[PATCH 5/8] score: Add self-contained mutex implementation
Thu Jul 23 12:54:45 UTC 2015
This mutex implementation uses a thread priority queue with a simple
priority inheritance mechanism (similar to the object based mutexes)
without support for timeouts.  The storage space must be supplied by the
user (16 bytes on 32-bit targets).
 cpukit/configure.ac                            |   1 +
 cpukit/libmisc/monitor/mon-prmisc.c            |   1 +
 cpukit/score/Makefile.am                       |   1 +
 cpukit/score/include/rtems/score/statesimpl.h  |   3 +
 cpukit/score/src/mutex.c                       | 314 +++++++++++++++++++++++++
 testsuites/sptests/Makefile.am                 |   3 +
 testsuites/sptests/configure.ac                |   4 +
 testsuites/sptests/spsyslock01/Makefile.am     |  19 ++
 testsuites/sptests/spsyslock01/init.c          | 301 ++++++++++++++++++++++++
 testsuites/sptests/spsyslock01/spsyslock01.doc |  20 ++
 testsuites/sptests/spsyslock01/spsyslock01.scn |   2 +
 11 files changed, 669 insertions(+)
 create mode 100644 cpukit/score/src/mutex.c
 create mode 100644 testsuites/sptests/spsyslock01/Makefile.am
 create mode 100644 testsuites/sptests/spsyslock01/init.c
 create mode 100644 testsuites/sptests/spsyslock01/spsyslock01.doc
 create mode 100644 testsuites/sptests/spsyslock01/spsyslock01.scn
diff --git a/cpukit/configure.ac b/cpukit/configure.ac
index c2b8e8d..14ce0f1 100644
--- a/cpukit/configure.ac
+++ b/cpukit/configure.ac
@@ -71,6 +71,7 @@ AC_CHECK_DECLS([ftrylockfile],[AC_CHECK_FUNCS([ftrylockfile])],,[#include <stdio
 AC_CHECK_HEADERS([envlock.h])
 AC_CHECK_DECLS([__env_lock],,,[#include <envlock.h>])
 AC_CHECK_DECLS([__env_unlock],,,[#include <envlock.h>])
+AC_CHECK_TYPES([struct _Thread_queue_Queue],[],[],[#include <sys/lock.h>])
 # Mandated by POSIX, older newlibs bogusly provided CLOCK_PROCESS_CPUTIME+CLOCK_THREAD_CPUTIME
 AC_CHECK_DECL([CLOCK_PROCESS_CPUTIME_ID],[],[AC_MSG_ERROR([missing define CLOCK_PROCESS_CPUTIME_ID])],[#include <time.h>])
diff --git a/cpukit/libmisc/monitor/mon-prmisc.c b/cpukit/libmisc/monitor/mon-prmisc.c
index 738014f..ae7f75d 100644
--- a/cpukit/libmisc/monitor/mon-prmisc.c
+++ b/cpukit/libmisc/monitor/mon-prmisc.c
@@ -134,6 +134,7 @@ static const rtems_assoc_t rtems_monitor_state_assoc[] = {
     { "Wseg",   STATES_WAITING_FOR_SEGMENT, 0 },
     { "Wsem",   STATES_WAITING_FOR_SEMAPHORE, 0 },
     { "Wsig",   STATES_WAITING_FOR_SIGNAL, 0 },
+    { "Wslmtx", STATES_WAITING_FOR_SYS_LOCK_MUTEX, 0 },
     { "Wsysev", STATES_WAITING_FOR_SYSTEM_EVENT, 0 },
     { "Wterm",  STATES_WAITING_FOR_TERMINATION, 0 },
     { "Wtime",  STATES_WAITING_FOR_TIME, 0 },
diff --git a/cpukit/score/Makefile.am b/cpukit/score/Makefile.am
index 3e612d4..3c117bb 100644
--- a/cpukit/score/Makefile.am
+++ b/cpukit/score/Makefile.am
@@ -345,6 +345,7 @@ libscore_a_SOURCES += src/apiext.c src/chain.c src/chainappend.c \
