
+      return RTEMS_NOT_CONFIGURED;
+    *bitmask |= (1 << PIN_NUMBER(pin_number));
+  return RTEMS_SUCCESSFUL;
+static rtems_status_code check_same_bank_and_availability(
+  const rtems_gpio_pin_conf *pin_confs,
+  uint32_t *pins
+  uint32_t bank;
+  uint8_t i;
+    pin_number = pin_confs[i].pin_number;
+    if ( i == 0 ) {
+    if ( gpio_pin_state[pin_number].pin_function != NOT_USED ) {
+      return RTEMS_RESOURCE_IN_USE;
+    pins[i] = PIN_NUMBER(pin_number);
+static rtems_status_code setup_resistor_and_interrupt_configuration(
+  uint32_t pin_number,
+  rtems_gpio_pull_mode pull_mode,
+  rtems_gpio_interrupt_configuration *interrupt_conf
+  rtems_status_code sc;
+  uint32_t bank;
+  sc = rtems_gpio_resistor_mode(pin_number, pull_mode);
+  if ( sc != RTEMS_SUCCESSFUL ) {
+#if defined(DEBUG)
+    printk("rtems_gpio_resistor_mode failed with status code %d\n", sc);
+#endif
+  if ( interrupt_conf != NULL ) {
+    sc = rtems_gpio_enable_interrupt(
+           pin_number,
+           interrupt_conf->active_interrupt,
+           interrupt_conf->handler_flag,
+           interrupt_conf->threaded_interrupts,
+           interrupt_conf->handler,
+           interrupt_conf->arg
+#if defined(DEBUG)
+      printk(
+        "rtems_gpio_enable_interrupt failed with status code %d\n",
+        sc
+#endif
+    interrupt_state = gpio_pin_state[pin_number].interrupt_state;
+    interrupt_state->debouncing_tick_count =
+      interrupt_conf->debounce_clock_tick_interval;
+    interrupt_state->last_isr_tick = 0;
+static rtems_status_code gpio_multi_select(
+  const rtems_gpio_pin_conf *pins,
+  uint8_t pin_count,
+  bool on_group
+  uint32_t bank;
+  uint8_t i;
+  /* If the BSP has multi select capabilities. */
+#ifdef BSP_GPIO_PINS_PER_SELECT_BANK
+  rtems_gpio_multiple_pin_select
+    pin_data[GPIO_SELECT_BANK_COUNT][BSP_GPIO_PINS_PER_SELECT_BANK];
+  rtems_gpio_specific_data *bsp_data;
+  /* Since each platform may have more than two functions to assign to a pin,
+   * each pin requires more than one bit in the selection register to
+   * properly assign a function to it.
+   * Therefore a selection bank (pin selection register) will support fewer pins
+   * than a regular bank, meaning that there will be more selection banks than
+   * regular banks, which have to be handled separately.
+   * This field records the select bank number relative to the GPIO bank. */
+  uint32_t select_bank;
+  uint32_t select_bank_counter[GPIO_SELECT_BANK_COUNT];
+  uint32_t select_count;
+  uint32_t pin;
+  if ( pin_count == 0 ) {
+  for ( i = 0; i < GPIO_SELECT_BANK_COUNT; ++i ) {
+    select_bank_counter[i] = 0;
+    pin_number = pins[i].pin_number;
+    pin = PIN_NUMBER(pin_number);
+    if ( i == 0 ) {
+      bank_number = bank;
+    else if ( bank != bank_number ) {
+    /* If the pin is already being used returns with an error. */
+    select_bank = (pin_number / BSP_GPIO_PINS_PER_SELECT_BANK) -
+                  (bank * GPIO_SELECT_BANK_COUNT);
+    select_count = select_bank_counter[select_bank];
+    pin_data[select_bank][select_count].pin_number = pin_number;
+    pin_data[select_bank][select_count].function = pins[i].function;
+    if ( pins[i].function == BSP_SPECIFIC ) {
+      bsp_data = (rtems_gpio_specific_data *) pins[i].bsp_specific;
+      if ( bsp_data == NULL ) {
+      pin_data[select_bank][select_count].io_function = bsp_data->io_function;
+      pin_data[select_bank][select_count].bsp_specific = bsp_data->pin_data;
+    else {
+      /* io_function takes a dummy value, as it will not be used. */
+      pin_data[select_bank][select_count].io_function = 0;
+      pin_data[select_bank][select_count].bsp_specific = pins[i].bsp_specific;
+    ++select_bank_counter[select_bank];
+    if ( select_bank_counter[i] == 0 ) {
+      continue;
+    sc = rtems_gpio_bsp_multi_select(
+           pin_data[i], select_bank_counter[i], i +
+           (bank_number * GPIO_SELECT_BANK_COUNT)
+      return sc;
+    /* Fill other pin state information. */
+    gpio_pin_state[pin_number].pin_function = pins[i].function;
+    gpio_pin_state[pin_number].logic_invert = pins[i].logic_invert;
+    gpio_pin_state[pin_number].on_group = on_group;
+    sc = setup_resistor_and_interrupt_configuration(
+           pin_number,
+           pins[i].pull_mode,
+           pins[i].interrupt
+      return sc;
+    if ( pins[i].function == DIGITAL_OUTPUT ) {
+      if ( pins[i].output_enabled == true ) {
+        sc = rtems_gpio_bsp_set(bank, pin);
+      else {
+        sc = rtems_gpio_bsp_clear(bank, pin);
+        return sc;
+  return sc;
+  /* If the BSP does not provide pin multi-selection,
+   * configures each pin sequentially. */
+#else
+    sc = rtems_gpio_request_configuration(&pins[i]);
+      return sc;
+    gpio_pin_state[pins[i].pin_number].on_group = on_group;
+#endif
+rtems_status_code rtems_gpio_initialize(void)
