[PATCH] [RTEMS] Add <sys/lock.h>
Tue Jul 28 06:39:57 UTC 2015
----- Chris Johns <chrisj at rtems.org> schrieb:
> On 28/07/2015 5:51 am, Joel Sherrill wrote:
> > This file is RTEMS specific and I am OK with it.
> Do we have tests in RTEMS for this new API ?
> This is a new API to RTEMS even if it is viewed as "internal" and the
> RTEMS project should treat it like any other of the APIs it supports, ie
> tests and documentation.
This is fully tested in test sptests/spsyslock01, see for example:
https://lists.rtems.org/pipermail/devel/2015-July/012004.html
In terms of documentation, where would you add it?  Most functions are
pretty self explanatory (e.g. _Semaphore_Post(), _Mutex_Acquire(), etc.)
and do what they are expected to do usually.  All of them have a simple
implementation.
> > Sebastian is about to go on holiday so it would be appreciated
> > to get this approved before he leaves.
> > OK to commit?
> Should we resolve the testing and documentation first ?
Since testing and documentation will be contained in RTEMS I would
really appreciate if we can commit this Newlib patch first since RTEMS
and GCC patches depend on it.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
