Xilinx Zynq A8 Qemu BSP with libbsd.
Fri Jun 19 07:44:23 UTC 2015
Hi,
I have just pushed a change to libbsd that disabled the IP header
hardware checksum for the Cadence driver which is used on the Xilinx Zynq.
If you are using the RSB qemu this tests should run.
There is known issue with some tests where the Init task delete's itself
and ends qemu. I am not sure why this is happening.
