GSOC 2015: Configuration GUI
Anand Krishnan
anandkp92 at gmail.com
Thu Jun 18 00:27:35 UTC 2015
Hi all,
I've almost prepared the basic layout for the GUI. Also added some dummy
event handlers for File Menu.
Any more suggestions before fetching the options?
Code at : https://github.com/anandkp92/waf/tree/waf/gui
Thanks,
Anand
On Tue, Jun 16, 2015 at 10:45 AM, Anand Krishnan <anandkp92 at gmail.com>
wrote:
> Thomas: Apologies. This is the right link:
> https://github.com/anandkp92/waf/blob/waf/gui/menu.py
> Thanks for the other input. I'll take care of in-code documentation and
> making the code modular.
> I'll work on the tabs next.
> Regards,
> Anand
> On Tue, Jun 16, 2015 at 4:37 AM, Gedare Bloom <gedare at gwu.edu> wrote:
>> I just had one comment from reading the code, it lacks any code-level
>> documentation. Granted it is simple now, but as it grows so should the
>> doc.
>> Also, make sure to watch out for when to break out into more
>> functions/modules. Avoid the pitfall of "one block of code to rule
>> them all"
>> -Gedare
>> On Mon, Jun 15, 2015 at 6:49 PM, Amar Takhar <amar at rtems.org> wrote:
>> > On 2015-06-15 23:52 +0530, Anand Krishnan wrote:
>> >> Hi all,
>> >> Currently I have uploaded the first part of the gui - just plain menus
>> (with no
>> >> event handlers yet) to my github: github.com/anandkp92/waf/gui/menu.py
>> . The
>> >> purpose of the GUI is for creating the config.cfg file for "waf
>> config" of the
>> >> waf version of RTEMS.
>> > Looks good so far.
>> >> I think you might need wxpython also to view it right now: http://
>> >> www.pygopar.com/installing-wxpython-3-on-ubuntu14-04/
>> > Everyone here will be able to sort that out, thanks for the help. :)
>> >> The main thing I want to get reviewed on is the code. I am planning to
>> have
>> >> different classes for menus, tabs, groups etc and a main class that
>> creates
>> >> multiple instances of each and puts it all together.
>> > It seems like a good start.
>> >> Correct me if I am wrong:
>> >> For the File options->
>> >> 1) New -> Opens a new instance with all the configuration options set
>> to
>> >> default again.
>> > Yes.
>> >> 2) Save -> Save the configuration options chosen so far.
>> > Yes.
>> >> 3) Open -> Open a previously saved set of configuration options.
>> > Yep.
>> >> Once this is cleared, I shall move on to implementing these.
>> > OK.
>> >> Please keep in mind this is a very crude version and the first part of
>> many
>> >> parts.
>> > Right. Lay out the panes and other UI Details before getting on to
>> actual
>> > options. I will help you with that.
>> > You will also need to decide how each option should be displayed.
>> > Amar.
>> > _______________________________________________
>> > devel mailing list
>> > devel at rtems.org
>> > http://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20150618/60a10a89/attachment.html>
