4.11 Release Description Help Needed
Tue Jun 9 18:45:03 UTC 2015
----- Sebastian Huber <sebastian.huber at embedded-brains.de> schrieb:
> On 03/06/15 12:59, Joel Sherrill wrote:
> > On June 3, 2015 4:34:31 AM EDT, Sebastian Huber<sebastian.huber at embedded-brains.de>  wrote:
> >> >Hi,
> >> >I added some points. What is a bit confusing is that the documentation
> >> >is not up to date, e.g.
> >> >https://docs.rtems.org/doc-current/share/rtems/html/bsp_howto/Clock-Driver.html#Clock-Driver
> >> >still reflects the old clock driver API.
> > Is it fixed in the source and just needs regenerating on the server? Or is there writing to do?
> I fixed this in the sources some time ago.  It seems that the automatic
> updated doesn't work.
The documentation is still not up to date.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
