rtems-libbsd waf params
Yurii Shevtsov ungetch at gmail.com
Fri Jun 5 18:38:03 UTC 2015
2015-06-05 21:02 GMT+03:00 Sujay Raj <sujayraaj at gmail.com>:
> From what I could make out from the documentation in README.waf,
> in waf configure , --prefix is where you would like to install rtems-libbsd,
> --rtems is where you installed your bsp, that is, the '--prefix' you
> passed while configuring the bsp.
> '--rtems-tools' points to the tool-set you built using RSB (the
> --prefix you passed to the RSB) and
> '--rtems-bsps' should be provided with the string 'architecture/bsp'.
>  (everything without quotes, quotes are just for illustration)
> usually --prefix and --rtems would have the same value, but it depends
> on how you are setting things up.
Thanks, I'll try.
> Further, from libbsd.txt, in config.inc BSP should only be the name of
> your BSP, not c/raspberrypi/make.
Can't agree with you here. This path is exactly what is needed for
successful build
> See if this helps.
> Regards
> On Fri, Jun 5, 2015 at 10:47 PM, Yurii Shevtsov <ungetch at gmail.com> wrote:
>> Since 'waf' requires four params and 'make' only three in config.inc,
>> I got confused with waf. Could anyone help me with waf params? Here is
>> my config.inc:
>>   TARGET = arm-rtems4.11
>>   BSP = c/raspberrypi/make
>>   PREFIX = /home/gtament/development/rtems/src/b-rpi
>> Thanks in advance)
>> devel mailing list
>> devel at rtems.org
