GSoC 2015: Raspberry Pi 2 Support
Hesham ALMatary heshamelmatary at gmail.com
Tue Jun 2 12:05:57 UTC 2015
On Tue, Jun 2, 2015 at 12:41 PM, Rohini Kulkarni <krohini1593 at gmail.com> wrote:
> From what I saw, they have to be enabled separately. Cache/mmu are disabled
> upon reset.
For the existing Raspberry BSP [1] there's a code for MMU/Cache init,
however I don't know about Pi2 and where its code is.
[1] https://github.com/RTEMS/rtems/tree/master/c/src/lib/libbsp/arm/raspberrypi
> On 2 Jun 2015 16:59, "Hesham ALMatary" <heshamelmatary at gmail.com> wrote:
>> Hi,
>> Aren't the MMU/Caches enabled by default for RPi [1]?
>> [1]
>> https://github.com/RTEMS/rtems/blob/master/c/src/lib/libbsp/arm/shared/mminit.c
>> On Tue, Jun 2, 2015 at 12:18 PM, Joel Sherrill
>> <joel.sherrill at oarcorp.com> wrote:
>> > On June 2, 2015 7:01:21 AM EDT, Rohini Kulkarni <krohini1593 at gmail.com>
>> > wrote:
>> >>Dr. Joel,
>> >>So we can't say something solely on the basis of this result?
>> > I don't think so. If Linux performs the same, then what you did is as
>> > good as it gets.
>> > However, if Linux is faster then some setting still isn't right.
>> > You need a reference measurement to have any confidence. It is possible
>> > you did something but didn't actually turn the cache (or all the cache) on.
>> >>On 2 Jun 2015 16:28, "Rohini Kulkarni" <krohini1593 at gmail.com> wrote:
>> >>I have not run it under linux on pi2 yet. Will have to run and check
>> >>the result.
>> >>On 2 Jun 2015 16:16, "Joel Sherrill" <joel.sherrill at oarcorp.com> wrote:
>> >>On June 2, 2015 5:58:33 AM EDT, Rohini Kulkarni <krohini1593 at gmail.com>
>> >>wrote:
>> >>>HI,
>> >>>I tried running the dhrystone benchmark with some changes for
>> >>cache/mmu
>> >>>set up.
>> >>>However, the output shows a reduction in performance.
>> >>>The time to run through the dhrystone has increased from 12 to 13 and
>> >>>dhrystones run per second decreased.
>> >>>According to this result, things were better with caches disabled.
>> >>>I have been working on this since two days and could not figure out an
>> >>>improvement. Any pointers?
>> >>How did it do under Linux on the Pi2?
>> >>>Thanks.
>> >>>On Thu, May 28, 2015 at 8:41 PM, Rohini Kulkarni
>> >>>Hi All,
>> >>>I have to implement the cache coherency support for Cortex A7. But for
>> >>>A7 MPCore, unlike for A9, I am not able to find any register
>> >>>description for the Snoop Control Unit from the TRM.
>> >>>I need help here on how to proceed.
>> >>>Additionally for A9 there is a single bit for A9 in the Auxiliary
>> >>>Control Register which enables cache broadcast operations. The
>> >>register
>> >>>format is different for A7 and again I am unable to find how to
>> >>achieve
>> >>>the same for A7.
>> >>>Thanks!
>> >>>On Tue, May 5, 2015 at 10:42 PM, Joel Sherrill
>> >>>On 5/5/2015 11:11 AM, Rohini Kulkarni wrote:
>> >>>Hi,
>> >>>I am working with the code for bsp hooks. I am referring to existing
>> >>>ARM multicore bsp codes, zync mainly.
>> >>>1. There are existing hooks for the raspberry pi. Where should the
>> >>code
>> >>>for the  Pi2 hooks be added?
>> >>>The Pi and Pi2 are remarkably similar so Pi2 should be placed inside
>> >>>the Pi BSP directory.
>> >>>There is already a Pi2 variant of that code built. But we know
>> >>specific
>> >>>places where there
>> >>>are variances. Depending on the scope of what is different, it can be
>> >>>as simple as
>> >>>a cpp conditional in a .h to select a value or two implementations of
>> >>a
>> >>>single method
>> >>>and the Makefile.am picking the right file to build based on the board
>> >>>variant.
>> >>>The big question to always ask is: Is this specific to the Pi2 and
>> >>>incompatible with the Pi?
>> >>>Since the Pi BSP is still missing capabilities, it is likely code
>> >>>common to both will
>> >>>be added this summer. For example, did the mailbox interface change? I
>> >>>don't know
>> >>>but would guess that it didn't.  Each new capability added needs that
>> >>>added.
>> >>>And any differences need to be analyzed to pick the least intrusive
>> >>way
>> >>>to provide
>> >>>alternate implementations. Or enable special code like the Pi2 SMP
>> >>>support which
>> >>>is dependent on --enable-smp and being a Pi2.
>> >>>2. Am I right in understanding that I will have to implement A7
>> >>>specific functions as have been for A9? I am referring specifically to
>> >>>the arm-a9mpcore-start.h
>> >>>Yes.
>> >>>If the code is very similar between the a7 and a9, then a discussion
>> >>>on devel@ should occur to decide the best way to minimize duplication.
>> >>>If you end up with a7 specific code, you should follow the location
>> >>and
>> >>>naming patterns already established. That places it in
>> >>>libbsp/arm/shared/...
>> >>>so it can be used by any BSP with the right SMP core.
>> >>>I am referring to existing codes to locate and get hold of what needs
>> >>>to be done in the hooks. However, being new to such implementations, I
>> >>>am taking longer to understand the details. Any suggestions that might
>> >>>help here are welcome
>> >>>The answer will depend on the factors listed above. When code can
>> >>>be shared, we want to share it across as many BSPs as makes sense.
>> >>>When it is unique to a specific BSP **variant** (e.g. Pi vs Pi2), then
>> >>>you want to find the way to account for the variation in the least
>> >>>intrusive code way possible.
>> >>>Thanks!
>> >>>On 1 May 2015 12:45, "Rohini Kulkarni" <krohini1593 at gmail.com> wrote:
>> >>>Hi,
>> >>>Excited to be a part of  this edition of GSoC! Thanks to everybody for
>> >>>helping me get here and congratulations to all the participating
>> >>>students!
>> >>>So, now getting to work, firstly I wish to know, specifically from my
>> >>>mentors, any changes that must be made to my proposed project or
>> >>>schedule.
>> >>>Secondly, are there any specifics for the development blog that we
>> >>need
>> >>>to create for the project? Over time what is the blog expected to
>> >>>convey.
>> >>>Also, I have to create a new wiki page for my project as none exists.
>> >>I
>> >>>want to know how to add one.
>> >>>Rohini Kulkarni
>> >>>-- Joel Sherrill, Ph.D. Director of Research & Development
>> >>>joel.sherrill at OARcorp.com On-Line Applications Research Ask me about
>> >>>RTEMS: a free RTOS Huntsville AL 35805 Support Available (256)
>> >>722-9985
>> >>>Rohini Kulkarni
>> >>>Rohini Kulkarni
>> >>--joel
>> > --joel
>> > _______________________________________________
>> > devel mailing list
>> > devel at rtems.org
>> > http://lists.rtems.org/mailman/listinfo/devel
>> Hesham
Hesham
