Error while compiling rtems main branch for sparc
Fri Jun 5 13:45:29 UTC 2015
Hi Saurabh,
This is a current problem in RTEMS. You need to have 'pax' installed
on your development host to build the dl tests. So, it looks good to
me!
Gedare
On Thu, Jun 4, 2015 at 9:16 PM, Saurabh Gadia <gadia at usc.edu> wrote:
> I am sorry for not attaching the patch and configuration command:
> ../rtems/configure --target=sparc-rtems4.11 --enable-rtemsbsp=sis
> --enable-tests --disable-posix ENABLE_STRICT_ORDER_MUTEX=1
> Thanks,
> Saurabh Gadia
> On Thu, Jun 4, 2015 at 6:08 PM, Saurabh Gadia <gadia at usc.edu> wrote:
>> Hi,
>> I worked out that bug related to strict_mutex and gone past that bug. But
>> now I have issue while compiling the libtests. Below is the error log:
>> sparc-rtems4.11-size syscall01.exe
>>    text       data        bss        dec        hex    filename
>>  266128       6064      11456     283648      45400    syscall01.exe
>> cp syscall01.exe syscall01.ralf
>> make[6]: Leaving directory
>> `/home/saurabh/dev1/kernel/b-sis/sparc-rtems4.11/c/sis/testsuites/libtests/syscall01'
>> Making all in dl01
>> make[6]: Entering directory
>> `/home/saurabh/dev1/kernel/b-sis/sparc-rtems4.11/c/sis/testsuites/libtests/dl01'
>> sparc-rtems4.11-gcc -B../../../../../sis/lib/ -specs bsp_specs -qrtems
>> -DHAVE_CONFIG_H -I.
>> -I../../../../../../../rtems/c/src/../../testsuites/libtests/dl01 -I..
>> -I../../../../../../../rtems/c/src/../../testsuites/libtests/../support/include
>> -mcpu=cypress -O2 -g -ffunction-sections -fdata-sections -Wall
>> -Wmissing-prototypes -Wimplicit-function-declaration -Wstrict-prototypes
>> -Wnested-externs -MT dl-o1.o -MD -MP -MF .deps/dl-o1.Tpo -c -o dl-o1.o
>> ../../../../../../../rtems/c/src/../../testsuites/libtests/dl01/dl-o1.c
>> mv -f .deps/dl-o1.Tpo .deps/dl-o1.Po
>> w -f dl.tar dl-o1.o
>>  17:44:17 up  2:31,  2 users,  load average: 2.27, 0.99, 0.53
>> USER     TTY        LOGIN@   IDLE   JCPU   PCPU WHAT
>> ../../../../../../tools/build/rtems-bin2c -C dl.tar dl-tar.c
>> cannot open dl.tar for reading
>> make[6]: *** [dl-tar.c] Error 1
>> make[5]: *** [all-local] Error 1
>> make[5]: Leaving directory
>> `/home/saurabh/dev1/kernel/b-sis/sparc-rtems4.11/c/sis/testsuites/libtests'
>> make[4]: *** [all] Error 2
>> make[4]: Leaving directory
>> make[3]: *** [all-recursive] Error 1
>> make[3]: Leaving directory
>> `/home/saurabh/dev1/kernel/b-sis/sparc-rtems4.11/c/sis/testsuites'
>> make[2]: *** [all-recursive] Error 1
>> make[2]: Leaving directory
>> `/home/saurabh/dev1/kernel/b-sis/sparc-rtems4.11/c/sis'
>> make[1]: *** [all-recursive] Error 1
>> make[1]: Leaving directory
>> `/home/saurabh/dev1/kernel/b-sis/sparc-rtems4.11/c'
>> make: *** [all-recursive] Error 1
>> saurabh at saurabh-Inspiron-N5010:~/dev1/kernel/b-sis$ ls
>> I am not able to find dl-tar.c but we have dl-tar.Po. Can anyone guide me
>> on this.  How should I proceed with this.
>> Thanks,
>> Saurabh Gadia
>> On Mon, Jun 1, 2015 at 7:48 AM, Saurabh Gadia <gadia at usc.edu> wrote:
>>> I am on it.
>>> On Monday, June 1, 2015, Gedare Bloom <gedare at rtems.org> wrote:
>>>> Hi Saurabh,
>>>> Please try to figure out how to fix the compile-error. You can see
>>>> that the problem occurs in the #ifdef'd STRICT_ORDER_MUTEX_CODE, so
>>>> that makes sense why others have not observed the same issue. It
>>>> appears you will have to reconcile the new _Thread_Change_priority
>>>> arguments with what is being used in that block of code. If you need
>>>> more guidance please ask.
