GSoC 2015: Raspberry Pi 2 Support
Gedare Bloom gedare at gwu.edu
Wed Jun 3 14:14:00 UTC 2015
On Wed, Jun 3, 2015 at 2:39 AM, Rohini Kulkarni <krohini1593 at gmail.com> wrote:
> But, I can't say cache configurations have a role here.
> I'll push my code to my github project soon.
> P.S. The Pi2 board I possess seems to have broken down. It just isn't
> turning on. Unable to test further. Will order one immediately.
Ouch. Make sure you put it in a safe space for development, clear of
threats like moisture, static shock, and cats.
> On 3 Jun 2015 09:03, "Rohini Kulkarni" <krohini1593 at gmail.com> wrote:
>> Hi,
>> Alan, your suggestion has resulted in much improvement
>> arm_control=0x1000
>> This has simply worked! Looks like the other cores were taking up plenty
>> of time.
>> I was aware from references that the other cores run a WFI, but ya, did
>> not get its impact.
>> Time for each dhrystone has reduced to 7 from 13 and the no of dhrystones
>> per second also increased.
>> But this is a change only in the config.txt not actually in the boot code.
>> Thanks
>> Rohini
>> On Wed, Jun 3, 2015 at 7:12 AM, Alan Cudmore <alan.cudmore at gmail.com>
>> wrote:
>>> The caches are being enabled on the RPI 1 BSP. The same code is being
>>> executed by the RPI 2 BSP, but obviously it’s not sufficient for the cache
>>> setup.
>>> I have been reading through this long thread, and it is very informative:
>>> https://www.raspberrypi.org/forums/viewtopic.php?f=72&t=98904
>>> I am starting to understand the setup that is required to enable caches
>>> on the RPI 2. For example this message near the bottom of page 3 gives a
>>> good indication of the speedup available by configuring the MMU and caches
>>> correctly:
>>> Quote from above thread
>>> Enabling I/D caches and branch prediction, just like the julia demo uses,
>>> it takes ~12 seconds, or ~21 fps. It's just one core but also a much smaller
>>> loop than the julia demo has.
>>> Enabling the MMU and mapping memory inner/outer write-back, write
>>> allocate and the framebuffer inner write-through, no write allocate + outer
>>> write-back, write-allocate it takes ~8 seconds, of 32 fps.
>>> PS: 640x480x32 with MMU gets me ~256 fps. Must have a greater L2 cache
>>> effect.
>>> End of quote
>>> The person who posted the above comment (mrvn) posted the code here:
>>> https://github.com/mrvn/test/blob/master/mmu.cc
>>> Also, it seems that when the Pi 2 starts up, cores 1-3 are put in a wait
>>> loop always accessing the bus. By putting this option in the config.txt file
>>> you can put the other cores to sleep, speeding up the code on core 1.
>>>  arm_control=0x1000
>>> It would be worth trying that option to see if the benchmark speeds up.
>>> Alan
>>> On Jun 2, 2015, at 8:05 AM, Hesham ALMatary <heshamelmatary at gmail.com>
>>> wrote:
>>> On Tue, Jun 2, 2015 at 12:41 PM, Rohini Kulkarni <krohini1593 at gmail.com>
>>> wrote:
>>> From what I saw, they have to be enabled separately. Cache/mmu are
>>> disabled
>>> upon reset.
>>> For the existing Raspberry BSP [1] there's a code for MMU/Cache init,
>>> however I don't know about Pi2 and where its code is.
>>> [1]
>>> https://github.com/RTEMS/rtems/tree/master/c/src/lib/libbsp/arm/raspberrypi
>>> On 2 Jun 2015 16:59, "Hesham ALMatary" <heshamelmatary at gmail.com> wrote:
>>> Hi,
>>> Aren't the MMU/Caches enabled by default for RPi [1]?
>>> [1]
>>> https://github.com/RTEMS/rtems/blob/master/c/src/lib/libbsp/arm/shared/mminit.c
>>> On Tue, Jun 2, 2015 at 12:18 PM, Joel Sherrill
>>> <joel.sherrill at oarcorp.com> wrote:
>>> On June 2, 2015 7:01:21 AM EDT, Rohini Kulkarni <krohini1593 at gmail.com>
>>> wrote:
>>> Dr. Joel,
>>> So we can't say something solely on the basis of this result?
>>> I don't think so. If Linux performs the same, then what you did is as
>>> good as it gets.
>>> However, if Linux is faster then some setting still isn't right.
>>> You need a reference measurement to have any confidence. It is possible
>>> you did something but didn't actually turn the cache (or all the cache)
>>> on.
>>> On 2 Jun 2015 16:28, "Rohini Kulkarni" <krohini1593 at gmail.com> wrote:
>>> I have not run it under linux on pi2 yet. Will have to run and check
>>> the result.
>>> On 2 Jun 2015 16:16, "Joel Sherrill" <joel.sherrill at oarcorp.com> wrote:
>>> On June 2, 2015 5:58:33 AM EDT, Rohini Kulkarni <krohini1593 at gmail.com>
>>> wrote:
>>> HI,
>>> I tried running the dhrystone benchmark with some changes for
>>> cache/mmu
>>> set up.
