qemu invocation for pc386
Joel Sherrill
joel.sherrill at oarcorp.com
Mon Jun 22 23:58:23 UTC 2015
Hi
It looks like qemu has changed the command line related to
virtual fat directories.
Has anyone used it recently or have suggestions? I don't seem
to be able to parse the help offered and get it happy.
+ qemu-system-i386 -m 512 -boot a -cpu 486 -fda /home/joel/qemu/pc386_fda -drive file=fat:dir:rw:/home/joel/qemu/hd -monitor null -nographic -serial stdio --no-reboot
WARNING: Image format was not specified for '/home/joel/qemu/pc386_fda' and probing guessed raw.
Automatically detecting the format is dangerous for raw images, write operations on block 0 will be restricted.
Specify the 'raw' format explicitly to remove the restrictions.
vvfat /home/joel/qemu/hd chs 1024,16,63
WARNING: Image format was not specified for 'json:{"fat-type": 0, "dir": "/home/joel/qemu/hd", "driver": "vvfat", "floppy": false, "rw": true}' and probing guessed raw.
*** LIBBSD SLEEP 1 TEST ***
nexus0: <RTEMS Nexus device>
devctl: +nexus0 at on root0
devctl: !system=IFNET subsystem=lo0 type=ATTACH
test timeouts
slave[2]: 1
slave[1]: 2
slave[0]: 3
test wakeup without waiter
test wakeup one
assertion "slave_counters[2] == 4" failed: file "../../testsuite/sleep01/test_main.c", line 183, function: test_wakeup_one
EXECUTIVE SHUTDOWN! Any key to reboot...
