[rtems-libbsd commit] Add BDS command support headers.
Sebastian Huber
Wed Jun 17 11:17:03 UTC 2015
On 16/06/15 05:21, Chris Johns wrote:
> Module: rtems-libbsd
> Branch: master
> Commit: affed5e3f586860e2fd97445eaa20674dc4bcd25
> Changeset: http://git.rtems.org/rtems-libbsd/commit/?id=affed5e3f586860e2fd97445eaa20674dc4bcd25
> Author: Chris Johns <chrisj at rtems.org>
> Date: Tue Jun 16 13:20:15 2015 +1000
> freebsd/contrib/tcpdump/tcpdump.c | 6 ++++--
> 1 file changed, 4 insertions(+), 2 deletions(-)
> diff --git a/freebsd/contrib/tcpdump/tcpdump.c b/freebsd/contrib/tcpdump/tcpdump.c
> index 32ffb45..00e44db 100644
> --- a/freebsd/contrib/tcpdump/tcpdump.c
> +++ b/freebsd/contrib/tcpdump/tcpdump.c
> @@ -55,6 +55,8 @@ static const char rcsid[] _U_ =
> #define __need_getopt_newlib
> #include <getopt.h>
> #define setpriority(a, b, c)
> +#include <machine/rtems-bsd-program.h>
> +#include <machine/rtems-bsd-commands.h>
Every RTEMS specific change should be in #ifdef __rtems__ sections. This
is very helpful if you have to review files. This is missing in a couple
of files.
There is not much documentation, but at least this is in libbsd.txt:
=== Rules for Modifying FreeBSD Source
Only add lines. Subtract code by added `#ifndef __rtems__`. This makes
merging easier in the future. For example:
/* Global variables for the kernel. */
#ifndef __rtems__
/* 1.1 */
extern char kernelname[MAXPATHLEN];
#endif /* __rtems__ */
extern int tick; /* usec per tick (1000000 / hz) */
#if defined(_KERNEL) || defined(_WANT_FILE)
#ifdef __rtems__
#include <rtems/libio_.h>
#include <sys/fcntl.h>
* Kernel descriptor table.
* One entry for each open kernel vnode and socket.
* Below is the list of locks that protects members in struct file.
* (f) protected with mtx_lock(mtx_pool_find(fp))
* (d) cdevpriv_mtx
* none not locked
extern int profprocs; /* number of process's profiling */
#ifndef __rtems__
extern volatile int ticks;
#else /* __rtems__ */
#define ticks _Watchdog_Ticks_since_boot
#endif /* _KERNEL */
Add nothing (even blank lines) before or after the `__rtems__` guards.
Always
include a `__rtems__` in the guards to make searches easy.
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
