Error while compiling rtems main branch for sparc
Saurabh Gadia
gadia at usc.edu
Mon Jun 1 04:35:09 UTC 2015
I wanted to test the ENABLE_STRICT_ORDER_MUTEX=1 related sptests for
"nested mutex" GSOC project. So please let me know what can be done.
Thanks,
Saurabh Gadia
On Sun, May 31, 2015 at 9:33 PM, Saurabh Gadia <gadia at usc.edu> wrote:
> Hi,
> so I am working for sparc-sis setting and master branch. And if you see
> the code in threadimpl.h and threadchangepriority.c and
> coremutexsurrender.c the definition of *_Thread_Change_priority() *is
> having mismatch calling. Git records says that there was change to above
> function structure done by sebastian huber. But I guess he forgot to change
> the definition of *_Thread_Change_priority() in threadimpl.h *and call in
> Configuration command:
> ./configure --target=sparc-rtems4.11 --enable-rtemsbsp=sis --enable-tests
> --disable-posix ENABLE_STRICT_ORDER_MUTEX=1
> Error Log:
> In file included from
> ../../cpukit/../../../sis/lib/include/rtems/score/coremuteximpl.h:24:0,
> from
> ../../../../../../rtems/c/src/../../cpukit/score/src/coremutexsurrender.c:23:
> ../../cpukit/../../../sis/lib/include/rtems/score/threadimpl.h:394:6:
> note: expected 'void *' but argument is of type 'int'
> void _Thread_Change_priority(
> ../../../../../../rtems/c/src/../../cpukit/score/src/coremutexsurrender.c:60:7:
> error: too few arguments to function '_Thread_Change_priority'
> _Thread_Change_priority( holder, mutex->queue.priority_before, true
> from
> note: declared here
> make[6]: *** [src/libscore_a-coremutexsurrender.o] Error 1
> Thanks,
> Saurabh Gadia
> On Sun, May 31, 2015 at 8:25 PM, Nick Withers <nick.withers at anu.edu.au>
> wrote:
>> Does re-running bootstrap in the source dir and re-configuring sort it?
>> Nick Withers
>> Embedded Systems Programmer
>> Department of Nuclear Physics, Research School of Physics and Engineering
>> The Australian National University (CRICOS: 00120C)
>> On Sun, 2015-05-31 at 20:31 -0400, Joel Sherrill wrote:
>> > More information is needed. Target architecture, bsp, configure command.
>> > I have been building all bsps regularly and unless it got broken this
>> weekend, something else is up
>> > On May 31, 2015 7:57:04 PM EDT, Saurabh Gadia <gadia at usc.edu> wrote:
>> > >The problem is on master branch
>> > >Thanks,
>> > >Saurabh Gadia
>> > >On Sun, May 31, 2015 at 4:44 PM, Saurabh Gadia <gadia at usc.edu> wrote:
>> > >Logs:
>> > >make[6]: Entering directory
>> > >`/home/saurabh/dev1/kernel/b-sis/sparc-rtems4.11/c/sis/cpukit/score'
>> > >make[6]: *** No rule to make target `src/apimutexislocked.c', needed by
>> > >`src/libscore_a-apimutexislocked.o'. Stop.
>> > >make[6]: Leaving directory
>> > >make[5]: *** [all-recursive] Error 1
>> > >There is no makefile but I am also not able to find apimutexislocked.c
>> > >How do I proceed about this.
>> > >Thanks,
>> > >Saurabh Gadia
>> > --joel
>> > _______________________________________________
>> > devel mailing list
>> > devel at rtems.org
>> > http://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20150531/3d4d070d/attachment.html>