+  uint32_t i;
+  if ( _Atomic_Flag_test_and_set(&init_flag, ATOMIC_ORDER_RELAXED) == true ) {
+  for ( i = 0; i < GPIO_BANK_COUNT; ++i ) {
+    sc = CREATE_LOCK(
+           rtems_build_name('G', 'I', 'N', 'T'),
+           &gpio_bank_state[i].lock
+      return sc;
+    gpio_bank_state[i].bank_number = i;
+    gpio_bank_state[i].interrupt_counter = 0;
+    /* The threaded_interrupts field is initialized during
+     * rtems_gpio_enable_interrupt(), as its value is never used before. */
+  for ( i = 0; i < BSP_GPIO_PIN_COUNT; ++i ) {
+    gpio_pin_state[i].pin_function = NOT_USED;
+    gpio_pin_state[i].resistor_mode = NO_PULL_RESISTOR;
+    gpio_pin_state[i].logic_invert = false;
+    gpio_pin_state[i].on_group = false;
+    gpio_pin_state[i].interrupt_state = NULL;
+  /* Initialize GPIO groups chain. */
+  rtems_chain_initialize_empty(&gpio_group);
+rtems_gpio_group *rtems_gpio_create_pin_group(void)
+  struct rtems_gpio_group *group;
+  group = (struct rtems_gpio_group *) malloc(sizeof(struct rtems_gpio_group));
+  return group;
+rtems_status_code rtems_gpio_define_pin_group(
+  const rtems_gpio_group_definition *group_definition,
+  rtems_gpio_group *group
+  if ( group_definition == NULL || group == NULL ) {
+  if (
+      group_definition->input_count == 0 &&
+      group_definition->output_count == 0 &&
+      group_definition->bsp_specific_pin_count == 0
+  group->input_count = group_definition->input_count;
+  if ( group->input_count > 0 ) {
+    group->digital_inputs =
+      (uint32_t *) malloc(group->input_count * sizeof(uint32_t));
+    /* Evaluate if the pins that will constitute the group are available and
+     * that pins with the same function within the group all belong
+     * to the same pin group. */
+    sc = check_same_bank_and_availability(
+           group_definition->digital_inputs,
+           group->input_count,
+           &group->digital_input_bank,
+      return sc;
+  else {
+    group->digital_inputs = NULL;
+  group->output_count = group_definition->output_count;
+  if ( group->output_count > 0 ) {
+    group->digital_outputs =
+      (uint32_t *) malloc(group->output_count * sizeof(uint32_t));
+           group_definition->digital_outputs,
+           group->output_count,
+           &group->digital_output_bank,
+      return sc;
+  else {
+    group->digital_outputs = NULL;
+  group->bsp_specific_pin_count = group_definition->bsp_specific_pin_count;
+  if ( group->bsp_specific_pin_count > 0 ) {
+    group->bsp_speficifc_pins =
+                     group->bsp_specific_pin_count *
+                     sizeof(uint32_t)
+           group_definition->bsp_specifics,
+           group->bsp_specific_pin_count,
+           &group->bsp_specific_bank,
+      return sc;
+  else {
+    group->bsp_speficifc_pins = NULL;
+  /* Request the pins. */
+  sc = gpio_multi_select(
+         group_definition->input_count,
+         true
+         group_definition->output_count,
+         true
+    sc = rtems_gpio_release_multiple_pins(
+    assert ( sc == RTEMS_SUCCESSFUL );
+         group_definition->bsp_specific_pin_count,
+         true
+  /* Create group lock. */
+  sc = CREATE_LOCK(rtems_build_name('G', 'R', 'P', 'L'), &group->group_lock);
+    return sc;
+  rtems_chain_append(&gpio_group, &group->node);
+rtems_status_code rtems_gpio_write_group(uint32_t data, rtems_gpio_group *group)
+  rtems_status_code sc = RTEMS_SUCCESSFUL;
+  uint32_t set_bitmask;
+  uint32_t clear_bitmask;
+  uint32_t bank;
+  uint32_t pin;
+  uint8_t i;
+  if ( group->output_count == 0 ) {
+    return RTEMS_NOT_DEFINED;
+  bank = group->digital_output_bank;
+  /* Acquire bank lock for the digital output pins. */
+  /* Acquire group lock. */
+  ACQUIRE_LOCK(group->group_lock);
+  set_bitmask = 0;
+  clear_bitmask = 0;
+  for ( i = 0; i < group->output_count; ++i ) {
+    pin = group->digital_outputs[i];
+    if ( (data & (1 << i)) == 0 ) {
+      clear_bitmask |= (1 << pin);
+    else {
+      set_bitmask |= (1 << pin);
+  /* Set the logical highs. */
+  if ( set_bitmask > 0 ) {
+    sc = rtems_gpio_bsp_multi_set(bank, set_bitmask);
+      RELEASE_LOCK(group->group_lock);
+      return sc;
+  /* Set the logical lows. */
+  if ( clear_bitmask > 0 ) {
+    sc = rtems_gpio_bsp_multi_clear(bank, clear_bitmask);
+      return sc;
+uint32_t rtems_gpio_read_group(rtems_gpio_group *group)
+  uint32_t read_bitmask;
+  uint32_t bank;
+  uint32_t pin;
+  uint32_t rv;
+  uint8_t i;
+  if ( group->input_count == 0 ) {
+    return 0xDEADBEEF;
+  bank = group->digital_input_bank;
+  /* Acquire bank lock for the digital input pins. */
+  read_bitmask = 0;
+  for ( i = 0; i < group->input_count; ++i ) {
+    pin = group->digital_inputs[i];
+    read_bitmask |= (1 << pin);
+  rv = rtems_gpio_bsp_multi_read(bank, read_bitmask);
+  return rv;
+rtems_status_code rtems_gpio_group_bsp_specific_operation(
