[PATCH] rtems: Add rtems_interrupt_local_disable|enable()
Fri Jun 19 21:02:48 UTC 2015
Add rtems_interrupt_local_disable|enable() as suggested by Pavel Pisa to
emphasize that interrupts are only disabled on the current processor.
Do not define the rtems_interrupt_disable|enable|flash() macros and
functions on SMP configurations since they don't ensure system wide
mutual exclusion.
 c/src/lib/libbsp/shared/bootcard.c      |   2 +-
 cpukit/rtems/include/rtems/rtems/intr.h |  38 ++++++++
 cpukit/rtems/src/intrbody.c             |   4 +
 doc/user/intr.t                         |  94 ++++++++++++++++++
 testsuites/libtests/heapwalk/init.c     |   4 +-
 testsuites/samples/Makefile.am          |   3 +
 testsuites/samples/configure.ac         |   2 +
 testsuites/sptests/sp37/init.c          | 164 ++++++++++++++++++--------------
 testsuites/sptests/sp40/init.c          |   6 +-
 testsuites/tmtests/tm26/task1.c         |   9 +-
 10 files changed, 244 insertions(+), 82 deletions(-)
diff --git a/c/src/lib/libbsp/shared/bootcard.c b/c/src/lib/libbsp/shared/bootcard.c
index 4f91aa9..0ee5e12 100644
--- a/c/src/lib/libbsp/shared/bootcard.c
+++ b/c/src/lib/libbsp/shared/bootcard.c
@@ -72,7 +72,7 @@ void boot_card(
    *  Make sure interrupts are disabled.
   (void) bsp_isr_level;
-  rtems_interrupt_disable( bsp_isr_level );
+  rtems_interrupt_local_disable( bsp_isr_level );
   bsp_boot_cmdline = cmdline;
diff --git a/cpukit/rtems/include/rtems/rtems/intr.h b/cpukit/rtems/include/rtems/rtems/intr.h
index 259120f..d084959 100644
--- a/cpukit/rtems/include/rtems/rtems/intr.h
+++ b/cpukit/rtems/include/rtems/rtems/intr.h
@@ -89,10 +89,15 @@ rtems_status_code rtems_interrupt_catch(
 #endif
+#if !defined(RTEMS_SMP)
  *  @brief Disable RTEMS Interrupt
  *  @note The interrupt level shall be of type @ref rtems_interrupt_level.
+ *  This macro is only available on uni-processor configurations.  The macro
+ *  rtems_interrupt_local_disable() is available on all configurations.
 #define rtems_interrupt_disable( _isr_cookie ) \
     _ISR_Disable(_isr_cookie)
@@ -101,6 +106,9 @@ rtems_status_code rtems_interrupt_catch(
  *  @brief Enable RTEMS Interrupt
+ *  rtems_interrupt_local_enable() is available on all configurations.
 #define rtems_interrupt_enable( _isr_cookie ) \
     _ISR_Enable(_isr_cookie)
@@ -109,10 +117,40 @@ rtems_status_code rtems_interrupt_catch(
  *  @brief Flash RTEMS Interrupt
+ *  rtems_interrupt_local_disable() and rtems_interrupt_local_enable() is
+ *  available on all configurations.
 #define rtems_interrupt_flash( _isr_cookie ) \
     _ISR_Flash(_isr_cookie)
+#endif /* RTEMS_SMP */
+ * @brief This macro disables the interrupts on the current processor.
+ * On SMP configurations this will not ensure system wide mutual exclusion.
+ * Use interrupt locks instead.
+ * @param[in] _isr_cookie The previous interrupt level is returned.  The type
+ *   of this variable must be rtems_interrupt_level.
+ * @see rtems_interrupt_local_enable().
+#define rtems_interrupt_local_disable( _isr_cookie ) \
+  _ISR_Disable_without_giant( _isr_cookie )
+ * @brief This macro restores the previous interrupt level on the current
+ * processor.