>>>> Gedare
>>>> On Mon, Jun 1, 2015 at 12:35 AM, Saurabh Gadia <gadia at usc.edu> wrote:
>>>> > I wanted to test the ENABLE_STRICT_ORDER_MUTEX=1 related sptests for
>>>> > "nested
>>>> > mutex" GSOC project. So please let me know what can be done.
>>>> > Thanks,
>>>> > Saurabh Gadia
>>>> > On Sun, May 31, 2015 at 9:33 PM, Saurabh Gadia <gadia at usc.edu> wrote:
>>>> >> Hi,
>>>> >> so I am working for sparc-sis setting and master branch. And if you
>>>> >> see
>>>> >> the code in threadimpl.h and threadchangepriority.c and
>>>> >> coremutexsurrender.c
>>>> >> the definition of _Thread_Change_priority() is having mismatch
>>>> >> calling. Git
>>>> >> records says that there was change to above function structure done
>>>> >> by
>>>> >> sebastian huber. But I guess he forgot to change the definition of
>>>> >> _Thread_Change_priority() in threadimpl.h and call in
>>>> >> Configuration command:
>>>> >> ./configure --target=sparc-rtems4.11 --enable-rtemsbsp=sis
>>>> >> --enable-tests
>>>> >> Error Log:
>>>> >> In file included from
>>>> >> ../../cpukit/../../../sis/lib/include/rtems/score/coremuteximpl.h:24:0,
>>>> >>                  from
>>>> >> ../../../../../../rtems/c/src/../../cpukit/score/src/coremutexsurrender.c:23:
>>>> >> ../../cpukit/../../../sis/lib/include/rtems/score/threadimpl.h:394:6:
>>>> >> note: expected 'void *' but argument is of type 'int'
>>>> >>  void _Thread_Change_priority(
>>>> >> ../../../../../../rtems/c/src/../../cpukit/score/src/coremutexsurrender.c:60:7:
>>>> >> error: too few arguments to function '_Thread_Change_priority'
>>>> >>        _Thread_Change_priority( holder, mutex->queue.priority_before,
>>>> >> true
>>>> >>                  from
>>>> >> note: declared here
>>>> >> make[6]: *** [src/libscore_a-coremutexsurrender.o] Error 1
>>>> >> Thanks,
>>>> >> Saurabh Gadia
>>>> >> On Sun, May 31, 2015 at 8:25 PM, Nick Withers
>>>> >> <nick.withers at anu.edu.au>
>>>> >> wrote:
>>>> >>> Does re-running bootstrap in the source dir and re-configuring sort
>>>> >>> it?
>>>> >>> Nick Withers
>>>> >>> Embedded Systems Programmer
>>>> >>> Department of Nuclear Physics, Research School of Physics and
>>>> >>> Engineering
>>>> >>> The Australian National University (CRICOS: 00120C)
>>>> >>> On Sun, 2015-05-31 at 20:31 -0400, Joel Sherrill wrote:
>>>> >>> > More information is needed. Target architecture, bsp, configure
>>>> >>> > command.
>>>> >>> > I have been building all bsps regularly and unless it got broken
>>>> >>> > this
>>>> >>> > weekend, something else is up
>>>> >>> > On May 31, 2015 7:57:04 PM EDT, Saurabh Gadia <gadia at usc.edu>
>>>> >>> > wrote:
>>>> >>> > >The problem is on master branch
>>>> >>> > >Thanks,
>>>> >>> > >Saurabh Gadia
>>>> >>> > >On Sun, May 31, 2015 at 4:44 PM, Saurabh Gadia <gadia at usc.edu>
>>>> >>> > > wrote:
>>>> >>> > >Logs:
>>>> >>> > > >`/home/saurabh/dev1/kernel/b-sis/sparc-rtems4.11/c/sis/cpukit/score'
>>>> >>> > >make[6]: *** No rule to make target `src/apimutexislocked.c',
>>>> >>> > > needed
>>>> >>> > > by
>>>> >>> > >`src/libscore_a-apimutexislocked.o'.  Stop.
>>>> >>> > >make[5]: *** [all-recursive] Error 1
>>>> >>> > >There is no makefile but I am also not able to find
>>>> >>> > > apimutexislocked.c
>>>> >>> > >How do I proceed about this.
>>>> >>> > >Thanks,
>>>> >>> > >Saurabh Gadia
>>>> >>> > --joel
>>>> >>> > _______________________________________________
>>>> >>> > devel mailing list
>>>> >>> > devel at rtems.org
>>>> >>> > http://lists.rtems.org/mailman/listinfo/devel
>>>> > devel mailing list
>>>> > devel at rtems.org
>>> Thanks,
>>> Saurabh Gadia