+  rtems_gpio_group *group,
+  void *arg
+  uint32_t bank;
+  if ( group->bsp_specific_pin_count == 0 ) {
+  bank = group->bsp_specific_bank;
+  /* Acquire bank lock for the BSP specific function pins. */
+  sc = rtems_gpio_bsp_specific_group_operation(
+         bank,
+         group->bsp_speficifc_pins,
+         arg
+  return sc;
+rtems_status_code rtems_gpio_multi_select(
+  uint8_t pin_count
+  return gpio_multi_select(pins, pin_count, false);
+rtems_status_code rtems_gpio_request_configuration(
+  const rtems_gpio_pin_conf *conf
+  sc = rtems_gpio_request_pin(
+         conf->pin_number,
+         conf->function,
+         conf->output_enabled,
+         conf->logic_invert,
+         conf->bsp_specific
+#if defined(DEBUG)
+    printk("rtems_gpio_request_pin failed with status code %d\n",sc);
+#endif
+  return setup_resistor_and_interrupt_configuration(
+           conf->pin_number,
+           conf->pull_mode,
+           conf->interrupt
+rtems_status_code rtems_gpio_update_configuration(
+  rtems_gpio_interrupt_configuration *interrupt_conf;
+  uint32_t bank;
+  if ( conf->pin_number < 0 || conf->pin_number >= BSP_GPIO_PIN_COUNT ) {
+  bank = BANK_NUMBER(conf->pin_number);
+  /* If the pin is not being used returns with an error. */
+  if ( gpio_pin_state[conf->pin_number].pin_function == NOT_USED ) {
+  sc = rtems_gpio_resistor_mode(conf->pin_number, conf->pull_mode);
+#if defined(DEBUG)
+#endif
+  interrupt_conf = (rtems_gpio_interrupt_configuration *) conf->interrupt;
+  interrupt_state = gpio_pin_state[conf->pin_number].interrupt_state;
+  if ( interrupt_state != NULL ) {
+    sc = rtems_gpio_disable_interrupt(conf->pin_number);
+#if defined(DEBUG)
+      printk(
+        "rtems_gpio_disable_interrupt failed with status code %d\n",
+        sc
+#endif
+           conf->pin_number,
+#if defined(DEBUG)
+      printk(
+        sc
+#endif
+  if ( interrupt_conf != NULL && interrupt_state != NULL ) {
+    if (
+        interrupt_conf->debounce_clock_tick_interval !=
+rtems_status_code rtems_gpio_multi_set(
+ uint32_t *pin_numbers,
+  uint32_t bitmask;
+  uint32_t bank;
+  sc = get_pin_bitmask(pin_numbers, pin_count, &bank, &bitmask, DIGITAL_OUTPUT);
+    return sc;
+  sc = rtems_gpio_bsp_multi_set(bank, bitmask);
+  return sc;
+rtems_status_code rtems_gpio_multi_clear(
+  uint32_t bitmask;
+  uint32_t bank;
+    return sc;
+  sc = rtems_gpio_bsp_multi_clear(bank, bitmask);
+  return sc;
+uint32_t rtems_gpio_multi_read(
+  uint32_t bitmask;
+  uint32_t bank;
+  uint32_t rv;
+  sc = get_pin_bitmask(pin_numbers, pin_count, &bank, &bitmask, DIGITAL_INPUT);
+  rv = rtems_gpio_bsp_multi_read(bank, bitmask);
+  return rv;
+rtems_status_code rtems_gpio_set(uint32_t pin_number)
+  uint32_t bank;
+  uint32_t pin;
+  if (
+      gpio_pin_state[pin_number].pin_function != DIGITAL_OUTPUT ||
+#if defined(DEBUG)
+    printk("Can only set digital output pins\n");
+#endif
+  if ( gpio_pin_state[pin_number].logic_invert ) {
+  else {
+  return sc;
+rtems_status_code rtems_gpio_clear(uint32_t pin_number)
+  uint32_t bank;
+  uint32_t pin;
+  if (
+#if defined(DEBUG)
+    printk("Can only clear digital output pins\n");
+#endif
+  else {
+  return sc;
+uint8_t rtems_gpio_get_value(uint32_t pin_number)
+  uint32_t bank;
+  uint32_t pin;
+  int rv;
+    return -1;
+  if (
+      gpio_pin_state[pin_number].pin_function != DIGITAL_INPUT ||
+#if defined(DEBUG)
+    printk("Can only read digital input pins\n");
+#endif
+    return -1;
+  rv = rtems_gpio_bsp_get_value(bank, pin);
+  if ( gpio_pin_state[pin_number].logic_invert && rv > 0 ) {
+    return !rv;
+  return ( rv > 0 ) ? 1 : rv;
+rtems_status_code rtems_gpio_request_pin(
+  rtems_gpio_function function,
+  bool output_enabled,
+  bool logic_invert,
+  void *bsp_specific
+  uint32_t bank;
+  uint32_t pin;
+  switch ( function ) {
+    case DIGITAL_INPUT:
+      sc = rtems_gpio_bsp_select_input(bank, pin, bsp_specific);
+      break;
+    case DIGITAL_OUTPUT:
+      sc = rtems_gpio_bsp_select_output(bank, pin, bsp_specific);
+      break;
+    case BSP_SPECIFIC:
+      bsp_data = (rtems_gpio_specific_data *) bsp_specific;
+      sc = rtems_bsp_select_specific_io(
+             bank,
+             pin,
+             bsp_data->io_function,
+             bsp_data->pin_data
+      break;
+    case NOT_USED:
+    default:
+    return sc;
+  /* If the function was successfully assigned to the pin,
+   * record that information on the gpio_pin_state structure. */
+  gpio_pin_state[pin_number].pin_function = function;
+  gpio_pin_state[pin_number].logic_invert = logic_invert;
+  if ( function == DIGITAL_OUTPUT ) {
+    if ( output_enabled == true ) {
+    else {
+  return sc;
+rtems_status_code rtems_gpio_resistor_mode(
+  rtems_gpio_pull_mode mode
+  uint32_t bank;
+  uint32_t pin;
+  /* If the desired actuation mode is already set, silently exits.
