4.11 Release Description Help Needed
Wed Jun 3 08:34:31 UTC 2015
Hi,
I added some points. What is a bit confusing is that the documentation
is not up to date, e.g.
https://docs.rtems.org/doc-current/share/rtems/html/bsp_howto/Clock-Driver.html#Clock-Driver
still reflects the old clock driver API.
On 23/05/15 16:44, Joel Sherrill wrote:
> Hi
> A LOT has happened since our last release. The release
> page (https://devel.rtems.org/wiki/Release/4.11) has a
> lot of the changes listed but a quick scan shows that
> at least:
> + SMP not mentioned
> + dynamic loading not mentioned
> + or1k not mentioned
> +epiphany not mentioned
> + other new BSPs missing? tms570 missing for sure
> + rtems-tester not mentioned
> + RSB only mentioned because I added some
> + recent timekeeping work missing
> + shell improvements looks too short
> + What else?
> Please look at this page and try to help improve the
> release notes. With major features completely missing
> from it, it is clearly lacking.
> This is a blocker on the release.
> Thanks.
> --joel
> devel mailing list
> devel at rtems.org
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
