[PATCH] GSoC: Cache configurations Raspberry Pi 2 support
Tue Jul 28 06:57:44 UTC 2015
On 24/07/15 21:55, Rohini Kulkarni wrote:
> Hi,
> I have attached the report containing outputs of arm-rtems4.11-size
> and arm-rtems4.11-nm -S.
> From arm-rtems4.11-nm -S I don't see how memset() is accessing .text
> section. The start and end values for both are not overlapping.
Maybe this patch helps:
diff --git a/c/src/lib/libbsp/arm/raspberrypi/startup/linkcmds
b/c/src/lib/libbsp/arm/raspberrypi/startup/linkcmds
index f1ad11c..f3b6232 100644
--- a/c/src/lib/libbsp/arm/raspberrypi/startup/linkcmds
+++ b/c/src/lib/libbsp/arm/raspberrypi/startup/linkcmds
@@ -62,7 +62,8 @@ REGION_ALIAS ("REGION_NOCACHE_LOAD", RAM);
  bsp_stack_irq_size = DEFINED (bsp_stack_irq_size) ? bsp_stack_irq_size
: 4096;
  bsp_stack_abt_size = DEFINED (bsp_stack_abt_size) ? bsp_stack_abt_size
: 1024;
-bsp_section_robarrier_align = DEFINED (bsp_section_robarrier_align) ?
bsp_section_robarrier_align : 1M;
+bsp_section_rwbarrier_align = DEFINED (bsp_section_rwbarrier_align) ?
bsp_section_rwbarrier_align : 1M;
  bsp_translation_table_base = ORIGIN (RAM_MMU);
  INCLUDE linkcmds.armv4
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