+   * The NO_PULL_RESISTOR is a special case, as some platforms have
+   * pull-up resistors enabled on startup, so this state may have to
+   * be reinforced in the hardware. */
+  if (
+      gpio_pin_state[pin_number].resistor_mode == mode &&
+      mode != NO_PULL_RESISTOR
+  sc = rtems_gpio_bsp_set_resistor_mode(bank, pin, mode);
+    return sc;
+  gpio_pin_state[pin_number].resistor_mode = mode;
+rtems_status_code rtems_gpio_release_pin(uint32_t pin_number)
+  uint32_t bank;
+  /* If the pin has an enabled interrupt then remove the handler(s)
+   * and disable interrupts on that pin. */
+    sc = rtems_gpio_disable_interrupt(pin_number);
+      return sc;
+  gpio_pin_state[pin_number].pin_function = NOT_USED;
+  gpio_pin_state[pin_number].resistor_mode = NO_PULL_RESISTOR;
+  gpio_pin_state[pin_number].logic_invert = false;
+  gpio_pin_state[pin_number].on_group = false;
+rtems_status_code rtems_gpio_release_configuration(
+  if ( conf == NULL ) {
+  return rtems_gpio_release_pin(conf->pin_number);
+rtems_status_code rtems_gpio_release_multiple_pins(
+  uint32_t i;
+  if ( pins == NULL ) {
+    sc = rtems_gpio_release_pin(pins[i].pin_number);
+      return sc;
+rtems_status_code rtems_gpio_release_pin_group(
+  uint8_t i;
+  sc = rtems_semaphore_flush(group->group_lock);
+    return sc;
+  /* Deletes the group lock. */
+  sc = rtems_semaphore_delete(group->group_lock);
+    return sc;
+  /* Pin releasing. */
+    sc = rtems_gpio_release_pin(group->digital_inputs[i]);
+      return sc;
+    free(group->digital_inputs);
+    sc = rtems_gpio_release_pin(group->digital_outputs[i]);
+      return sc;
+    free(group->digital_outputs);
+  for ( i = 0; i < group->bsp_specific_pin_count; ++i ) {
+    sc = rtems_gpio_release_pin(group->bsp_speficifc_pins[i]);
+      return sc;
+    free(group->bsp_speficifc_pins);
+  rtems_chain_extract(&group->node);
+  free(group);
+rtems_status_code rtems_gpio_debounce_switch(uint32_t pin_number, int ticks)
+  uint32_t bank;
+  /* If no interrupt configuration is set for this pin, or if the pin is
+   * not set as a digital input, or the pin in on a group. */
+  if (
+      interrupt_state == NULL ||
+  interrupt_state->debouncing_tick_count = ticks;
+rtems_status_code rtems_gpio_interrupt_handler_install(
+  rtems_gpio_irq_state (*handler) (void *arg),
+  void *arg
+  uint32_t bank;
+  /* If no interrupt configuration is set for this pin. */
+   if ( interrupt_state == NULL ) {
+  /* If the current pin has no interrupt enabled
+   * then it does not need an handler. */
+  if ( interrupt_state->active_interrupt == NONE ) {
+  /* If the pin already has an enabled interrupt but the installed handler
+   * is set as unique. */
+  else if (
+           interrupt_state->handler_flag == UNIQUE_HANDLER &&
+           !rtems_chain_is_empty(&interrupt_state->handler_chain)
+    return RTEMS_TOO_MANY;
+  /* Update the pin's ISR list. */
+  isr_node = (gpio_handler_node *) malloc(sizeof(gpio_handler_node));
+  if ( isr_node == NULL ) {
+    return RTEMS_NO_MEMORY;
+  isr_node->handler = handler;
+  isr_node->arg = arg;
+  rtems_chain_append(&interrupt_state->handler_chain, &isr_node->node);
+rtems_status_code rtems_gpio_enable_interrupt(
+  rtems_gpio_interrupt interrupt,
+  rtems_gpio_handler_flag flag,
+  bool threaded_handling,
+  void *arg
+  uint32_t bank;
+  uint32_t pin;
+  vector = rtems_gpio_bsp_get_vector(bank);
+  if (
+  /* If the bank already has at least one interrupt enabled on a pin,
+   * then new interrupts on this bank must follow the current
+   * threading policy. */
+  if (
+      gpio_bank_state[bank].interrupt_counter > 0 &&
+      gpio_bank_state[bank].threaded_interrupts != threaded_handling
+  /* If an interrupt configuration is already in place for this pin. */
+  gpio_pin_state[pin_number].interrupt_state =
+    (gpio_pin_interrupt_state *) malloc(sizeof(gpio_pin_interrupt_state));
+  if ( gpio_pin_state[pin_number].interrupt_state == NULL ) {
+  gpio_pin_state[pin_number].interrupt_state->active_interrupt = NONE;
+  gpio_pin_state[pin_number].interrupt_state->debouncing_tick_count = 0;
+  gpio_pin_state[pin_number].interrupt_state->last_isr_tick = 0;
+    &gpio_pin_state[pin_number].interrupt_state->handler_chain
+  interrupt_state->active_interrupt = interrupt;
+  interrupt_state->handler_flag = flag;
+  /* Installs the interrupt handler on the GPIO pin
+   * tracking structure. */
+  sc = rtems_gpio_interrupt_handler_install(pin_number, handler, arg);
+  if ( threaded_handling ) {
+    if (
+        _Atomic_Load_uint(&threaded_interrupt_counter, ATOMIC_ORDER_RELAXED) == 0
+      sc = rtems_interrupt_server_initialize(
+             INTERRUPT_SERVER_PRIORITY,
+             INTERRUPT_SERVER_STACK_SIZE,
+             INTERRUPT_SERVER_MODES,
+             INTERRUPT_SERVER_ATTRIBUTES,
+             NULL
+    if ( gpio_bank_state[bank].interrupt_counter == 0 ) {
+      sc = rtems_interrupt_server_handler_install(
+             RTEMS_ID_NONE,
+             vector,
+             "GPIO_HANDLER",
+             RTEMS_INTERRUPT_UNIQUE,
+             (rtems_interrupt_handler) generic_bank_isr,
+             &gpio_bank_state[bank].bank_number
+      _Atomic_Fetch_add_uint(
+        &threaded_interrupt_counter,
+        1,
+        ATOMIC_ORDER_RELAXED
+  else if ( gpio_bank_state[bank].interrupt_counter == 0 ) {
+    sc = rtems_interrupt_handler_install(
+           vector,
+           "GPIO_HANDLER",
+  sc = rtems_bsp_enable_interrupt(bank, pin, interrupt);
+  /* If this was the first interrupt enabled on this GPIO bank,
+   * record the threading policy. */
+    gpio_bank_state[bank].threaded_interrupts = threaded_handling;
+  ++gpio_bank_state[bank].interrupt_counter;
+rtems_status_code rtems_gpio_interrupt_handler_remove(
+  void *arg
+  uint32_t bank;
+  /* If the first node is also the last handler for this pin, disables
+   * interrupts on this pin as there will be no handler to handle it.
+   * This also removes the remaining handler. */
+  if ( rtems_chain_is_last(node) ) {
+    return rtems_gpio_disable_interrupt(pin_number);
+    if ( isr_node->handler == handler && isr_node->arg == arg ) {
+      rtems_chain_extract(node);
+      break;
+    node = next_node;
+rtems_status_code rtems_gpio_disable_interrupt(uint32_t pin_number)
+  uint32_t bank;
+  uint32_t pin;
+  sc = rtems_bsp_disable_interrupt(bank, pin, interrupt_state->active_interrupt);
+  interrupt_state->active_interrupt = NONE;
+    node = next_node;
+  /* If this is the last GPIO interrupt are left in this bank,
+   * removes the handler. */
+  if ( gpio_bank_state[bank].interrupt_counter == 1 ) {
+    if ( gpio_bank_state[bank].threaded_interrupts ) {
+      sc = rtems_interrupt_server_handler_remove(
+             RTEMS_ID_NONE,
+             vector,
+    else {
+      sc = rtems_interrupt_handler_remove(
+             vector,
+  /* Free the pin's interrupt state structure. */
+  free(interrupt_state);
+  --gpio_bank_state[bank].interrupt_counter;
+    _Atomic_Fetch_sub_uint(&threaded_interrupt_counter, 1, ATOMIC_ORDER_RELAXED);
diff --git a/c/src/lib/libbsp/shared/include/gpio.h b/c/src/lib/libbsp/shared/include/gpio.h
index 0000000..b2deb1e
--- /dev/null
+++ b/c/src/lib/libbsp/shared/include/gpio.h
@@ -0,0 +1,948 @@
+ * @file gpio.h
+ * @brief RTEMS GPIO API definition.