 libscore_a_SOURCES += src/isrisinprogress.c
 libscore_a_SOURCES += src/debugisownerofallocator.c
 libscore_a_SOURCES += src/profilingisrentryexit.c
+libscore_a_SOURCES += src/mutex.c
 libscore_a_SOURCES += src/once.c
 libscore_a_SOURCES += src/resourceiterate.c
 libscore_a_SOURCES += src/smpbarrierwait.c
diff --git a/cpukit/score/include/rtems/score/statesimpl.h b/cpukit/score/include/rtems/score/statesimpl.h
index d1c402e..4ad8786 100644
--- a/cpukit/score/include/rtems/score/statesimpl.h
+++ b/cpukit/score/include/rtems/score/statesimpl.h
@@ -86,6 +86,8 @@ extern "C" {
 #define STATES_RESTARTING                      0x800000
 /** This macro corresponds to a task waiting for a join. */
 #define STATES_WAITING_FOR_JOIN                0x1000000
+/** This macro corresponds to a task waiting for a <sys/lock.h> mutex. */
+#define STATES_WAITING_FOR_SYS_LOCK_MUTEX      0x2000000
 /** This macro corresponds to a task which is in an interruptible
  *  blocking state.
@@ -103,6 +105,7 @@ extern "C" {
                                  STATES_WAITING_FOR_SIGNAL             | \
                                  STATES_WAITING_FOR_BARRIER            | \
                                  STATES_WAITING_FOR_BSD_WAKEUP         | \
+                                 STATES_WAITING_FOR_SYS_LOCK_MUTEX     | \
                                  STATES_WAITING_FOR_RWLOCK             )
 /** This macro corresponds to a task waiting which is blocked. */
diff --git a/cpukit/score/src/mutex.c b/cpukit/score/src/mutex.c
new file mode 100644
index 0000000..57b50f5
--- /dev/null
+++ b/cpukit/score/src/mutex.c
@@ -0,0 +1,314 @@
+ * Copyright (c) 2015 embedded brains GmbH.  All rights reserved.
+ *  embedded brains GmbH
+ *  Dornierstr. 4
+ *  82178 Puchheim
+ *  Germany
+ *  <rtems at embedded-brains.de>
+#if HAVE_CONFIG_H
+  #include "config.h"
+#endif
+#include <sys/lock.h>
+#include <rtems/score/assert.h>
+#include <rtems/score/threadimpl.h>
+#include <rtems/score/threadqimpl.h>
+#if HAVE_STRUCT__THREAD_QUEUE_QUEUE
+RTEMS_STATIC_ASSERT(
+  offsetof( Thread_queue_Queue, heads )
+    == offsetof( struct _Thread_queue_Queue, _heads ),
+  THREAD_QUEUE_QUEUE_HEADS
+#if defined(RTEMS_SMP)
+  offsetof( Thread_queue_Queue, Lock.next_ticket )
+    == offsetof( struct _Thread_queue_Queue, _Lock._next_ticket ),
+  THREAD_QUEUE_QUEUE_NEXT_TICKET
+  offsetof( Thread_queue_Queue, Lock.now_serving )
+    == offsetof( struct _Thread_queue_Queue, _Lock._now_serving ),
+  THREAD_QUEUE_QUEUE_NOW_SERVING
+  sizeof( Thread_queue_Queue )
+    == sizeof( struct _Thread_queue_Queue ),
+  THREAD_QUEUE_QUEUE_SIZE_SMP
+#else
+  THREAD_QUEUE_QUEUE_SIZE_UNI
+#endif
+#define MUTEX_TQ_OPERATIONS &_Thread_queue_Operations_priority
+static Thread_queue_Queue *_Mutex_Get_thread_queue(
+  struct _Mutex_Control *mutex
+  return (Thread_queue_Queue *) &mutex->_Queue;
+static Thread_Control *_Mutex_Queue_acquire(
+  struct _Mutex_Control *mutex,
