GSoC 2015: Raspberry Pi 2 Support
Tue Jun 2 11:31:39 UTC 2015
On June 2, 2015 7:29:52 AM EDT, Hesham ALMatary <heshamelmatary at gmail.com> wrote:
>Hi,
>Aren't the MMU/Caches enabled by default for RPi [1]?
Yes but I recall that the setup is different on the Pi2 and Alan disabled the code to to work at all.
>[1]
>https://github.com/RTEMS/rtems/blob/master/c/src/lib/libbsp/arm/shared/mminit.c
>On Tue, Jun 2, 2015 at 12:18 PM, Joel Sherrill
><joel.sherrill at oarcorp.com> wrote:
>> On June 2, 2015 7:01:21 AM EDT, Rohini Kulkarni
><krohini1593 at gmail.com> wrote:
>>>Dr. Joel,
>>>So we can't say something solely on the basis of this result?
>> I don't think so. If Linux performs the same, then what you did is as
>good as it gets.
>> However, if Linux is faster then some setting still isn't right.
>> You need a reference measurement to have any confidence. It is
>possible you did something but didn't actually turn the cache (or all
>the cache) on.
>>>On 2 Jun 2015 16:28, "Rohini Kulkarni" <krohini1593 at gmail.com> wrote:
>>>I have not run it under linux on pi2 yet. Will have to run and check
>>>the result.
>>>On 2 Jun 2015 16:16, "Joel Sherrill" <joel.sherrill at oarcorp.com>
>wrote:
>>>On June 2, 2015 5:58:33 AM EDT, Rohini Kulkarni
>>>wrote:
>>>>HI,
>>>>I tried running the dhrystone benchmark with some changes for
>>>cache/mmu
>>>>set up.
>>>>However, the output shows a reduction in performance.
>>>>The time to run through the dhrystone has increased from 12 to 13
>and
>>>>dhrystones run per second decreased.
>>>>According to this result, things were better with caches disabled.
>>>>I have been working on this since two days and could not figure out
>an
>>>>improvement. Any pointers?
>>>How did it do under Linux on the Pi2?
>>>>Thanks.
>>>>On Thu, May 28, 2015 at 8:41 PM, Rohini Kulkarni
>>>>Hi All,
>>>>I have to implement the cache coherency support for Cortex A7. But
>for
>>>>A7 MPCore, unlike for A9, I am not able to find any register
>>>>description for the Snoop Control Unit from the TRM.
>>>>I need help here on how to proceed.
>>>>Additionally for A9 there is a single bit for A9 in the Auxiliary
>>>>Control Register which enables cache broadcast operations. The
>>>register
>>>>format is different for A7 and again I am unable to find how to
>>>achieve
>>>>the same for A7.
>>>>Thanks!
>>>>On Tue, May 5, 2015 at 10:42 PM, Joel Sherrill
>>>>On 5/5/2015 11:11 AM, Rohini Kulkarni wrote:
>>>>Hi,
>>>>I am working with the code for bsp hooks. I am referring to existing
>>>>ARM multicore bsp codes, zync mainly.
>>>>1. There are existing hooks for the raspberry pi. Where should the
>>>code
>>>>for the  Pi2 hooks be added?
>>>>The Pi and Pi2 are remarkably similar so Pi2 should be placed inside
>>>>the Pi BSP directory.
>>>>There is already a Pi2 variant of that code built. But we know
>>>specific
>>>>places where there
>>>>are variances. Depending on the scope of what is different, it can
>be
>>>>as simple as
>>>>a cpp conditional in a .h to select a value or two implementations
>of
>>>a
>>>>single method
>>>>and the Makefile.am picking the right file to build based on the
>board
>>>>variant.
>>>>The big question to always ask is: Is this specific to the Pi2 and
>>>>incompatible with the Pi?
>>>>Since the Pi BSP is still missing capabilities, it is likely code
>>>>common to both will
>>>>be added this summer. For example, did the mailbox interface change?
>I
>>>>don't know
>>>>but would guess that it didn't.  Each new capability added needs
>that
>>>>added.
>>>>And any differences need to be analyzed to pick the least intrusive
>>>way
>>>>to provide
>>>>alternate implementations. Or enable special code like the Pi2 SMP
>>>>support which
>>>>is dependent on --enable-smp and being a Pi2.
>>>>2. Am I right in understanding that I will have to implement A7
>>>>specific functions as have been for A9? I am referring specifically
>to
>>>>the arm-a9mpcore-start.h
>>>>Yes.
>>>>If the code is very similar between the a7 and a9, then a discussion
>>>>on devel@ should occur to decide the best way to minimize
>duplication.
>>>>If you end up with a7 specific code, you should follow the location
>>>and
>>>>naming patterns already established. That places it in
>>>>libbsp/arm/shared/...
>>>>so it can be used by any BSP with the right SMP core.
>>>>I am referring to existing codes to locate and get hold of what
>needs
>>>>to be done in the hooks. However, being new to such implementations,
>I
>>>>am taking longer to understand the details. Any suggestions that
>might
>>>>help here are welcome
>>>>The answer will depend on the factors listed above. When code can
>>>>be shared, we want to share it across as many BSPs as makes sense.
>>>>When it is unique to a specific BSP **variant** (e.g. Pi vs Pi2),
>then
>>>>you want to find the way to account for the variation in the least
>>>>intrusive code way possible.
>>>>Thanks!
>>>>On 1 May 2015 12:45, "Rohini Kulkarni" <krohini1593 at gmail.com>
>wrote:
>>>>Hi,
>>>>Excited to be a part of  this edition of GSoC! Thanks to everybody
>for
>>>>helping me get here and congratulations to all the participating
>>>>students!
>>>>So, now getting to work, firstly I wish to know, specifically from
>my
>>>>mentors, any changes that must be made to my proposed project or
>>>>schedule.
>>>>Secondly, are there any specifics for the development blog that we
>>>need
>>>>to create for the project? Over time what is the blog expected to
>>>>convey.
>>>>Also, I have to create a new wiki page for my project as none
>exists.
>>>I
>>>>want to know how to add one.
>>>>Rohini Kulkarni
>>>>-- Joel Sherrill, Ph.D. Director of Research & Development
>>>>joel.sherrill at OARcorp.com On-Line Applications Research Ask me about
>>>>RTEMS: a free RTOS Huntsville AL 35805 Support Available (256)
>>>722-9985
>>>>Rohini Kulkarni
>>>>Rohini Kulkarni
>>>--joel
>> --joel
>> devel mailing list
>> devel at rtems.org
--joel
