[PATCH] libcsupport: Workaround for GCC 5.1 and later
Mon Jul 13 14:37:39 UTC 2015
This is possible to do inside the file itself using function
attributes or pragmas. I am not sure which method is best but
wanted to pass along so we could decide as a group.
> optimize
> The optimize attribute is used to specify that a function is to be compiled with different optimization options than specified on the command line. Arguments can either be numbers or strings. Numbers are assumed to be an optimization level. Strings that begin with O are assumed to be an optimization option, while other options are assumed to be used with a -f prefix. You can also use the ‘#pragma GCC optimize’ pragma to set the optimization options that affect more than one function. See Function Specific Option Pragmas, for details about the ‘#pragma GCC optimize’ pragma.
> This can be used for instance to have frequently-executed functions compiled with more aggressive optimization options that produce faster and larger code, while other functions can be compiled with less aggressive options.
--joel
On 7/13/2015 3:20 AM, Sebastian Huber wrote:
> Disable an optimization which would lead to a recursive calloc() call in
> calloc().
>   cpukit/libcsupport/Makefile.am | 8 ++++++--
>   cpukit/wrapup/Makefile.am      | 1 +
>   2 files changed, 7 insertions(+), 2 deletions(-)
> diff --git a/cpukit/libcsupport/Makefile.am b/cpukit/libcsupport/Makefile.am
> index 7474079..a5da5f1 100644
> --- a/cpukit/libcsupport/Makefile.am
> +++ b/cpukit/libcsupport/Makefile.am
> @@ -1,8 +1,9 @@
>   include $(top_srcdir)/automake/multilib.am
>   include $(top_srcdir)/automake/compile.am
> -noinst_LIBRARIES = libcsupport.a
> +noinst_LIBRARIES = libcsupport.a libcalloc.a
>   libcsupport_a_CPPFLAGS = $(AM_CPPFLAGS)
> +libcalloc_a_CPPFLAGS = $(AM_CPPFLAGS)
>   include_rtemsdir = $(includedir)/rtems
>   include_rtems_HEADERS = include/console.h
> @@ -79,7 +80,7 @@ ID_C_FILES = src/getegid.c src/geteuid.c src/getgid.c src/getgroups.c \
>       src/seteuid.c src/setgid.c src/setuid.c src/setegid.c src/setpgid.c \
>       src/setsid.c
> -MALLOC_C_FILES = src/malloc_initialize.c src/calloc.c src/malloc.c \
> +MALLOC_C_FILES = src/malloc_initialize.c src/malloc.c \
>       src/realloc.c src/_calloc_r.c src/_malloc_r.c \
>       src/free.c src/_free_r.c \
>       src/_realloc_r.c src/mallocfreespace.c \
> @@ -138,6 +139,9 @@ libcsupport_a_SOURCES += $(LIBC_GLUE_C_FILES) $(PASSWORD_GROUP_C_FILES) \
>   libcsupport_a_SOURCES += src/flockfile.c src/funlockfile.c src/ftrylockfile.c
> +libcalloc_a_SOURCES = src/calloc.c
> +libcalloc_a_CFLAGS = -fno-builtin
>   EXTRA_DIST = src/TODO src/CASES src/README
>   include $(srcdir)/preinstall.am
> diff --git a/cpukit/wrapup/Makefile.am b/cpukit/wrapup/Makefile.am
> index 53861df..5fd6e33 100644
> --- a/cpukit/wrapup/Makefile.am
> +++ b/cpukit/wrapup/Makefile.am
> @@ -21,6 +21,7 @@ endif
>   TMP_LIBS += ../libcrypt/libcrypt.a
>   TMP_LIBS += ../libcsupport/libcsupport.a
> +TMP_LIBS += ../libcsupport/libcalloc.a
>   TMP_LIBS += ../libblock/libblock.a
>   if LIBDOSFS
>   TMP_LIBS += ../libfs/libdosfs.a
