GSoC 2015: Raspberry Pi 2 Support
Hesham ALMatary heshamelmatary at gmail.com
Tue Jun 2 11:29:52 UTC 2015
Hi,
Aren't the MMU/Caches enabled by default for RPi [1]?
[1] https://github.com/RTEMS/rtems/blob/master/c/src/lib/libbsp/arm/shared/mminit.c
On Tue, Jun 2, 2015 at 12:18 PM, Joel Sherrill
<joel.sherrill at oarcorp.com> wrote:
> On June 2, 2015 7:01:21 AM EDT, Rohini Kulkarni <krohini1593 at gmail.com> wrote:
>>Dr. Joel,
>>So we can't say something solely on the basis of this result?
> I don't think so. If Linux performs the same, then what you did is as good as it gets.
> However, if Linux is faster then some setting still isn't right.
> You need a reference measurement to have any confidence. It is possible you did something but didn't actually turn the cache (or all the cache) on.
>>On 2 Jun 2015 16:28, "Rohini Kulkarni" <krohini1593 at gmail.com> wrote:
>>I have not run it under linux on pi2 yet. Will have to run and check
>>the result.
>>On 2 Jun 2015 16:16, "Joel Sherrill" <joel.sherrill at oarcorp.com> wrote:
>>On June 2, 2015 5:58:33 AM EDT, Rohini Kulkarni <krohini1593 at gmail.com>
>>wrote:
>>>HI,
>>>I tried running the dhrystone benchmark with some changes for
>>cache/mmu
>>>set up.
>>>However, the output shows a reduction in performance.
>>>The time to run through the dhrystone has increased from 12 to 13 and
>>>dhrystones run per second decreased.
>>>According to this result, things were better with caches disabled.
>>>I have been working on this since two days and could not figure out an
>>>improvement. Any pointers?
>>How did it do under Linux on the Pi2?
>>>Thanks.
>>>On Thu, May 28, 2015 at 8:41 PM, Rohini Kulkarni
>>>Hi All,
>>>I have to implement the cache coherency support for Cortex A7. But for
>>>A7 MPCore, unlike for A9, I am not able to find any register
>>>description for the Snoop Control Unit from the TRM.
>>>I need help here on how to proceed.
>>>Additionally for A9 there is a single bit for A9 in the Auxiliary
>>>Control Register which enables cache broadcast operations. The
>>register
>>>format is different for A7 and again I am unable to find how to
>>achieve
>>>the same for A7.
>>>Thanks!
>>>On Tue, May 5, 2015 at 10:42 PM, Joel Sherrill
>>>On 5/5/2015 11:11 AM, Rohini Kulkarni wrote:
>>>Hi,
>>>I am working with the code for bsp hooks. I am referring to existing
>>>ARM multicore bsp codes, zync mainly.
>>>1. There are existing hooks for the raspberry pi. Where should the
>>code
>>>for the  Pi2 hooks be added?
>>>The Pi and Pi2 are remarkably similar so Pi2 should be placed inside
>>>the Pi BSP directory.
>>>There is already a Pi2 variant of that code built. But we know
>>specific
>>>places where there
>>>are variances. Depending on the scope of what is different, it can be
>>>as simple as
>>>a cpp conditional in a .h to select a value or two implementations of
>>a
>>>single method
>>>and the Makefile.am picking the right file to build based on the board
>>>variant.
>>>The big question to always ask is: Is this specific to the Pi2 and
>>>incompatible with the Pi?
>>>Since the Pi BSP is still missing capabilities, it is likely code
>>>common to both will
>>>be added this summer. For example, did the mailbox interface change? I
>>>don't know
>>>but would guess that it didn't.  Each new capability added needs that
>>>added.
>>>And any differences need to be analyzed to pick the least intrusive
>>way
>>>to provide
>>>alternate implementations. Or enable special code like the Pi2 SMP
>>>support which
>>>is dependent on --enable-smp and being a Pi2.
>>>2. Am I right in understanding that I will have to implement A7
>>>specific functions as have been for A9? I am referring specifically to
>>>the arm-a9mpcore-start.h
>>>Yes.
>>>If the code is very similar between the a7 and a9, then a discussion
>>>on devel@ should occur to decide the best way to minimize duplication.
>>>If you end up with a7 specific code, you should follow the location
>>and
>>>naming patterns already established. That places it in
>>>libbsp/arm/shared/...
>>>so it can be used by any BSP with the right SMP core.
>>>I am referring to existing codes to locate and get hold of what needs
>>>to be done in the hooks. However, being new to such implementations, I
>>>am taking longer to understand the details. Any suggestions that might
>>>help here are welcome
>>>The answer will depend on the factors listed above. When code can
>>>be shared, we want to share it across as many BSPs as makes sense.
>>>When it is unique to a specific BSP **variant** (e.g. Pi vs Pi2), then
>>>you want to find the way to account for the variation in the least
>>>intrusive code way possible.
>>>Thanks!
>>>On 1 May 2015 12:45, "Rohini Kulkarni" <krohini1593 at gmail.com> wrote:
>>>Hi,
>>>Excited to be a part of  this edition of GSoC! Thanks to everybody for
>>>helping me get here and congratulations to all the participating
>>>students!
>>>So, now getting to work, firstly I wish to know, specifically from my
>>>mentors, any changes that must be made to my proposed project or
>>>schedule.
>>>Secondly, are there any specifics for the development blog that we
>>need
>>>to create for the project? Over time what is the blog expected to
>>>convey.
>>>Also, I have to create a new wiki page for my project as none exists.
>>I
>>>want to know how to add one.
>>>Rohini Kulkarni
>>>-- Joel Sherrill, Ph.D. Director of Research & Development
>>>joel.sherrill at OARcorp.com On-Line Applications Research Ask me about
>>>RTEMS: a free RTOS Huntsville AL 35805 Support Available (256)
>>722-9985
>>>Rohini Kulkarni
>>>Rohini Kulkarni
>>--joel
> --joel
> devel mailing list
> devel at rtems.org
Hesham