+ * @param[in] _isr_cookie The previous interrupt level returned by
+ *   rtems_interrupt_local_disable().
+#define rtems_interrupt_local_enable( _isr_cookie ) \
+  _ISR_Enable_without_giant( _isr_cookie )
  *  @brief RTEMS Interrupt Is in Progress
diff --git a/cpukit/rtems/src/intrbody.c b/cpukit/rtems/src/intrbody.c
index 6b37eb2..deb0dc0 100644
--- a/cpukit/rtems/src/intrbody.c
+++ b/cpukit/rtems/src/intrbody.c
@@ -23,6 +23,8 @@
 #include <rtems/score/isr.h>
 #include <rtems/rtems/intr.h>
  *  Undefine all of these is normally a macro and we want a real body in
  *  the library for other language bindings.
@@ -70,3 +72,5 @@ bool rtems_interrupt_is_in_progress( void )
   return _ISR_Is_in_progress();
diff --git a/doc/user/intr.t b/doc/user/intr.t
index 6cb6a26..cf106f3 100644
--- a/doc/user/intr.t
+++ b/doc/user/intr.t
@@ -21,6 +21,8 @@ directive:
 @item @code{@value{DIRPREFIX}interrupt_disable} - Disable Interrupts
 @item @code{@value{DIRPREFIX}interrupt_enable} - Enable Interrupts
 @item @code{@value{DIRPREFIX}interrupt_flash} - Flash Interrupt
+ at item @code{@value{DIRPREFIX}interrupt_local_disable} - Disable Interrupts on Current Processor
+ at item @code{@value{DIRPREFIX}interrupt_local_enable} - Enable Interrupts on Current Processor
 @item @code{@value{DIRPREFIX}interrupt_lock_initialize} - Initialize an ISR Lock
 @item @code{@value{DIRPREFIX}interrupt_lock_acquire} - Acquire an ISR Lock
 @item @code{@value{DIRPREFIX}interrupt_lock_release} - Release an ISR Lock
@@ -397,6 +399,10 @@ This directive will not cause the calling task to be preempted.
 parameter.}
 @end ifset
+This directive is only available on uni-processor configurations.  The
+directive @code{@value{DIRPREFIX}interrupt_local_disable} is available on all
+configurations.
 @c
 @c
 @c
@@ -441,6 +447,9 @@ and will be enabled when this directive returns to the caller.
+directive @code{@value{DIRPREFIX}interrupt_local_enable} is available on all
+configurations.
 @c
 @c
@@ -486,6 +495,91 @@ and will be redisabled when this directive returns to the caller.
+directives @code{@value{DIRPREFIX}interrupt_local_disable} and
+ at code{@value{DIRPREFIX}interrupt_local_enable} is available on all
+configurations.
+ at c
+ at c
+ at c
+ at page
+ at subsection INTERRUPT_LOCAL_DISABLE - Disable Interrupts on Current Processor
+ at cindex disable interrupts
+ at subheading CALLING SEQUENCE:
+ at ifset is-C
+ at findex rtems_interrupt_local_disable
+ at example
+void rtems_interrupt_local_disable(
+  rtems_interrupt_level  level
+/* this is implemented as a macro and sets level as a side-effect */
+ at end example
+ at end ifset
+ at subheading DIRECTIVE STATUS CODES:
+NONE
+ at subheading DESCRIPTION:
+This directive disables all maskable interrupts and returns
+the previous @code{level}.  A later invocation of the
+ at code{@value{DIRPREFIX}interrupt_local_enable} directive should be used to
+restore the interrupt level.
+ at subheading NOTES:
+This directive will not cause the calling task to be preempted.
+ at ifset is-C
+ at b{This directive is implemented as a macro which modifies the @code{level}
+parameter.}
+ at end ifset
+On SMP configurations this will not ensure system wide mutual exclusion.  Use
+interrupt locks instead.
