GSoC 2015 RPi USB Support
Wed Jul 8 19:28:41 UTC 2015
Did you build the tests of libbsd for the xilinx_zynq_a9_qemu?  Did you run and debug the telnetd01 test in Qemu to see how the device tree initialization works?
----- Yurii Shevtsov <ungetch at gmail.com> schrieb:
> ping
> 2015-07-01 17:20 GMT+03:00 Yurii Shevtsov <ungetch at gmail.com>:
> > Any news?
> > 2015-06-29 19:50 GMT+03:00 Yurii Shevtsov <ungetch at gmail.com>:
> >> So, it is empty.
> >>  .rtemsroset.bsd.nexus.begin
> >>                 0x001104bc        0x0 ./libbsd.a(rtems-bsd-nexus.c.16.o)
> >>                 0x001104bc                _bsd__start_set_nexus
> >>  .rtemsroset.bsd.nexus.end
> >>                 0x001104bc                _bsd__stop_set_nexus
> >> What will be next step? My repo:
> >> https://github.com/gtament/rtems-libbsd/commit/cf3f0fcafef3bcb9b0ec80d8c57e1304689ebace
> >> 2015-06-29 9:43 GMT+03:00 Sebastian Huber <sebastian.huber at embedded-brains.de>:
> >>> You can debug this issue on Qemu. The Nexus childes are registered in a
> >>> linker set, so I would consult the linker map file.  It should look like
> >>> this:
> >>>                 0x000000000052ef7c        0x0 libbsd.a(rtems-bsd-nexus.o)
> >>>                 0x000000000052ef7c _bsd__start_set_nexus
> >>>  .rtemsroset.bsd.nexus.content
> >>>                 0x000000000052ef7c       0x28
> >>> testsuite/telnetd01/test_main.o
> >>>                 0x000000000052efa4        0x0 libbsd.a(rtems-bsd-nexus.o)
> >>>                 0x000000000052efa4 _bsd__stop_set_nexus
> >>> The  .rtemsroset.bsd.nexus.content section must be non-empty.
> >>> On 27/06/15 16:39, Yurii Shevtsov wrote:
> >>>> Any ideas? Maybe I did some typo? Maybe you can compile and try it in
> >>>> qemu?
> >>>> 2015-06-26 17:05 GMT+03:00 Yurii Shevtsov <ungetch at gmail.com>:
> >>>>> 2015-06-25 16:00 GMT+03:00 Sebastian Huber
> >>>>>> I would set a break point to nexus_probe(). In this loop
> >>>>>>      SET_FOREACH(nd, nexus) {
> >>>>>>          device_add_child(dev, nd->name, nd->unit);
> >>>>>> your device must get added. I would also set break points to the probe
> >>>>>> and
> >>>>>> attach functions of your device.
> >>>>> Added printfs()
> >>>>>      printf("before setforeach\n");
> >>>>>          printf("setforeach: %s\n", nd->name);
> >>>>> Got only 'before setforeach' in console. So it doesn't step into loop.
> >>>>> Any ideas? Also I already had printfs in my driver's probe and attach,
> >>>>> also got no output.
> >>>>>> On 25/06/15 14:50, Yurii Shevtsov wrote:
> >>>>>>> This is ping message, with small update: the problem is not on the
> >>>>>>> linking stage, driver is linked to testsuite (checked with objdump)
> >>>>>>> 2015-06-21 17:57 GMT+03:00 Yurii Shevtsov <ungetch at gmail.com>:
> >>>>>>>> Hello)
> >>>>>>>> Now I have apps from libbsd testsuite running. But DWC OTG driver
> >>>>>>>> doesn't
> >>>>>>>> loads.
> >>>>>>>> I added this lines to init01/test_main.c:
> >>>>>>>> +SYSINIT_NEED_USB_CORE;
> >>>>>>>> +SYSINIT_DRIVER_REFERENCE(bcm283x_dwcotg, nexus);
> >>>>>>>> (I know it's bad hardcode)
> >>>>>>>> If I run it. I get only this:
> >>>>>>>>     nexus0: <RTEMS Nexus device>
> >>>>>>>>     devctl: +nexus0 at   on root0
> >>>>>>>>     devctl: !system=IFNET subsystem=lo0 type=ATTACH
> >>>>>>>> Of course, I modified rtemsbsd/include/machine/rtems-bsd-sysinit.h and
> >>>>>>>> rtemsbsd/include/bsp/nexus-devices.h (took vlues from working DTS) and
> >>>>>>>> did other nexus-related changes to drivers. You can find changes in my
> >>>>>>>> repo https://github.com/gtament/rtems-libbsd/
> >>>>>>>> So I need some kind of code review, please.
> >>>>>>>> P.S. All testsuites (netshell01, usb01) with shell hangs without any
> >>>>>>>> output.
> >>>>>>>> Thanks in advance!
> >>>>>>> _______________________________________________
> >>>>>>> devel mailing list
> >>>>>>> devel at rtems.org
> >>>>>>> http://lists.rtems.org/mailman/listinfo/devel
> >>>>>> Sebastian Huber, embedded brains GmbH
> >>>>>> Address : Dornierstr. 4, D-82178 Puchheim, Germany
> >>>>>> Phone   : +49 89 189 47 41-16
> >>>>>> Fax     : +49 89 189 47 41-09
> >>>>>> E-Mail  : sebastian.huber at embedded-brains.de
> >>>>>> PGP     : Public key available on request.
> >>>>>> Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
