Nice surprise with C++11
Daniel Gutson
daniel.gutson at tallertechnologies.com
Fri Jul 31 12:51:00 UTC 2015
El 31/7/2015 2:37, "Sebastian Huber" <sebastian.huber at embedded-brains.de>
escribió:
> Hello Daniel,
Hello Sebastian.
> On 30/07/15 17:26, Daniel Gutson wrote:
>> On Thu, Jul 30, 2015 at 11:31 AM, Daniel Gutson
>> <daniel.gutson at tallertechnologies.com> wrote:
>>> >El 30/7/2015 11:27, "Joel Sherrill"<joel.sherrill at oarcorp.com>
escribió:
>>>> >>On 7/30/2015 9:08 AM, Daniel Gutson wrote:
>>>>> >>>IOW, I think that the double parens is only for decltype.
>>>> >>Historical convention is to put parens around variable names
>>>> >>in macros. What type of impact does this have?
>>> >If what I think is correct, then the impact os none since this a bug.
But I
>>> >will look at it deeper once I arrive to the office in 1h. I will try
with
>>> >different versions of gcc and clang and look into the C++ standard. So
far
>>> >the (()) seems to be a decltype only thing, so this would be a
frontend bug.
>> As I mentioned in the bugzilla, I think this is a bug of the front-end
>> (since I could not reproduce
>> it in earlier versions of g++ (4.8.4) and clang (3.5)). I already
>> asked Ville Voutilainen and Jens Maurer
>> (from the C++ Committee) to look into it. I will let you know.
> thanks for looking at this issue. Is this really a problem within the
scope of the standard?
The bug has been introduced when implementing the new rules related to
decltype in C++14. Indeed the code has something like 'if (cxxversion <
CPP14) return;' meaning that the newly (faulty) introduced code is not
executed when running previous std versions: that's why -std=c++11 should
work (the problem is that g++ 6 defaults to c++14).
>The global register variables are GCC specific.
Yes, a GNU C extension.
> Is it possible to construct objects without an address via plain C++?
Sorry I don't understand the question. Rephrase please?
Global objects and objects of static storage duration don't take an address.
> Phone : +49 89 189 47 41-16
> Fax : +49 89 189 47 41-09
URL: <http://lists.rtems.org/pipermail/devel/attachments/20150731/e35b4217/attachment.html>