>>> However, the output shows a reduction in performance.
>>> The time to run through the dhrystone has increased from 12 to 13 and
>>> dhrystones run per second decreased.
>>> According to this result, things were better with caches disabled.
>>> I have been working on this since two days and could not figure out an
>>> improvement. Any pointers?
>>> How did it do under Linux on the Pi2?
>>> Thanks.
>>> On Thu, May 28, 2015 at 8:41 PM, Rohini Kulkarni
>>> Hi All,
>>> I have to implement the cache coherency support for Cortex A7. But for
>>> A7 MPCore, unlike for A9, I am not able to find any register
>>> description for the Snoop Control Unit from the TRM.
>>> I need help here on how to proceed.
>>> Additionally for A9 there is a single bit for A9 in the Auxiliary
>>> Control Register which enables cache broadcast operations. The
>>> register
>>> format is different for A7 and again I am unable to find how to
>>> achieve
>>> the same for A7.
>>> Thanks!
>>> On Tue, May 5, 2015 at 10:42 PM, Joel Sherrill
>>> On 5/5/2015 11:11 AM, Rohini Kulkarni wrote:
>>> Hi,
>>> I am working with the code for bsp hooks. I am referring to existing
>>> ARM multicore bsp codes, zync mainly.
>>> 1. There are existing hooks for the raspberry pi. Where should the
>>> code
>>> for the  Pi2 hooks be added?
>>> The Pi and Pi2 are remarkably similar so Pi2 should be placed inside
>>> the Pi BSP directory.
>>> There is already a Pi2 variant of that code built. But we know
>>> specific
>>> places where there
>>> are variances. Depending on the scope of what is different, it can be
>>> as simple as
>>> a cpp conditional in a .h to select a value or two implementations of
>>> a
>>> single method
>>> and the Makefile.am picking the right file to build based on the board
>>> variant.
>>> The big question to always ask is: Is this specific to the Pi2 and
>>> incompatible with the Pi?
>>> Since the Pi BSP is still missing capabilities, it is likely code
>>> common to both will
>>> be added this summer. For example, did the mailbox interface change? I
>>> don't know
>>> but would guess that it didn't.  Each new capability added needs that
>>> added.
>>> And any differences need to be analyzed to pick the least intrusive
>>> way
>>> to provide
>>> alternate implementations. Or enable special code like the Pi2 SMP
>>> support which
>>> is dependent on --enable-smp and being a Pi2.
>>> 2. Am I right in understanding that I will have to implement A7
>>> specific functions as have been for A9? I am referring specifically to
>>> the arm-a9mpcore-start.h
>>> Yes.
>>> If the code is very similar between the a7 and a9, then a discussion
>>> on devel@ should occur to decide the best way to minimize duplication.
>>> If you end up with a7 specific code, you should follow the location
>>> and
>>> naming patterns already established. That places it in
>>> libbsp/arm/shared/...
>>> so it can be used by any BSP with the right SMP core.
>>> I am referring to existing codes to locate and get hold of what needs
>>> to be done in the hooks. However, being new to such implementations, I
>>> am taking longer to understand the details. Any suggestions that might
>>> help here are welcome
>>> The answer will depend on the factors listed above. When code can
>>> be shared, we want to share it across as many BSPs as makes sense.
>>> When it is unique to a specific BSP **variant** (e.g. Pi vs Pi2), then
>>> you want to find the way to account for the variation in the least
>>> intrusive code way possible.
>>> Thanks!
>>> On 1 May 2015 12:45, "Rohini Kulkarni" <krohini1593 at gmail.com> wrote:
>>> Hi,
>>> Excited to be a part of  this edition of GSoC! Thanks to everybody for
>>> helping me get here and congratulations to all the participating
>>> students!
>>> So, now getting to work, firstly I wish to know, specifically from my
>>> mentors, any changes that must be made to my proposed project or
>>> schedule.
>>> Secondly, are there any specifics for the development blog that we
>>> need
>>> to create for the project? Over time what is the blog expected to
>>> convey.
>>> Also, I have to create a new wiki page for my project as none exists.
>>> I
>>> want to know how to add one.
>>> Rohini Kulkarni
>>> -- Joel Sherrill, Ph.D. Director of Research & Development
>>> joel.sherrill at OARcorp.com On-Line Applications Research Ask me about
>>> RTEMS: a free RTOS Huntsville AL 35805 Support Available (256)
>>> 722-9985
>>> Rohini Kulkarni
>>> Rohini Kulkarni
>>> --joel
>>> --joel
>>> devel mailing list
>>> devel at rtems.org
>>> http://lists.rtems.org/mailman/listinfo/devel
>>> Hesham
>>> Hesham
>>> devel mailing list
>>> devel at rtems.org
>> Rohini Kulkarni
> devel mailing list
> devel at rtems.org
