Interrupt server on BBB
Gedare Bloom gedare at gwu.edu
Mon Jul 13 15:37:25 UTC 2015
Since you run the server task at priority 1, if it does not work
correctly then it can be causing a non-responsive system.
Do you reach the USB1HostIntHandler function? What does it do?
-Gedare
On Fri, Jul 10, 2015 at 5:33 PM, Martin Galvan
<martin.galvan at tallertechnologies.com> wrote:
> Hi everyone! I'm currently trying to use an interrupt server task for
> handling USB interrupts on the Beaglebone Black. Here's the code I'm
> using:
> rtems_interrupt_server_initialize(1, 1500, RTEMS_TIMESLICE | RTEMS_PREEMPT,
>     RTEMS_DEFAULT_ATTRIBUTES, NULL);
> rtems_interrupt_server_handler_install(NULL, AM335X_INT_USB1, "USB_interrupt",
>     RTEMS_INTERRUPT_UNIQUE,
>     reinterpret_cast<rtems_interrupt_handler>(USB1HostIntHandler), NULL);
> I checked the return codes of both functions and it's always
> RTEMS_SUCCESSFUL. At the same time I have a separate thread which is
> constantly doing a printk for debugging purposes.
> Right now what happens is that the printk thread runs about 10-15
> times and then the system hangs in the middle of the print. Am I doing
> something wrong?
> Thanks a lot!
> Martin Galvan
> Software Engineer
> Taller Technologies Argentina
> San Lorenzo 47, 3rd Floor, Office 5
> Córdoba, Argentina
> Phone: 54 351 4217888 / +54 351 4218211
> devel mailing list
> devel at rtems.org