+  ISR_lock_Context *lock_context
+  Thread_Control *executing;
+  _ISR_lock_ISR_disable( lock_context );
+  executing = _Thread_Executing;
+  _Thread_queue_Queue_acquire_critical(
+    _Mutex_Get_thread_queue( mutex ),
+    &executing->Potpourri_stats,
+    lock_context
+  return executing;
+static void _Mutex_Queue_release(
+  _Thread_queue_Queue_release(
+    lock_context
+static void _Mutex_Acquire_more(
+  Thread_Control *owner,
+  Thread_Control *executing,
+  /* Priority inheritance */
+  _Thread_Raise_priority( owner, executing->current_priority );
+  _Thread_queue_Enqueue_critical(
+    MUTEX_TQ_OPERATIONS,
+    executing,
+    STATES_WAITING_FOR_SYS_LOCK_MUTEX,
+    0,
+    0,
+    lock_context
+static void _Mutex_Release_more(
+  Thread_queue_Heads *heads,
+  bool keep_priority,
+  if (heads != NULL) {
+    const Thread_queue_Operations *operations;
+    Thread_Control *first;
+    operations = MUTEX_TQ_OPERATIONS;
+    first = ( *operations->first )( heads );
+    mutex->_owner = first;
+    _Thread_queue_Extract_critical(
+      operations,
+      first,
+      lock_context
+  } else {
+    _Mutex_Queue_release( mutex, lock_context);
+  if ( !keep_priority ) {
+    Per_CPU_Control *cpu_self;
+    cpu_self = _Thread_Dispatch_disable();
+    _Thread_Restore_priority( executing );
+    _Thread_Dispatch_enable( cpu_self );
+static void _Mutex_Release_critical(
+  Thread_queue_Heads *heads;
+  bool keep_priority;
+  mutex->_owner = NULL;
+  --executing->resource_count;
+   * Ensure that the owner resource count is visible to all other
+   * processors and that we read the latest priority restore
+   * hint.
+  _Atomic_Fence( ATOMIC_ORDER_ACQ_REL );
+  heads = _Mutex_Get_thread_queue( mutex )->heads;
+  keep_priority = _Thread_Owns_resources( executing )
+    || !executing->priority_restore_hint;
+  if ( __predict_true( heads == NULL && keep_priority ) ) {
+    _Mutex_Queue_release( mutex, lock_context );
+  } else {
+    _Mutex_Release_more(
+      mutex,
+      executing,
+      heads,
+      keep_priority,
+      lock_context
+void _Mutex_Acquire( struct _Mutex_Control *mutex )
+  ISR_lock_Context lock_context;
+  Thread_Control *owner;
+  executing = _Mutex_Queue_acquire( mutex, &lock_context );
+  owner = mutex->_owner;
+  ++executing->resource_count;
+  if ( __predict_true( owner == NULL ) ) {
+    mutex->_owner = executing;
+    _Mutex_Queue_release( mutex, &lock_context );
+  } else {
+    _Mutex_Acquire_more( mutex, owner, executing, &lock_context );
+int _Mutex_Try_acquire( struct _Mutex_Control *mutex )
+  int success;
+    success = 1;
+  } else {
+    success = 0;
+  return success;
+void _Mutex_Release( struct _Mutex_Control *mutex )
+  _Assert( mutex->_owner == executing );
+  _Mutex_Release_critical( mutex, executing, &lock_context );
+void _Mutex_recursive_Acquire( struct _Mutex_recursive_Control *mutex )