+ at c
+ at c
+ at c
+ at page
+ at subsection INTERRUPT_LOCAL_ENABLE - Enable Interrupts on Current Processor
+ at cindex enable interrupts
+ at ifset is-C
+ at findex rtems_interrupt_local_enable
+ at example
+void rtems_interrupt_local_enable(
+ at end example
+ at end ifset
+NONE
+This directive enables maskable interrupts to the @code{level}
+which was returned by a previous call to
+ at code{@value{DIRPREFIX}interrupt_local_disable}.
+Immediately prior to invoking this directive, maskable interrupts should
+be disabled by a call to @code{@value{DIRPREFIX}interrupt_local_disable}
+and will be enabled when this directive returns to the caller.
 @c
 @c
 @c
diff --git a/testsuites/libtests/heapwalk/init.c b/testsuites/libtests/heapwalk/init.c
index 80073e8..3bd6c91 100644
--- a/testsuites/libtests/heapwalk/init.c
+++ b/testsuites/libtests/heapwalk/init.c
@@ -94,12 +94,12 @@ static void test_system_not_up(void)
   puts( "start with a system state != SYSTEM_STATE_UP" );
-  rtems_interrupt_disable( level );
+  rtems_interrupt_local_disable( level );
   System_state_Codes state = _System_state_Get();
   _System_state_Set( SYSTEM_STATE_TERMINATED );
   test_call_heap_walk( true );
   _System_state_Set( state );
-  rtems_interrupt_enable( level );
+  rtems_interrupt_local_enable( level );
 static void test_check_control(void)
diff --git a/testsuites/samples/Makefile.am b/testsuites/samples/Makefile.am
index 08455d3..374617b 100644
--- a/testsuites/samples/Makefile.am
+++ b/testsuites/samples/Makefile.am
@@ -18,8 +18,11 @@ endif
 if NETTESTS
 ## loopback tests a network loopback interface
 _SUBDIRS += loopback
+if HAS_SMP
+else
 _SUBDIRS += pppd
 endif
+endif
 include $(top_srcdir)/../automake/test-subdirs.am
 include $(top_srcdir)/../automake/local.am
diff --git a/testsuites/samples/configure.ac b/testsuites/samples/configure.ac
index e6f12d0..91a3661 100644
--- a/testsuites/samples/configure.ac
+++ b/testsuites/samples/configure.ac
@@ -26,6 +26,7 @@ RTEMS_CHECK_CUSTOM_BSP(RTEMS_BSP)
 RTEMS_CHECK_CPUOPTS([RTEMS_MULTIPROCESSING])
 RTEMS_CHECK_CXX(RTEMS_BSP)
 RTEMS_CHECK_CPUOPTS([RTEMS_NETWORKING])
+RTEMS_CHECK_CPUOPTS([RTEMS_SMP])
 CXXTESTS=$HAS_CPLUSPLUS
 AS_IF([test $HAS_CPLUSPLUS = yes],[
@@ -52,6 +53,7 @@ AS_IF([test $HAS_CPLUSPLUS = yes],[
 AM_CONDITIONAL([CXXTESTS],[test $CXXTESTS = "yes"])
 AM_CONDITIONAL(NETTESTS,test "$rtems_cv_RTEMS_NETWORKING" = "yes")
 AM_CONDITIONAL(MPTESTS,test "$rtems_cv_RTEMS_MULTIPROCESSING" = "yes")
+AM_CONDITIONAL(HAS_SMP,test "$rtems_cv_RTEMS_SMP" = "yes")
