Nice surprise with C++11
Daniel Gutson
daniel.gutson at tallertechnologies.com
Thu Jul 30 14:31:15 UTC 2015
El 30/7/2015 11:27, "Joel Sherrill" <joel.sherrill at oarcorp.com> escribió:
> On 7/30/2015 9:08 AM, Daniel Gutson wrote:
>> IOW, I think that the double parens is only for decltype.
> Historical convention is to put parens around variable names
> in macros. What type of impact does this have?
If what I think is correct, then the impact os none since this a bug. But I
will look at it deeper once I arrive to the office in 1h. I will try with
different versions of gcc and clang and look into the C++ standard. So far
the (()) seems to be a decltype only thing, so this would be a frontend bug.
>> El 30/7/2015 11:06, escribió:
>> I don't it's a language issue: https://ideone.com/k1vz5d
>> El 30/7/2015 10:51, "Gedare Bloom" <gedare at gwu.edu <mailto:
gedare at gwu.edu>> escribió:
>> OK, I guess this makes the convention "minimize parentheses"
mandatory
>> if we want C++11. I guess the basic problem is that constructions
>> where a single atom is in parens may produce different results
now. At
>> least an error is emitted rather than silent optimization..
>> -Gedare
>> On Thu, Jul 30, 2015 at 2:49 AM, Sebastian Huber
>> <sebastian.huber at embedded-brains.de <mailto:
sebastian.huber at embedded-brains.de>> wrote:
>> > Hello,
>> > please have a look at the following bug:
>> > https://gcc.gnu.org/bugzilla/show_bug.cgi?id=67064
>> > This is really nice in combination with defines and macros
that use ( ) to
>> > make sure the content stays together.
>> > Sebastian Huber, embedded brains GmbH
>> > Address : Dornierstr. 4, D-82178 Puchheim, Germany
>> > Phone : +49 89 189 47 41-16
>> > Fax : +49 89 189 47 41-09
>> > E-Mail : sebastian.huber at embedded-brains.de <mailto:
>> > PGP : Public key available on request.
>> > Diese Nachricht ist keine geschäftliche Mitteilung im Sinne
des EHUG.
>> > _______________________________________________
>> > devel mailing list
>> > devel at rtems.org <mailto:devel at rtems.org>
>> > http://lists.rtems.org/mailman/listinfo/devel
>> devel mailing list
> Joel Sherrill, Ph.D. Director of Research & Development
> joel.sherrill at OARcorp.com On-Line Applications Research
> Ask me about RTEMS: a free RTOS Huntsville AL 35805
> Support Available (256) 722-9985
URL: <http://lists.rtems.org/pipermail/devel/attachments/20150730/a2d7975d/attachment-0001.html>
