GSOC 2015: Configuration GUI
Gedare Bloom gedare at gwu.edu
Mon Jun 15 23:07:05 UTC 2015
I just had one comment from reading the code, it lacks any code-level
documentation. Granted it is simple now, but as it grows so should the
doc.
Also, make sure to watch out for when to break out into more
functions/modules. Avoid the pitfall of "one block of code to rule
them all"
-Gedare
On Mon, Jun 15, 2015 at 6:49 PM, Amar Takhar <amar at rtems.org> wrote:
> On 2015-06-15 23:52 +0530, Anand Krishnan wrote:
>> Hi all,
>> Currently I have uploaded the first part of the gui - just plain menus (with no
>> event handlers yet) to my github: github.com/anandkp92/waf/gui/menu.py . The
>> purpose of the GUI is for creating the config.cfg file for "waf config" of the
>> waf version of RTEMS.
> Looks good so far.
>> I think you might need wxpython also to view it right now: http://
>> www.pygopar.com/installing-wxpython-3-on-ubuntu14-04/
> Everyone here will be able to sort that out, thanks for the help. :)
>> The main thing I want to get reviewed on is the code. I am planning to have
>> different classes for menus, tabs, groups etc and a main class that creates
>> multiple instances of each and puts it all together.
> It seems like a good start.
>> Correct me if I am wrong:
>> For the File options->
>> 1) New ->  Opens a new instance with all the configuration options set to
>> default again.
> Yes.
>> 2) Save -> Save the configuration options chosen so far.
> Yes.
>> 3) Open -> Open a previously saved set of configuration options.
> Yep.
>> Once this is cleared, I shall move on to implementing these.
> OK.
>> Please keep in mind this is a very crude version and the first part of many
>> parts.
> Right.  Lay out the panes and other UI Details before getting on to actual
> options.  I will help you with that.
> You will also need to decide how each option should be displayed.
> Amar.
> devel mailing list
> devel at rtems.org