 # FIXME: We should get rid of this. It's a cludge.
 AC_CHECK_SIZEOF([time_t])
diff --git a/testsuites/sptests/sp37/init.c b/testsuites/sptests/sp37/init.c
index 0846491..a963a30 100644
--- a/testsuites/sptests/sp37/init.c
+++ b/testsuites/sptests/sp37/init.c
@@ -243,8 +243,7 @@ static void test_clock_tick_functions( void )
   rtems_interrupt_level level;
   Watchdog_Interval saved_ticks;
-  _Thread_Disable_dispatch();
   saved_ticks = _Watchdog_Ticks_since_boot;
@@ -287,16 +286,19 @@ static void test_clock_tick_functions( void )
   _Watchdog_Ticks_since_boot = saved_ticks;
-  _Thread_Enable_dispatch();
 void test_interrupt_inline(void)
+  rtems_interrupt_level level_1;
   rtems_mode            level_mode_body;
   rtems_mode            level_mode_macro;
   bool                  in_isr;
+  uint32_t              isr_level_0;
+  uint32_t              isr_level_1;
+  uint32_t              isr_level_2;
   puts( "interrupt is in progress (use body)" );
   in_isr = rtems_interrupt_is_in_progress();
@@ -305,20 +307,33 @@ void test_interrupt_inline(void)
     rtems_test_exit( 0 );
   puts( "interrupt disable (use inline)" );
   puts( "interrupt flash (use inline)" );
   rtems_interrupt_flash( level );
   puts( "interrupt enable (use inline)" );
+  isr_level_0 = _ISR_Get_level();
+  rtems_test_assert( isr_level_0 == 0 );
+  isr_level_1 = _ISR_Get_level();
+  rtems_test_assert( isr_level_1 != isr_level_0 );
+  rtems_interrupt_local_disable( level_1 );
+  isr_level_2 = _ISR_Get_level();
+  rtems_test_assert( isr_level_2 == isr_level_1 );
+  rtems_interrupt_local_enable( level_1 );
+  rtems_test_assert( _ISR_Get_level() == isr_level_1 );
+  rtems_test_assert( _ISR_Get_level() == isr_level_0 );
   puts( "interrupt level mode (use inline)" );
   level_mode_body = rtems_interrupt_level_body( level );
@@ -328,7 +343,10 @@ void test_interrupt_inline(void)
 volatile int isr_in_progress_body;
+#endif
 volatile int isr_in_progress_inline;
 void check_isr_in_progress_inline(void)
@@ -336,25 +354,6 @@ void check_isr_in_progress_inline(void)
   isr_in_progress_inline = rtems_interrupt_is_in_progress() ? 1 : 2;
-#undef rtems_interrupt_disable
-extern rtems_interrupt_level rtems_interrupt_disable(void);
-#undef rtems_interrupt_enable
-extern void rtems_interrupt_enable(rtems_interrupt_level previous_level);
-#undef rtems_interrupt_flash
-extern void rtems_interrupt_flash(rtems_interrupt_level previous_level);
-#undef rtems_interrupt_is_in_progress
-extern bool rtems_interrupt_is_in_progress(void);
-rtems_timer_service_routine test_isr_in_progress(
-  rtems_id  timer,
-  void     *arg
-  check_isr_in_progress_inline();
-  isr_in_progress_body = rtems_interrupt_is_in_progress() ? 1 : 2;
 void check_isr_worked(
   char *s,
   int   result
@@ -429,16 +428,72 @@ rtems_timer_service_routine test_unblock_task(
   directive_failed( status, "rtems_task_resume" );
+#undef rtems_interrupt_disable
+extern rtems_interrupt_level rtems_interrupt_disable(void);
+#undef rtems_interrupt_enable
+extern void rtems_interrupt_enable(rtems_interrupt_level previous_level);
+#undef rtems_interrupt_flash
+extern void rtems_interrupt_flash(rtems_interrupt_level previous_level);
+#undef rtems_interrupt_is_in_progress
+extern bool rtems_interrupt_is_in_progress(void);
+static void test_interrupt_body(void)
+  rtems_interrupt_level level;
+  rtems_mode            level_mode_body;
+  rtems_mode            level_mode_macro;