+#ifndef LIBBSP_SHARED_GPIO_H
+#define LIBBSP_SHARED_GPIO_H
+#include <bsp.h>
+#include <rtems.h>
+#ifdef __cplusplus
+extern "C" {
+#endif /* __cplusplus */
+#if !defined(BSP_GPIO_PIN_COUNT) || !defined(BSP_GPIO_PINS_PER_BANK)
+  #error "BSP_GPIO_PIN_COUNT or BSP_GPIO_PINS_PER_BANK is not defined."
+#endif
+#if BSP_GPIO_PIN_COUNT <= 0 || BSP_GPIO_PINS_PER_BANK <= 0
+  #error "Invalid BSP_GPIO_PIN_COUNT or BSP_GPIO_PINS_PER_BANK."
+#endif
+#if BSP_GPIO_PINS_PER_BANK > 32
+  #error "Invalid BSP_GPIO_PINS_PER_BANK. Must be in the range of 1 to 32."
+#endif
+#define GPIO_LAST_BANK_PINS BSP_GPIO_PIN_COUNT % BSP_GPIO_PINS_PER_BANK
+#if GPIO_LAST_BANK_PINS > 0
+  #define GPIO_BANK_COUNT (BSP_GPIO_PIN_COUNT / BSP_GPIO_PINS_PER_BANK) + 1
+#else
+  #define GPIO_BANK_COUNT BSP_GPIO_PIN_COUNT / BSP_GPIO_PINS_PER_BANK
+  #define GPIO_LAST_BANK_PINS BSP_GPIO_PINS_PER_BANK
+#endif
+#if defined(BSP_GPIO_PINS_PER_SELECT_BANK) && BSP_GPIO_PINS_PER_SELECT_BANK > 32
+  #error "Invalid BSP_GPIO_PINS_PER_SELECT_BANK. Must under and including 32."
+#elif defined(BSP_GPIO_PINS_PER_SELECT_BANK) <= 32
+  #define GPIO_SELECT_BANK_COUNT \
+    BSP_GPIO_PINS_PER_BANK / BSP_GPIO_PINS_PER_SELECT_BANK
+#endif
+#define INTERRUPT_SERVER_PRIORITY 1
+#define INTERRUPT_SERVER_STACK_SIZE 2 * RTEMS_MINIMUM_STACK_SIZE
+#define INTERRUPT_SERVER_MODES RTEMS_TIMESLICE | RTEMS_PREEMPT
+#define INTERRUPT_SERVER_ATTRIBUTES RTEMS_DEFAULT_ATTRIBUTES
+ * @name GPIO data structures
+ * @brief The set of possible configurations for a GPIO pull-up resistor.
+ * Enumerated type to define the possible pull-up resistor configurations
+ * for a GPIO pin.
+typedef enum
+  PULL_UP = 1,
+  PULL_DOWN,
+  NO_PULL_RESISTOR
+} rtems_gpio_pull_mode;
+ * @brief The set of possible functions a pin can have.
+ * Enumerated type to define a pin function.
+typedef enum
+  DIGITAL_INPUT = 0,
+  DIGITAL_OUTPUT,
+  BSP_SPECIFIC,
+  NOT_USED
+} rtems_gpio_function;
+ * @brief The set of possible interrupts a GPIO pin can generate.
+ * Enumerated type to define a GPIO pin interrupt.
+typedef enum
+  FALLING_EDGE = 0,
+  RISING_EDGE,
+  LOW_LEVEL,
+  HIGH_LEVEL,
+  BOTH_EDGES,
+  BOTH_LEVELS,
+  NONE
+} rtems_gpio_interrupt;
+ * @brief The set of possible handled states an user-defined interrupt
+ *        handler can return.
+ * Enumerated type to define an interrupt handler handled state.
+typedef enum
+  IRQ_HANDLED,
+  IRQ_NONE
+} rtems_gpio_irq_state;
+ * @brief The set of flags to specify an user-defined interrupt handler
+ *        uniqueness on a GPIO pin.
+ * Enumerated type to define an interrupt handler shared flag.
+typedef enum
+  SHARED_HANDLER,
+  UNIQUE_HANDLER
+} rtems_gpio_handler_flag;
+ * @brief Object containing relevant information for assigning a BSP specific
+ *        function to a pin.
+ * Encapsulates relevant data for a BSP specific GPIO function.
+typedef struct
+  /* The BSP defined function code. */
+  uint32_t io_function;
+  void *pin_data;
+} rtems_gpio_specific_data;
+ * @brief Object containing configuration information
+ *        regarding interrupts.
+typedef struct
+  /* Interrupt handler function. */
+  /* Interrupt handler function arguments. */
+  void *arg;
+  /* Software switch debounce settings. It should contain the amount of clock
+   * ticks that must pass between interrupts to ensure that the interrupt
+   * was not caused by a switch bounce.
+   * If set to 0 this feature is disabled . */
+  uint32_t debounce_clock_tick_interval;
+} rtems_gpio_interrupt_configuration;
+ *        to request/update a GPIO pin.
+typedef struct
+  /* Processor pin number. */
+  rtems_gpio_function function;
+  /* Pull resistor setting. */
+  rtems_gpio_pull_mode pull_mode;
+  /* If digital out pin, set to TRUE to set the pin to logical high,
+   * or FALSE for logical low. If not a digital out then this
+   * is ignored. */
+  bool output_enabled;
+  /* Pin interrupt configuration. Should be NULL if not used. */
+  rtems_gpio_interrupt_configuration *interrupt;
+  /* Structure with BSP specific data, to use during the pin request.
+   * If function == BSP_SPECIFIC this should have a pointer to
+   * a rtems_gpio_specific_data structure.