+  executing = _Mutex_Queue_acquire( &mutex->_Mutex, &lock_context );
+  owner = mutex->_Mutex._owner;
+    mutex->_Mutex._owner = executing;
+    _Mutex_Queue_release( &mutex->_Mutex, &lock_context );
+  } else if ( owner == executing ) {
+    ++mutex->_nest_level;
+  } else {
+    _Mutex_Acquire_more( &mutex->_Mutex, owner, executing, &lock_context );
+int _Mutex_recursive_Try_acquire( struct _Mutex_recursive_Control *mutex )
+  int success;
+    success = 1;
+    success = 1;
+  } else {
+    success = 0;
+  return success;
+void _Mutex_recursive_Release( struct _Mutex_recursive_Control *mutex )
+  unsigned int nest_level;
+  _Assert( mutex->_Mutex._owner == executing );
+  nest_level = mutex->_nest_level;
+  if ( __predict_true( nest_level == 0 ) ) {
+    _Mutex_Release_critical( &mutex->_Mutex, executing, &lock_context );
+  } else {
+    mutex->_nest_level = nest_level - 1;
+#endif /* HAVE_STRUCT__THREAD_QUEUE_QUEUE */
diff --git a/testsuites/sptests/Makefile.am b/testsuites/sptests/Makefile.am
index 8811623..d012019 100644
--- a/testsuites/sptests/Makefile.am
+++ b/testsuites/sptests/Makefile.am
@@ -37,6 +37,9 @@ if HAS_SMP
 else
 _SUBDIRS += sp29
 endif
+if HAS__THREAD_QUEUE_QUEUE
+_SUBDIRS += spsyslock01
+endif
 _SUBDIRS += sptasknopreempt01
 _SUBDIRS += spintrcritical23
 _SUBDIRS += sptimecounter01
diff --git a/testsuites/sptests/configure.ac b/testsuites/sptests/configure.ac
index 99e9b89..be69f09 100644
--- a/testsuites/sptests/configure.ac
+++ b/testsuites/sptests/configure.ac
@@ -30,6 +30,9 @@ AM_CONDITIONAL([HAS_CPLUSPLUS],[test $HAS_CPLUSPLUS = "yes"])
 # FIXME: We should get rid of this. It's a cludge.
 AC_CHECK_SIZEOF([time_t])
+AM_CONDITIONAL(HAS__THREAD_QUEUE_QUEUE,test x"${ac_cv_type_struct__Thread_queue_Queue}" = x"yes")
 # Added to newlib pthreads for RTEMS SMP (np), may not be present
 AC_CHECK_HEADERS([sys/cpuset.h])
 AM_CONDITIONAL(HAS_CPUSET,test x"${ac_cv_header_sys_cpuset_h}" = x"yes")
@@ -40,6 +43,7 @@ AM_CONDITIONAL(HAS_SMP,test "$rtems_cv_RTEMS_SMP" = "yes")
 # Explicitly list all Makefiles here
 AC_CONFIG_FILES([Makefile
+spsyslock01/Makefile
 sptasknopreempt01/Makefile
 spintrcritical23/Makefile
 sptimecounter01/Makefile
diff --git a/testsuites/sptests/spsyslock01/Makefile.am b/testsuites/sptests/spsyslock01/Makefile.am
index 0000000..7fb3a01
--- /dev/null
+++ b/testsuites/sptests/spsyslock01/Makefile.am
@@ -0,0 +1,19 @@
+rtems_tests_PROGRAMS = spsyslock01
+spsyslock01_SOURCES = init.c
+dist_rtems_tests_DATA = spsyslock01.scn spsyslock01.doc
+include $(RTEMS_ROOT)/make/custom/@RTEMS_BSP at .cfg
+include $(top_srcdir)/../automake/compile.am
+include $(top_srcdir)/../automake/leaf.am
+AM_CPPFLAGS += -I$(top_srcdir)/../support/include
+LINK_OBJS = $(spsyslock01_OBJECTS)
+LINK_LIBS = $(spsyslock01_LDLIBS)
+spsyslock01$(EXEEXT): $(spsyslock01_OBJECTS) $(spsyslock01_DEPENDENCIES)
+	@rm -f spsyslock01$(EXEEXT)
+	$(make-exe)
