usb01.exe from rtems-libbsd testsuites gives no output
Gedare Bloom gedare at gwu.edu
Mon Jun 15 19:21:20 UTC 2015
If you haven't already, I'd suggest building and running libbsd for a
known-to-work target (probably the realview pbx a9 qemu) as well, so
you can have confidence in your tools and the libbsd sources. Are you
building it with make or with waf?
There are a list of tests in libbsd.txt that don't need network to
run. Perhaps you should try those (without your modifications first)?
Gedare
On Mon, Jun 15, 2015 at 3:05 PM, Yurii Shevtsov <ungetch at gmail.com> wrote:
> This is "Please, pay attention" message. I really need help. Also I
> still can't start working with the latest libbsd repo because of this
> https://lists.rtems.org/pipermail/users/2015-June/029005.html
> Thanks in advance, and excuse me, if my questions seem stupid
> 2015-06-13 13:56 GMT+03:00 Yurii Shevtsov <ungetch at gmail.com>:
>> I compiled it from repo with latest commit
>> 66ec94a3fc3c41470f90b7d20913ea1fafc019a9
>> Tried to run it on RPi with uboot. Boot approach is OK, because
>> testsuites from rtems samples are running normally. I thought ported
>> driver hangs system, but then I commented out USB init macro and also
>> added some printf to the beginning of Init() proc and still got no
>> output. RPi is connected through Serial. Now I'm trying to setup QEMU,
>> maybe I would get some more info. Also feel free to suggest some other
>> testsuite, which can help me testing ported driver.
>> Thanks in advance)
> devel mailing list
> devel at rtems.org
