[PATCH] GSoC: Cache configurations Raspberry Pi 2 support
Rohini Kulkarni
krohini1593 at gmail.com
Mon Jun 22 20:59:50 UTC 2015
.../arm/raspberrypi/startup/mm_config_table.c | 18 +++++++--------
c/src/lib/libbsp/arm/shared/mminit.c | 23
2 files changed, 32 insertions(+), 9 deletions(-)
diff --git a/c/src/lib/libbsp/arm/raspberrypi/startup/mm_config_table.c
b/c/src/lib/libbsp/arm/raspberrypi/startup/mm_config_table.c
index 8a6d37a..dd1941e 100644
--- a/c/src/lib/libbsp/arm/raspberrypi/startup/mm_config_table.c
+++ b/c/src/lib/libbsp/arm/raspberrypi/startup/mm_config_table.c
@@ -31,39 +31,39 @@ const arm_cp15_start_section_config
arm_cp15_start_mmu_config_table[] = {
.begin = (uint32_t) bsp_section_fast_data_begin,
.end = (uint32_t) bsp_section_fast_data_end,
- .flags = ARMV7_MMU_DATA_READ_WRITE_CACHED
+ .flags = ARMV7_MMU_DATA_READ_WRITE_CACHED
.begin = (uint32_t) bsp_section_start_begin,
.end = (uint32_t) bsp_section_start_end,
- .flags = ARMV7_MMU_CODE_CACHED
+ .flags = ARMV7_MMU_CODE_CACHED
.begin = (uint32_t) bsp_section_vector_begin,
.end = (uint32_t) bsp_section_vector_end,
.begin = (uint32_t) bsp_section_text_begin,
.end = (uint32_t) bsp_section_text_end,
- .flags = ARMV7_MMU_READ_WRITE
+ .flags = ARMV7_MMU_READ_WRITE | ARM_MMU_SECT_C | ARM_MMU_SECT_B
.begin = (uint32_t) bsp_section_rodata_begin,
.end = (uint32_t) bsp_section_rodata_end,
- .flags = ARMV7_MMU_DATA_READ_ONLY_CACHED
+ .flags = ARMV7_MMU_DATA_READ_ONLY_CACHED
.begin = (uint32_t) bsp_section_data_begin,
.end = (uint32_t) bsp_section_data_end,
.begin = (uint32_t) bsp_section_bss_begin,
.end = (uint32_t) bsp_section_bss_end,
.begin = (uint32_t) bsp_section_work_begin,
.end = (uint32_t) bsp_section_work_end,
.begin = (uint32_t) bsp_section_stack_begin,
.end = (uint32_t) bsp_section_stack_end,
.begin = RPI_PERIPHERAL_BASE,
.end = RPI_PERIPHERAL_BASE + RPI_PERIPHERAL_SIZE,
diff --git a/c/src/lib/libbsp/arm/shared/mminit.c
b/c/src/lib/libbsp/arm/shared/mminit.c
index acfbfc0..96ca1ec 100644
--- a/c/src/lib/libbsp/arm/shared/mminit.c
+++ b/c/src/lib/libbsp/arm/shared/mminit.c
@@ -13,6 +13,28 @@
#include <bsp/linker-symbols.h>
#include <bsp/mm.h>
+#if (BSP_IS_RPI2 == 1)
+BSP_START_TEXT_SECTION void bsp_memory_management_initialize(void)
+ /* Enable SMP in auxiliary control */
+ uint32_t actlr = arm_cp15_get_auxiliary_control();
+ actlr |= ARM_CORTEX_A9_ACTL_SMP;
+ arm_cp15_set_auxiliary_control(actlr);
+ uint32_t ctrl = arm_cp15_start_setup_mmu_and_cache(
+ ARM_CP15_CTRL_A,
+ ARM_CP15_CTRL_AFE| ARM_CP15_CTRL_Z
+ arm_cp15_start_setup_translation_table_and_enable_mmu_and_cache(
+ ctrl,
+ (uint32_t *) bsp_translation_table_base,
+ ARM_MMU_DEFAULT_CLIENT_DOMAIN,
+ &arm_cp15_start_mmu_config_table[0],
+ arm_cp15_start_mmu_config_table_size
+#else
uint32_t ctrl = arm_cp15_get_control();
@@ -27,3 +49,4 @@ BSP_START_TEXT_SECTION void
+#endif
\ No newline at end of file
1.7.9.5
Rohini Kulkarni
URL: <http://lists.rtems.org/pipermail/devel/attachments/20150623/b0db404d/attachment.html>