+include $(top_srcdir)/../automake/local.am
diff --git a/testsuites/sptests/spsyslock01/init.c b/testsuites/sptests/spsyslock01/init.c
index 0000000..7d93676
--- /dev/null
+++ b/testsuites/sptests/spsyslock01/init.c
@@ -0,0 +1,301 @@
+ *  Dornierstr. 4
+ *  82178 Puchheim
+ *  Germany
+#ifdef HAVE_CONFIG_H
+#endif
+#include "tmacros.h"
+#include <string.h>
+const char rtems_test_name[] = "SPSYSLOCK 1";
+#define EVENT_MTX_ACQUIRE RTEMS_EVENT_0
+#define EVENT_MTX_RELEASE RTEMS_EVENT_1
+#define EVENT_MTX_PRIO_INV RTEMS_EVENT_2
+#define EVENT_MTX_DEADLOCK RTEMS_EVENT_3
+#define EVENT_REC_MTX_ACQUIRE RTEMS_EVENT_4
+#define EVENT_REC_MTX_RELEASE RTEMS_EVENT_5
+#define EVENT_REC_MTX_PRIO_INV RTEMS_EVENT_6
+typedef struct {
+  rtems_id high;
+  rtems_id mid;
+  rtems_id low;
+  struct _Mutex_Control mtx;
+  struct _Mutex_recursive_Control rec_mtx;
+  bool flag;
+} test_context;
+static test_context test_instance;
+static void send_events(test_context *ctx, rtems_event_set events)
+  rtems_status_code sc;
+  sc = rtems_event_send(ctx->high, events);
+  rtems_test_assert(sc == RTEMS_SUCCESSFUL);
+static void test_initialization(test_context *ctx)
+  struct _Mutex_Control mtx = _MUTEX_INITIALIZER;
+  struct _Mutex_recursive_Control rec_mtx = _MUTEX_RECURSIVE_INITIALIZER;
+  _Mutex_Initialize(&ctx->mtx);
+  _Mutex_recursive_Initialize(&ctx->rec_mtx);
+  rtems_test_assert(memcmp(&mtx, &ctx->mtx, sizeof(mtx)) == 0);
+  rtems_test_assert(memcmp(&rec_mtx, &ctx->rec_mtx, sizeof(rec_mtx)) == 0);
+  _Mutex_Destroy(&mtx);
+  _Mutex_recursive_Destroy(&rec_mtx);
+static void test_recursive_acquire_normal(test_context *ctx)
+  struct _Mutex_Control *mtx = &ctx->mtx;
+  int success;
+  success = _Mutex_Try_acquire(mtx);
+  rtems_test_assert(success == 1);
+  rtems_test_assert(success == 0);
+  _Mutex_Release(mtx);
+  _Mutex_Acquire(mtx);
+  send_events(ctx, EVENT_MTX_ACQUIRE);
+  send_events(ctx, EVENT_MTX_RELEASE);
+static void test_recursive_acquire_recursive(test_context *ctx)
+  struct _Mutex_recursive_Control *mtx = &ctx->rec_mtx;
+  int success;
+  success = _Mutex_recursive_Try_acquire(mtx);
+  _Mutex_recursive_Acquire(mtx);
+  _Mutex_recursive_Release(mtx);
+  send_events(ctx, EVENT_REC_MTX_ACQUIRE);
+  send_events(ctx, EVENT_REC_MTX_RELEASE);
+static void test_prio_inv_normal(test_context *ctx)
+  ctx->flag = false;
+  send_events(ctx, EVENT_MTX_PRIO_INV);
+  rtems_test_assert(!ctx->flag);
+  rtems_test_assert(ctx->flag);
+static void test_prio_inv_recursive(test_context *ctx)
+  send_events(ctx, EVENT_REC_MTX_PRIO_INV);
+static void mid_task(rtems_task_argument arg)
+  rtems_test_assert(0);
+static void high_task(rtems_task_argument arg)
+  test_context *ctx = &test_instance;
+  sc = rtems_task_start(ctx->mid, mid_task, 0);
+  sc = rtems_task_suspend(ctx->mid);
+  while (true) {
+    rtems_event_set events;
+    sc = rtems_event_receive(
+      RTEMS_ALL_EVENTS,
+      RTEMS_EVENT_ANY | RTEMS_WAIT,
