[PATCH] GSoC: Cache configurations Raspberry Pi 2 support
Tue Jun 23 08:14:52 UTC 2015
Please avoid unnecessary white-space changes and white-space at the end
of line.
On 22/06/15 22:59, Rohini Kulkarni wrote:
>  .../arm/raspberrypi/startup/mm_config_table.c      |   18 +++++++--------
>  c/src/lib/libbsp/arm/shared/mminit.c               |   23
>  2 files changed, 32 insertions(+), 9 deletions(-)
> diff --git
> a/c/src/lib/libbsp/arm/raspberrypi/startup/mm_config_table.c
> b/c/src/lib/libbsp/arm/raspberrypi/startup/mm_config_table.c
> index 8a6d37a..dd1941e 100644
> --- a/c/src/lib/libbsp/arm/raspberrypi/startup/mm_config_table.c
> +++ b/c/src/lib/libbsp/arm/raspberrypi/startup/mm_config_table.c
> @@ -31,39 +31,39 @@ const arm_cp15_start_section_config
> arm_cp15_start_mmu_config_table[] = {
>      .begin = (uint32_t) bsp_section_fast_data_begin,
>      .end = (uint32_t) bsp_section_fast_data_end,
> -    .flags = ARMV7_MMU_DATA_READ_WRITE_CACHED
> +    .flags = ARMV7_MMU_DATA_READ_WRITE_CACHED
>      .begin = (uint32_t) bsp_section_start_begin,
>      .end = (uint32_t) bsp_section_start_end,
> -    .flags = ARMV7_MMU_CODE_CACHED
> +    .flags = ARMV7_MMU_CODE_CACHED
>      .begin = (uint32_t) bsp_section_vector_begin,
>      .end = (uint32_t) bsp_section_vector_end,
>      .begin = (uint32_t) bsp_section_text_begin,
>      .end = (uint32_t) bsp_section_text_end,
> -    .flags = ARMV7_MMU_READ_WRITE
> +    .flags = ARMV7_MMU_READ_WRITE | ARM_MMU_SECT_C | ARM_MMU_SECT_B
Why is this not ARMV7_MMU_CODE_CACHED?  Why can't this BSP use
ARMV7_CP15_START_DEFAULT_SECTIONS?
>      .begin = (uint32_t) bsp_section_rodata_begin,
>      .end = (uint32_t) bsp_section_rodata_end,
> -    .flags = ARMV7_MMU_DATA_READ_ONLY_CACHED
> +    .flags = ARMV7_MMU_DATA_READ_ONLY_CACHED
>      .begin = (uint32_t) bsp_section_data_begin,
>      .end = (uint32_t) bsp_section_data_end,
>      .begin = (uint32_t) bsp_section_bss_begin,
>      .end = (uint32_t) bsp_section_bss_end,
>      .begin = (uint32_t) bsp_section_work_begin,
>      .end = (uint32_t) bsp_section_work_end,
>      .begin = (uint32_t) bsp_section_stack_begin,
>      .end = (uint32_t) bsp_section_stack_end,
>      .begin = RPI_PERIPHERAL_BASE,
>      .end =   RPI_PERIPHERAL_BASE + RPI_PERIPHERAL_SIZE,
> diff --git a/c/src/lib/libbsp/arm/shared/mminit.c
> b/c/src/lib/libbsp/arm/shared/mminit.c
> index acfbfc0..96ca1ec 100644
> --- a/c/src/lib/libbsp/arm/shared/mminit.c
> +++ b/c/src/lib/libbsp/arm/shared/mminit.c
> @@ -13,6 +13,28 @@
>  #include <bsp/linker-symbols.h>
>  #include <bsp/mm.h>
> +#if (BSP_IS_RPI2 == 1)
Such a construct in a shared folder makes no sense.
> +BSP_START_TEXT_SECTION void bsp_memory_management_initialize(void)
> +  /* Enable SMP in auxiliary control */
> +  uint32_t actlr = arm_cp15_get_auxiliary_control();
> +  actlr |= ARM_CORTEX_A9_ACTL_SMP;
> +  arm_cp15_set_auxiliary_control(actlr);
> +  uint32_t ctrl = arm_cp15_start_setup_mmu_and_cache(
> +    ARM_CP15_CTRL_A,
> +    ARM_CP15_CTRL_AFE| ARM_CP15_CTRL_Z
> + arm_cp15_start_setup_translation_table_and_enable_mmu_and_cache(
> +    ctrl,
> +    (uint32_t *) bsp_translation_table_base,
> +    ARM_MMU_DEFAULT_CLIENT_DOMAIN,
> +    &arm_cp15_start_mmu_config_table[0],
> +    arm_cp15_start_mmu_config_table_size
> +#else
>    uint32_t ctrl = arm_cp15_get_control();
> @@ -27,3 +49,4 @@ BSP_START_TEXT_SECTION void
> +#endif
> \ No newline at end of file
> 1.7.9.5
> Rohini Kulkarni
> devel mailing list
> devel at rtems.org
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
