USB Host and MMC/SD Card Stack
Daniel Gutson daniel.gutson at tallertechnologies.com
Fri Jun 5 16:27:23 UTC 2015
Hi Sebastian,
   is this industrial-grade fully functional, or has known issues? If
it has, we could fix them.
Thanks,
   Daniel.
On Mon, May 18, 2015 at 4:01 AM, Sebastian Huber
> On 16/05/15 20:53, Afshin Jamaali (Arian) wrote:
>> Hi Sebastian,
>> Sorry, it seems a problem exists. The link
>> "http://git.rtems.org/rtems-libbsd.git/" says:
>> "No repositories found"
> Sorry, the right link is:
> https://git.rtems.org/rtems-libbsd
>> Best Regards,
>> Afshin Jamaali
>> -----Original Message-----
>> From: devel [mailto:devel-bounces at rtems.org] On Behalf Of Sebastian Huber
>> Sent: Friday, May 15, 2015 18:25
>> To: devel at rtems.org
>> Subject: Re: USB Host and MMC/SD Card Stack
>> Hello,
>> the USB host and MMC/SD card stack for RTEMS is now available via the
>> libbsd:
>> I will remove my libusb repository to avoid confusion.
>> On 27/08/14 14:19, Sebastian Huber wrote:
>>> Hello,
>>> I added a USB host and MMC/SD card stack for RTEMS (libusb) to my Git
>>> repository area:
>>> http://git.rtems.org/sebh/rtems-libusb.git/
>>> It was previously only available as a snapshot:
>>> https://www.rtems.org/bugzilla/show_bug.cgi?id=1601
>>> The USB host stack is a port from FreeBSD 8.  The MMC/SD card stack is
>>> a port from FreeBSD 9.3.
>>> The libusb is a subset an older version of the libbsd which contains
>>> also the network stack from FreeBSD 9.3.  We use libusb on some boards
>>> and projects.  I simply had no time to test the USB and MMC/SD parts
>>> in libbsd.
>>> http://git.rtems.org/rtems-libbsd/
>>> Both libraries lack documentation.  The basic network stack in libbsd
>>> works well, but more work is required to polish it.
>> Sebastian Huber, embedded brains GmbH
>> Address : Dornierstr. 4, D-82178 Puchheim, Germany
>> Phone   : +49 89 189 47 41-16
>> Fax     : +49 89 189 47 41-09
>> E-Mail  : sebastian.huber at embedded-brains.de
>> PGP     : Public key available on request.
>> Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
>> devel mailing list
>> devel at rtems.org
> devel mailing list
> devel at rtems.org
Daniel F. Gutson
Chief Engineering Officer, SPD
San Lorenzo 47, 3rd Floor, Office 5
Córdoba, Argentina
Phone:   +54 351 4217888 / +54 351 4218211
Skype:    dgutson
LinkedIn: http://ar.linkedin.com/in/danielgutson