+  bool                  in_isr;
+  puts( "interrupt disable (use body)" );
+  level = rtems_interrupt_disable();
+  puts( "interrupt flash (use body)" );
+  rtems_interrupt_flash( level );
+  puts( "interrupt enable (use body)" );
+  rtems_interrupt_enable( level );
+  puts( "interrupt level mode (use body)" );
+  level_mode_body = rtems_interrupt_level_body( level );
+  level_mode_macro = RTEMS_INTERRUPT_LEVEL(level);
+  if ( level_mode_macro == level_mode_body ) {
+    puts("test seems to work");
+   *  Test interrupt bodies
+  puts( "interrupt is in progress (use body)" );
+  in_isr = rtems_interrupt_is_in_progress();
+  if ( in_isr ) {
+    puts( "interrupt reported to be is in progress (body)" );
+    rtems_test_exit( 0 );
+rtems_timer_service_routine test_isr_in_progress(
+  rtems_id  timer,
+  void     *arg
+  check_isr_in_progress_inline();
+  isr_in_progress_body = rtems_interrupt_is_in_progress() ? 1 : 2;
+#endif
 rtems_task Init(
   rtems_task_argument argument
   rtems_time_of_day     time;
   rtems_status_code     status;
-  rtems_interrupt_level level;
-  rtems_mode            level_mode_body;
-  rtems_mode            level_mode_macro;
-  bool                  in_isr;
   rtems_id              timer;
   int                   i;
@@ -523,47 +578,8 @@ rtems_task Init(
        break;
-   *  Test interrupt inline versions
   test_interrupt_inline();
-   *  Test interrupt bodies
-  puts( "interrupt is in progress (use body)" );
-  in_isr = rtems_interrupt_is_in_progress();
-  if ( in_isr ) {
-    puts( "interrupt reported to be is in progress (body)" );
-    rtems_test_exit( 0 );
-  puts( "interrupt disable (use body)" );
-  level = rtems_interrupt_disable();
-  puts( "interrupt flash (use body)" );
-  rtems_interrupt_flash( level );
-  puts( "interrupt enable (use body)" );
-  puts( "interrupt level mode (use body)" );
-  level_mode_body = rtems_interrupt_level_body( level );
-  level_mode_macro = RTEMS_INTERRUPT_LEVEL(level);
-  if ( level_mode_macro == level_mode_body ) {
-    puts("test seems to work");
+  test_interrupt_body();
    * Test ISR in progress from actual ISR
@@ -576,7 +592,9 @@ rtems_task Init(
   check_isr_worked( "inline", isr_in_progress_inline );
   check_isr_worked( "body", isr_in_progress_body );
+#endif
   TEST_END();
diff --git a/testsuites/sptests/sp40/init.c b/testsuites/sptests/sp40/init.c
index 5b0ad7d..d3b547b 100644
--- a/testsuites/sptests/sp40/init.c
+++ b/testsuites/sptests/sp40/init.c
@@ -42,16 +42,14 @@ static rtems_driver_address_table test_driver = {
 #define test_interrupt_context_enter( level ) \
   do { \
-    _Thread_Disable_dispatch(); \
-    rtems_interrupt_disable( level ); \
+    rtems_interrupt_local_disable( level ); \
     ++_ISR_Nest_level; \
   } while (0)
 #define test_interrupt_context_leave( level ) \
   do { \
     --_ISR_Nest_level; \
-    rtems_interrupt_enable( level ); \
-    _Thread_Enable_dispatch(); \
+    rtems_interrupt_local_enable( level ); \
   } while (0)
 rtems_task Init(
diff --git a/testsuites/tmtests/tm26/task1.c b/testsuites/tmtests/tm26/task1.c
index ee66218..5b19c3d 100644
--- a/testsuites/tmtests/tm26/task1.c
+++ b/testsuites/tmtests/tm26/task1.c
@@ -341,15 +341,20 @@ rtems_task High_task(
   benchmark_timer_initialize();
   isr_disable_time = benchmark_timer_read();
+#if defined(RTEMS_SMP)
+#else
+#endif
   isr_flash_time = benchmark_timer_read();
   isr_enable_time = benchmark_timer_read();
1.8.1.4
