Xilinx Zynq A8 Qemu BSP with libbsd.
Fri Jun 19 14:00:11 UTC 2015
On June 19, 2015 2:44:23 AM CDT, Chris Johns <chrisj at rtems.org> wrote:
>Hi,
>I have just pushed a change to libbsd that disabled the IP header
>hardware checksum for the Cadence driver which is used on the Xilinx
>Zynq.
Is this a bug on real hardware as well? Or specific to qemu?
If broken in qemu, works this be better with a kennel hint until fixed in qemu.
>If you are using the RSB qemu this tests should run.
>There is known issue with some tests where the Init task delete's
>itself
>and ends qemu. I am not sure why this is happening.
That is weird.
>Chris
>_______________________________________________
>devel mailing list
>devel at rtems.org
>http://lists.rtems.org/mailman/listinfo/devel
--joel
