4.11 Release Description Help Needed
Wed Jun 3 10:59:26 UTC 2015
On June 3, 2015 4:34:31 AM EDT, Sebastian Huber <sebastian.huber at embedded-brains.de> wrote:
>Hi,
>I added some points. What is a bit confusing is that the documentation
>is not up to date, e.g.
>https://docs.rtems.org/doc-current/share/rtems/html/bsp_howto/Clock-Driver.html#Clock-Driver
>still reflects the old clock driver API.
Is it fixed in the source and just needs regenerating on the server? Or is there writing to do?
>On 23/05/15 16:44, Joel Sherrill wrote:
>> Hi
>> A LOT has happened since our last release. The release
>> page (https://devel.rtems.org/wiki/Release/4.11) has a
>> lot of the changes listed but a quick scan shows that
>> at least:
>> + SMP not mentioned
>> + dynamic loading not mentioned
>> + or1k not mentioned
>> +epiphany not mentioned
>> + other new BSPs missing? tms570 missing for sure
>> + rtems-tester not mentioned
>> + RSB only mentioned because I added some
>> + recent timekeeping work missing
>> + shell improvements looks too short
>> + What else?
>> Please look at this page and try to help improve the
>> release notes. With major features completely missing
>> from it, it is clearly lacking.
>> This is a blocker on the release.
>> Thanks.
>> --joel
>> devel mailing list
>> devel at rtems.org
--joel
