USB Host and MMC/SD Card Stack
Daniel Gutson daniel.gutson at tallertechnologies.com
Tue Jun 9 14:35:52 UTC 2015
Thanks Sebastian.
We will use it in the BeagleBone Black BSD.
On Tue, Jun 9, 2015 at 4:16 AM, Sebastian Huber
> Hello Daniel,
> the USB host and MMC/SD card stack is from FreeBSD 9. It works quite well on
> our targets.
> On 05/06/15 18:27, Daniel Gutson wrote:
>> Hi Sebastian,
>>     is this industrial-grade fully functional, or has known issues? If
>> it has, we could fix them.
>> Thanks,
>>     Daniel.
>> On Mon, May 18, 2015 at 4:01 AM, Sebastian Huber
>>> On 16/05/15 20:53, Afshin Jamaali (Arian) wrote:
>>>> Hi Sebastian,
>>>> Sorry, it seems a problem exists. The link
>>>> "http://git.rtems.org/rtems-libbsd.git/" says:
>>>> "No repositories found"
>>> Sorry, the right link is:
>>> https://git.rtems.org/rtems-libbsd
>>>> Best Regards,
>>>> Afshin Jamaali
>>>> -----Original Message-----
>>>> From: devel [mailto:devel-bounces at rtems.org] On Behalf Of Sebastian
>>>> Huber
>>>> Sent: Friday, May 15, 2015 18:25
>>>> To: devel at rtems.org
>>>> Subject: Re: USB Host and MMC/SD Card Stack
>>>> Hello,
>>>> the USB host and MMC/SD card stack for RTEMS is now available via the
>>>> libbsd:
>>>> I will remove my libusb repository to avoid confusion.
>>>> On 27/08/14 14:19, Sebastian Huber wrote:
>>>>> Hello,
>>>>> I added a USB host and MMC/SD card stack for RTEMS (libusb) to my Git
>>>>> repository area:
>>>>> http://git.rtems.org/sebh/rtems-libusb.git/
>>>>> It was previously only available as a snapshot:
>>>>> https://www.rtems.org/bugzilla/show_bug.cgi?id=1601
>>>>> The USB host stack is a port from FreeBSD 8.  The MMC/SD card stack is
>>>>> a port from FreeBSD 9.3.
>>>>> The libusb is a subset an older version of the libbsd which contains
>>>>> also the network stack from FreeBSD 9.3.  We use libusb on some boards
>>>>> and projects.  I simply had no time to test the USB and MMC/SD parts
>>>>> in libbsd.
>>>>> http://git.rtems.org/rtems-libbsd/
>>>>> Both libraries lack documentation.  The basic network stack in libbsd
>>>>> works well, but more work is required to polish it.
>>>> Sebastian Huber, embedded brains GmbH
>>>> Address : Dornierstr. 4, D-82178 Puchheim, Germany
>>>> Phone   : +49 89 189 47 41-16
>>>> Fax     : +49 89 189 47 41-09
>>>> E-Mail  : sebastian.huber at embedded-brains.de
>>>> PGP     : Public key available on request.
>>>> Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
>>>> _______________________________________________
>>>> devel mailing list
>>>> devel at rtems.org
>>>> http://lists.rtems.org/mailman/listinfo/devel
>>> devel mailing list
>>> devel at rtems.org
Daniel F. Gutson
Chief Engineering Officer, SPD
San Lorenzo 47, 3rd Floor, Office 5
Córdoba, Argentina
Phone:   +54 351 4217888 / +54 351 4218211
Skype:    dgutson
LinkedIn: http://ar.linkedin.com/in/danielgutson