+      RTEMS_NO_TIMEOUT,
+      &events
+    if ((events & EVENT_MTX_ACQUIRE) != 0) {
+      _Mutex_Acquire(&ctx->mtx);
+    if ((events & EVENT_MTX_RELEASE) != 0) {
+      _Mutex_Release(&ctx->mtx);
+    if ((events & EVENT_MTX_PRIO_INV) != 0) {
+      sc = rtems_task_resume(ctx->mid);
+      ctx->flag = true;
+    if ((events & EVENT_MTX_DEADLOCK) != 0) {
+      struct _Mutex_Control dead = _MUTEX_INITIALIZER;
+      _Mutex_Acquire(&dead);
+    if ((events & EVENT_REC_MTX_ACQUIRE) != 0) {
+      _Mutex_recursive_Acquire(&ctx->rec_mtx);
+    if ((events & EVENT_REC_MTX_RELEASE) != 0) {
+      _Mutex_recursive_Release(&ctx->rec_mtx);
+    if ((events & EVENT_REC_MTX_PRIO_INV) != 0) {
+      ctx->flag = true;
+static void test(void)
+  test_initialization(ctx);
+  ctx->low = rtems_task_self();
+  sc = rtems_task_create(
+    rtems_build_name('M', 'I', 'D', ' '),
+    2,
+    RTEMS_MINIMUM_STACK_SIZE,
+    RTEMS_DEFAULT_MODES,
+    RTEMS_DEFAULT_ATTRIBUTES,
+    &ctx->mid
+    rtems_build_name('H', 'I', 'G', 'H'),
+    1,
+    &ctx->high
+  sc = rtems_task_start(ctx->high, high_task, 0);
+  test_recursive_acquire_normal(ctx);
+  test_recursive_acquire_recursive(ctx);
+  test_prio_inv_normal(ctx);
+  test_prio_inv_recursive(ctx);
+  send_events(ctx, EVENT_MTX_DEADLOCK);
+  _Mutex_Destroy(&ctx->mtx);
+  _Mutex_recursive_Destroy(&ctx->rec_mtx);
+static void Init(rtems_task_argument arg)
+  TEST_BEGIN();
+  test();
+  TEST_END();
+  rtems_test_exit(0);
+#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
+#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
+#define CONFIGURE_USE_IMFS_AS_BASE_FILESYSTEM
+#define CONFIGURE_MAXIMUM_TASKS 3
+#define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
+#define CONFIGURE_INIT_TASK_PRIORITY 3
+#define CONFIGURE_INIT_TASK_INITIAL_MODES RTEMS_DEFAULT_MODES
+#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
+#include <rtems/confdefs.h>
diff --git a/testsuites/sptests/spsyslock01/spsyslock01.doc b/testsuites/sptests/spsyslock01/spsyslock01.doc
index 0000000..440759d
--- /dev/null
+++ b/testsuites/sptests/spsyslock01/spsyslock01.doc
@@ -0,0 +1,20 @@
+This file describes the directives and concepts tested by this test set.
+test set name: spsyslock01
+directives:
+  - _Mutex_Initialize()
+  - _Mutex_Acquire()
+  - _Mutex_Try_acquire()
+  - _Mutex_Release()
+  - _Mutex_Destroy()
+  - _Mutex_recursive_Initialize()
+  - _Mutex_recursive_Acquire()
+  - _Mutex_recursive_Try_acquire()
+  - _Mutex_recursive_Release()
+  - _Mutex_recursive_Destroy()
+concepts:
+  - Ensure that self-contained mutexes and recursive mutexes work.
diff --git a/testsuites/sptests/spsyslock01/spsyslock01.scn b/testsuites/sptests/spsyslock01/spsyslock01.scn
index 0000000..f8c05f7
--- /dev/null
+++ b/testsuites/sptests/spsyslock01/spsyslock01.scn
@@ -0,0 +1,2 @@
+*** BEGIN OF TEST SPSYSLOCK 1 ***
+*** END OF TEST SPSYSLOCK 1 ***
1.8.4.5