+   * If not this field may be NULL. This is passed to the BSP function
+   * so any BSP specific data can be passed to it through this pointer. */
+  void *bsp_specific;
+} rtems_gpio_pin_conf;
+ *        to assign GPIO functions to multiple pins
+ *        at the same time. To be used by BSP code only.
+typedef struct
+  /* Global GPIO pin number. */
+  /* RTEMS GPIO pin function code. */
+  /* BSP specific function code. Only used if function == BSP_SPECIFIC */
+  /* BSP specific data. */
+} rtems_gpio_multiple_pin_select;
+ *        to request a GPIO pin group.
+typedef struct
+  const rtems_gpio_pin_conf *digital_inputs;
+  const rtems_gpio_pin_conf *digital_outputs;
+  const rtems_gpio_pin_conf *bsp_specifics;
+} rtems_gpio_group_definition;
+ * @brief Opaque type for a GPIO pin group.
+typedef struct rtems_gpio_group rtems_gpio_group;
+ * @name gpio Usage
+ * @brief Initializes the GPIO API.
+ * @retval RTEMS_SUCCESSFUL API successfully initialized.
+ * @retval * @see rtems_semaphore_create().
+extern rtems_status_code rtems_gpio_initialize(void);
+ * @brief Instantiates a GPIO pin group.
+ *        To define the group @see rtems_gpio_define_pin_group().
+ * @retval rtems_gpio_group pointer.
+extern rtems_gpio_group *rtems_gpio_create_pin_group(void);
+ * @brief Requests a GPIO pin group configuration.
+ * @param[in] group_definition rtems_gpio_group_definition structure filled with
+ *                             the group pins configurations.
+ * @param[out] group Reference to the created group.
+ * @retval RTEMS_SUCCESSFUL Pin group was configured successfully.
+ * @retval RTEMS_UNSATISFIED @var group_definition or @var group is NULL,
+ *                           the @var pins are not from the same bank,
+ *                           no pins were defined or could not satisfy at
+ *                           least one given configuration.
+ * @retval RTEMS_RESOURCE_IN_USE At least one pin is already being used.
+extern rtems_status_code rtems_gpio_define_pin_group(
+ * @brief Writes a value to the group's digital outputs. The pins order
+ *        is as defined in the group definition.
+ * @param[in] data Data to write/send.
+ * @param[in] group Reference to the group.
+ * @retval RTEMS_SUCCESSFUL Data successfully written.
+ * @retval RTEMS_NOT_DEFINED Group has no output pins.
+ * @retval RTEMS_UNSATISFIED Could not operate on at least one of the pins.
+extern rtems_status_code rtems_gpio_write_group(
+  uint32_t data,
+ * @brief Reads the value/level of the group's digital inputs. The pins order
+ * @retval The function returns a 32-bit bitmask with the group's input pins
+ *         current logical values.
+ * @retval 0xDEADBEEF Group has no input pins.
+extern uint32_t rtems_gpio_read_group(rtems_gpio_group *group);
+ * @brief Performs a BSP specific operation on a group of pins. The pins order
+ * @param[in] arg Pointer to a BSP defined structure with BSP-specific
+ *                data. This field is handled by the BSP.
+ * @retval RTEMS_SUCCESSFUL Operation completed with success.
+ * @retval RTEMS_NOT_DEFINED Group has no BSP specific pins, or the BSP does not
+ *                           support BSP specific operations for groups.
+extern rtems_status_code rtems_gpio_group_bsp_specific_operation(
+  void *arg
+ * @brief Requests a GPIO pin configuration.
+ * @param[in] conf rtems_gpio_pin_conf structure filled with the pin information
+ *                 and desired configurations.
+ * @retval RTEMS_SUCCESSFUL Pin was configured successfully.
+ * @retval RTEMS_UNSATISFIED Could not satisfy the given configuration.
+extern rtems_status_code rtems_gpio_request_configuration(
+ * @brief Updates the current configuration of a GPIO pin .
+ * @retval RTEMS_SUCCESSFUL Pin configuration was updated successfully.
+ * @retval RTEMS_INVALID_ID Pin number is invalid.
+ * @retval RTEMS_NOT_CONFIGURED The pin is not being used.
+ * @retval RTEMS_UNSATISFIED Could not update the pin's configuration.
+extern rtems_status_code rtems_gpio_update_configuration(
+ * @brief Sets multiple output GPIO pins with the logical high.
+ * @param[in] pin_numbers Array with the GPIO pin numbers to set.
+ * @param[in] count Number of GPIO pins to set.
+ * @retval RTEMS_SUCCESSFUL All pins were set successfully.
+ * @retval RTEMS_INVALID_ID At least one pin number is invalid.
+ * @retval RTEMS_NOT_CONFIGURED At least one of the received pins
+ *                              is not configured as a digital output.
+ * @retval RTEMS_UNSATISFIED Could not set the GPIO pins.
+extern rtems_status_code rtems_gpio_multi_set(
+ * @brief Sets multiple output GPIO pins with the logical low.
+ * @param[in] pin_numbers Array with the GPIO pin numbers to clear.
+ * @param[in] count Number of GPIO pins to clear.
+ * @retval RTEMS_SUCCESSFUL All pins were cleared successfully.
+ * @retval RTEMS_UNSATISFIED Could not clear the GPIO pins.
+extern rtems_status_code rtems_gpio_multi_clear(
+ * @brief Returns the value (level) of multiple GPIO input pins.
+ * @param[in] pin_numbers Array with the GPIO pin numbers to read.
+ * @param[in] count Number of GPIO pins to read.
+ * @retval Bitmask with the values of the corresponding pins.
+ *         0 for logical low and 1 for logical high.
+ * @retval 0xDEADBEEF Could not read at least one pin level.
+extern uint32_t rtems_gpio_multi_read(
+ * @brief Sets an output GPIO pin with the logical high.
+ * @param[in] pin_number GPIO pin number.
+ * @retval RTEMS_SUCCESSFUL Pin was set successfully.
+ * @retval RTEMS_NOT_CONFIGURED The received pin is not configured
+ *                              as a digital output.
+ * @retval RTEMS_UNSATISFIED Could not set the GPIO pin.
+extern rtems_status_code rtems_gpio_set(uint32_t pin_number);
+ * @brief Sets an output GPIO pin with the logical low.
+ * @retval RTEMS_SUCCESSFUL Pin was cleared successfully.
+ * @retval RTEMS_UNSATISFIED Could not clear the GPIO pin.
+extern rtems_status_code rtems_gpio_clear(uint32_t pin_number);
+ * @brief Returns the value (level) of a GPIO input pin.
