Error while compiling rtems main branch for sparc
Saurabh Gadia
gadia at usc.edu
Mon Jun 1 04:33:47 UTC 2015
Hi,
so I am working for sparc-sis setting and master branch. And if you see the
code in threadimpl.h and threadchangepriority.c and coremutexsurrender.c
the definition of *_Thread_Change_priority() *is having mismatch calling.
Git records says that there was change to above function structure done by
sebastian huber. But I guess he forgot to change the definition of
in threadimpl.h *and call in coremutexsurrender.c
Configuration command:
./configure --target=sparc-rtems4.11 --enable-rtemsbsp=sis --enable-tests
--disable-posix ENABLE_STRICT_ORDER_MUTEX=1
Error Log:
In file included from
../../cpukit/../../../sis/lib/include/rtems/score/coremuteximpl.h:24:0,
from
../../../../../../rtems/c/src/../../cpukit/score/src/coremutexsurrender.c:23:
../../cpukit/../../../sis/lib/include/rtems/score/threadimpl.h:394:6: note:
expected 'void *' but argument is of type 'int'
void _Thread_Change_priority(
../../../../../../rtems/c/src/../../cpukit/score/src/coremutexsurrender.c:60:7:
error: too few arguments to function '_Thread_Change_priority'
_Thread_Change_priority( holder, mutex->queue.priority_before, true
from
declared here
make[6]: *** [src/libscore_a-coremutexsurrender.o] Error 1
Thanks,
Saurabh Gadia
On Sun, May 31, 2015 at 8:25 PM, Nick Withers <nick.withers at anu.edu.au>
wrote:
> Does re-running bootstrap in the source dir and re-configuring sort it?
> Nick Withers
> Embedded Systems Programmer
> Department of Nuclear Physics, Research School of Physics and Engineering
> The Australian National University (CRICOS: 00120C)
> On Sun, 2015-05-31 at 20:31 -0400, Joel Sherrill wrote:
> > More information is needed. Target architecture, bsp, configure command.
> > I have been building all bsps regularly and unless it got broken this
> weekend, something else is up
> > On May 31, 2015 7:57:04 PM EDT, Saurabh Gadia <gadia at usc.edu> wrote:
> > >The problem is on master branch
> > >Thanks,
> > >Saurabh Gadia
> > >On Sun, May 31, 2015 at 4:44 PM, Saurabh Gadia <gadia at usc.edu> wrote:
> > >Logs:
> > >make[6]: Entering directory
> > >`/home/saurabh/dev1/kernel/b-sis/sparc-rtems4.11/c/sis/cpukit/score'
> > >make[6]: *** No rule to make target `src/apimutexislocked.c', needed by
> > >`src/libscore_a-apimutexislocked.o'. Stop.
> > >make[6]: Leaving directory
> > >make[5]: *** [all-recursive] Error 1
> > >There is no makefile but I am also not able to find apimutexislocked.c
> > >How do I proceed about this.
> > >Thanks,
> > >Saurabh Gadia
> > --joel
> > devel mailing list
> > devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20150531/4fe6a98b/attachment-0001.html>
