testing order for rtems-libbsd
Tue Jun 23 06:28:53 UTC 2015
On 23/06/2015 3:55 pm, Sebastian Huber wrote:
> On 23/06/15 01:56, Joel Sherrill wrote:
>> Hi
>> I have it built now for pc386 but some tests run and others don't.
>> Any suggestions on the order to run tests in from simplest to
>> most complex?
> The ones covered by a "make run_tests" should work (there is a known
> issue with selectpollkqueue01).
On the Zynq some test kill qemu then the init task is deleted. I have
not looked into this yet.