+ * @retval The function returns 0 or 1 depending on the pin current
+ *         logical value.
+ * @retval -1 Pin number is invalid, or not a digital input pin.
+extern uint8_t rtems_gpio_get_value(uint32_t pin_number);
+ * @brief Requests multiple GPIO pin configurations. If the BSP provides
+ *        support for parallel selection each call to this function will
+ *        result in a single call to the GPIO hardware, else each pin
+ *        configuration will be done in individual and sequential calls.
+ *        All pins must belong to the same GPIO bank.
+ * @param[in] pins Array of rtems_gpio_pin_conf structures filled with the pins
+ *                 information and desired configurations. All pins must belong
+ *                 to the same GPIO bank.
+ * @param[in] pin_count Number of pin configurations in the @var pins array.
+ * @retval RTEMS_SUCCESSFUL All pins were configured successfully.
+ * @retval RTEMS_INVALID_ID At least one pin number in the @var pins array
+ *                          is invalid.
+ * @retval RTEMS_UNSATISFIED Could not satisfy at least one given configuration.
+extern rtems_status_code rtems_gpio_multi_select(
+  uint8_t pin_count
+ * @brief Assigns a certain function to a GPIO pin.
+ * @param[in] function The new function for the pin.
+ * @param[in] output_enabled If TRUE and @var function is DIGITAL_OUTPUT,
+ *                           then the pin is set with the logical high.
+ *                           Otherwise it is set with logical low.
+ * @param[in] logic_invert Reverses the digital I/O logic for DIGITAL_INPUT
+ *                         and DIGITAL_OUTPUT pins.
+ * @param[in] bsp_specific Pointer to a BSP defined structure with BSP-specific
+ * @retval RTEMS_RESOURCE_IN_USE The received pin is already being used.
+ * @retval RTEMS_UNSATISFIED Could not assign the GPIO function.
+ * @retval RTEMS_NOT_DEFINED GPIO function not defined, or NOT_USED.
+extern rtems_status_code rtems_gpio_request_pin(
+  bool output_enable,
+ * @brief Configures a single GPIO pin pull resistor.
+ * @param[in] mode The pull resistor mode.
+ * @retval RTEMS_SUCCESSFUL Pull resistor successfully configured.
+ * @retval RTEMS_UNSATISFIED Could not set the pull mode.
+extern rtems_status_code rtems_gpio_resistor_mode(
+ * @brief Releases a GPIO pin, making it available to be used again.
+ * @retval RTEMS_SUCCESSFUL Pin successfully disabled.
+ * @retval * Could not disable an active interrupt on this pin,
+ *           @see rtems_gpio_disable_interrupt().
+extern rtems_status_code rtems_gpio_release_pin(uint32_t pin_number);
+ * @param[in] conf GPIO pin configuration to be released.
+ * @retval RTEMS_UNSATISFIED Pin configuration is NULL.
+ * @retval * @see rtems_gpio_release_pin().
+extern rtems_status_code rtems_gpio_release_configuration(
+ * @brief Releases multiple GPIO pins, making them available to be used again.
+ * @param[in] pins Array of rtems_gpio_pin_conf structures.
+ * @retval RTEMS_SUCCESSFUL Pins successfully disabled.
+ * @retval RTEMS_UNSATISFIED @var pins array is NULL.
+extern rtems_status_code rtems_gpio_release_multiple_pins(
+ * @brief Releases a GPIO pin group, making the pins used available to be
+ *        repurposed.
+ * @retval * @see rtems_gpio_release_pin(), @see rtems_semaphore_delete() or
+ *           @see rtems_semaphore_flush().
+extern rtems_status_code rtems_gpio_release_pin_group(
+ * @brief Attaches a debouncing function to a given pin/switch.
+ *        Debouncing is done by requiring a certain number of clock ticks to
+ *        pass between interrupts. Any interrupt fired too close to the last
+ *        will be ignored as it is probably the result of an involuntary
+ *        switch/button bounce after being released.
+ * @param[in] ticks Minimum number of clock ticks that must pass between
+ *                  interrupts so it can be considered a legitimate
+ *                  interrupt.
+ * @retval RTEMS_SUCCESSFUL Debounce function successfully attached to the pin.
+ * @retval RTEMS_NOT_CONFIGURED The current pin is not configured as a digital
+ *                              input, hence it can not be connected to a switch,
+ *                              or interrupts are not enabled for this pin.
+extern rtems_status_code rtems_gpio_debounce_switch(
+  int ticks
+ * @brief Connects a new user-defined interrupt handler to a given pin.
+ * @param[in] handler Pointer to a function that will be called every time
+ *                    the enabled interrupt for the given pin is generated.
+ *                    This function must return information about its
+ *                    handled/unhandled state.
+ * @param[in] arg Void pointer to the arguments of the user-defined handler.
+ * @retval RTEMS_SUCCESSFUL Handler successfully connected to this pin.
+ * @retval RTEMS_NO_MEMORY Could not connect more user-defined handlers to
+ *                         the given pin.
+ * @retval RTEMS_NOT_CONFIGURED The given pin has no interrupt configured.
+ * @retval RTEMS_TOO_MANY The pin's current handler is set as unique.
+ * @retval RTEMS_RESOURCE_IN_USE The current user-defined handler for this pin
+ *                               is unique.
+extern rtems_status_code rtems_gpio_interrupt_handler_install(
+  void *arg
+ * @brief Enables interrupts to be generated on a given GPIO pin.
+ *        When fired that interrupt will call the given handler.
+ * @param[in] interrupt Type of interrupt to enable for the pin.
+ * @param[in] flag Defines the uniqueness of the interrupt handler for the pin.
+ * @param[in] threaded_handling Defines if the handler should be called from a
+ *                              thread/task or from normal ISR contex.
+ *                    @var interrupt is generated. This function must return
+ *                    information about its handled/unhandled state.
+ * @retval RTEMS_SUCCESSFUL Interrupt successfully enabled for this pin.
+ * @retval RTEMS_UNSATISFIED Could not install the GPIO ISR, create/start
+ *                           the handler task, or enable the interrupt
+ *                           on the pin.
+ *                              as a digital input, the pin is on a
+ *                              pin grouping.
+ * @retval RTEMS_RESOURCE_IN_USE The pin already has an enabled interrupt,
+ *                               or the handler threading policy does not match
+ *                               the bank's policy.
+ * @retval RTEMS_NO_MEMORY Could not store the pin's interrupt configuration.
+extern rtems_status_code rtems_gpio_enable_interrupt(
+  void *arg
+ * @brief Disconnects an user-defined interrupt handler from the given pin.
+ *        If in the end there are no more user-defined handlers connected
+ *        to the pin, interrupts are disabled on the given pin.
+ * @param[in] handler Pointer to the user-defined handler
+ * @retval RTEMS_SUCCESSFUL Handler successfully disconnected from this pin.
+ * @retval RTEMS_NOT_CONFIGURED Pin has no active interrupts.
+ * @retval * @see rtems_gpio_disable_interrupt()
+extern rtems_status_code rtems_gpio_interrupt_handler_remove(
+  void *arg
+ * @brief Stops interrupts from being generated on a given GPIO pin
+ *        and removes the corresponding handler.
+ * @retval RTEMS_SUCCESSFUL Interrupt successfully disabled for this pin.
+ * @retval RTEMS_UNSATISFIED Could not remove the current interrupt handler,
+ *                           could not recognize the current active interrupt
+ *                           on this pin or could not disable interrupts on
+ *                           this pin.
+extern rtems_status_code rtems_gpio_disable_interrupt(uint32_t pin_number);
+ *        This must be implemented by each BSP.
+ * @param[in] bank GPIO bank number.
+ * @param[in] bitmask Bitmask of GPIO pins to set in the given bank.
+ * @retval RTEMS_UNSATISFIED Could not set at least one of the pins.
+extern rtems_status_code rtems_gpio_bsp_multi_set(
+  uint32_t bank,
+  uint32_t bitmask
+ * @param[in] bitmask Bitmask of GPIO pins to clear in the given bank.
+ * @retval RTEMS_UNSATISFIED Could not clear at least one of the pins.
+extern rtems_status_code rtems_gpio_bsp_multi_clear(
+  uint32_t bank,
+  uint32_t bitmask
+ * @param[in] bitmask Bitmask of GPIO pins to read in the given bank.
+ * @retval The function must return a bitmask with the values of the
+ *         corresponding pins. 0 for logical low and 1 for logical high.
+extern uint32_t rtems_gpio_bsp_multi_read(uint32_t bank, uint32_t bitmask);
+ *        The implementation for this function may be omitted if the target
+ *        does not support the feature, by returning RTEMS_NOT_DEFINED.
+ * @retval RTEMS_NOT_DEFINED The BSP does not support BSP specific operations
+ *                           for groups.
+extern rtems_status_code rtems_gpio_bsp_specific_group_operation(
+  uint32_t bank,
+  uint32_t *pins,
+  void *arg
+ * @brief Assigns GPIO functions to all the given pins in a single register
+ *        operation.
+ * @param[in] pins Array of rtems_gpio_multiple_pin_select structures filled
+ *                 with the pins desired functions. All pins belong to the
+ *                 same select bank.
+ * @param[in] select_bank Select bank number of the received pins.
+ * @retval RTEMS_SUCCESSFUL Functions were assigned successfully.
+ * @retval RTEMS_NOT_DEFINED The BSP does not support multiple pin function
+ *                           assignment.
+ * @retval RTEMS_UNSATISFIED Could not assign the functions to the pins.
+extern rtems_status_code rtems_gpio_bsp_multi_select(
+  rtems_gpio_multiple_pin_select *pins,
+ * @param[in] pin GPIO pin number within the given bank.
+ * @retval RTEMS_UNSATISFIED Could not set the given pin.
+extern rtems_status_code rtems_gpio_bsp_set(uint32_t bank, uint32_t pin);
+ * @retval RTEMS_UNSATISFIED Could not clear the given pin.
+extern rtems_status_code rtems_gpio_bsp_clear(uint32_t bank, uint32_t pin);
+ * @retval The function must return 0 or 1 depending on the pin current
+ *         logical value.
+ * @retval -1 Could not read the pin level.
+extern uint8_t rtems_gpio_bsp_get_value(uint32_t bank, uint32_t pin);
+ * @brief Assigns the digital input function to the given pin.
+ *                         data.
+ * @retval RTEMS_SUCCESSFUL Function was assigned successfully.
+ * @retval RTEMS_UNSATISFIED Could not assign the function to the pin.
+extern rtems_status_code rtems_gpio_bsp_select_input(
+  uint32_t bank,
+  uint32_t pin,
+ * @brief Assigns the digital output function to the given pin.
+ *                         data.
+extern rtems_status_code rtems_gpio_bsp_select_output(
+  uint32_t bank,
+  uint32_t pin,
+ * @brief Assigns a BSP specific function to the given pin.
+ * @param[in] function BSP defined GPIO function.
+ * @param[in] pin_data Pointer to a BSP defined structure with BSP-specific
+ *                     data.
+extern rtems_status_code rtems_bsp_select_specific_io(
+  uint32_t bank,
+  uint32_t pin,
+  uint32_t function,
+  void *pin_data
+extern rtems_status_code rtems_gpio_bsp_set_resistor_mode(
+  uint32_t bank,
+  uint32_t pin,
+ * @brief Reads and returns a vector/bank interrupt event line.
+ *        The bitmask should indicate with a 1 if the corresponding pin
+ *        as a pending interrupt, or 0 if otherwise. The function
+ *        should clear the interrupt event line before returning.
+ * @param[in] vector GPIO vector/bank.
+ * @retval Bitmask (max 32-bit) representing a GPIO bank, where a bit set
+ *         indicates an active interrupt on that pin.
+extern uint32_t rtems_gpio_bsp_interrupt_line(rtems_vector_number vector);
+ * @brief Calculates a vector number for a given GPIO bank.
+ * @retval The corresponding rtems_vector_number.
+extern rtems_vector_number rtems_gpio_bsp_get_vector(uint32_t bank);
+ * @retval RTEMS_UNSATISFIED Could not enable the interrupt on the pin.
+extern rtems_status_code rtems_bsp_enable_interrupt(
+  uint32_t bank,
+  uint32_t pin,
+ * @brief Stops interrupts from being generated on a given GPIO pin.
+ * @param[in] active_interrupt Interrupt type currently active on this pin.
+ * @retval RTEMS_UNSATISFIED Could not disable interrupts on this pin.
+extern rtems_status_code rtems_bsp_disable_interrupt(
+  uint32_t bank,
+  uint32_t pin,
+#ifdef __cplusplus
+#endif /* LIBBSP_SHARED_GPIO_H */
2.3.6
