[PATCH] GSoC: Cache configurations Raspberry Pi 2 support
Rohini Kulkarni
krohini1593 at gmail.com
Tue Jun 23 10:57:10 UTC 2015
On Tue, Jun 23, 2015 at 1:44 PM, Sebastian Huber <
> Please avoid unnecessary white-space changes and white-space at the end of
> line.
> Something went wrong with the whitespace. I couldn't see that change in my
code. I'll rectify it.
> On 22/06/15 22:59, Rohini Kulkarni wrote:
>> .../arm/raspberrypi/startup/mm_config_table.c | 18 +++++++--------
>> c/src/lib/libbsp/arm/shared/mminit.c | 23
>> 2 files changed, 32 insertions(+), 9 deletions(-)
>> diff --git a/c/src/lib/libbsp/arm/raspberrypi/startup/mm_config_table.c
>> b/c/src/lib/libbsp/arm/raspberrypi/startup/mm_config_table.c
>> index 8a6d37a..dd1941e 100644
>> --- a/c/src/lib/libbsp/arm/raspberrypi/startup/mm_config_table.c
>> +++ b/c/src/lib/libbsp/arm/raspberrypi/startup/mm_config_table.c
>> @@ -31,39 +31,39 @@ const arm_cp15_start_section_config
>> arm_cp15_start_mmu_config_table[] = {
>> .begin = (uint32_t) bsp_section_fast_data_begin,
>> .end = (uint32_t) bsp_section_fast_data_end,
>> - .flags = ARMV7_MMU_DATA_READ_WRITE_CACHED
>> + .flags = ARMV7_MMU_DATA_READ_WRITE_CACHED
>> .begin = (uint32_t) bsp_section_start_begin,
>> .end = (uint32_t) bsp_section_start_end,
>> - .flags = ARMV7_MMU_CODE_CACHED
>> + .flags = ARMV7_MMU_CODE_CACHED
>> .begin = (uint32_t) bsp_section_vector_begin,
>> .end = (uint32_t) bsp_section_vector_end,
>> .begin = (uint32_t) bsp_section_text_begin,
>> .end = (uint32_t) bsp_section_text_end,
>> - .flags = ARMV7_MMU_READ_WRITE
>> + .flags = ARMV7_MMU_READ_WRITE | ARM_MMU_SECT_C | ARM_MMU_SECT_B
> Why is this not ARMV7_MMU_CODE_CACHED? Why can't this BSP use
> ARMV7_CP15_START_DEFAULT_SECTIONS?
> One question that came up when I figured out last night that this was the
only required change. This was the only uncached normal memory section in
the table. So there were many changes I tried before I made this cacheable.
Why was it not made cacheable (MMU_CODE_CACHED is read only. But then yes,
why is this made read write, differently from
ARMV7_CP15_START_DEFAULT_SECTIONS)
The TEX bits 2 and 1 have been assigned the value for cacheable memory but
are used in the defines for CACHED sections.
>> .begin = (uint32_t) bsp_section_rodata_begin,
>> .end = (uint32_t) bsp_section_rodata_end,
>> - .flags = ARMV7_MMU_DATA_READ_ONLY_CACHED
>> + .flags = ARMV7_MMU_DATA_READ_ONLY_CACHED
>> .begin = (uint32_t) bsp_section_data_begin,
>> .end = (uint32_t) bsp_section_data_end,
>> .begin = (uint32_t) bsp_section_bss_begin,
>> .end = (uint32_t) bsp_section_bss_end,
>> .begin = (uint32_t) bsp_section_work_begin,
>> .end = (uint32_t) bsp_section_work_end,
>> .begin = (uint32_t) bsp_section_stack_begin,
>> .end = (uint32_t) bsp_section_stack_end,
>> .begin = RPI_PERIPHERAL_BASE,
>> .end = RPI_PERIPHERAL_BASE + RPI_PERIPHERAL_SIZE,
>> diff --git a/c/src/lib/libbsp/arm/shared/mminit.c
>> b/c/src/lib/libbsp/arm/shared/mminit.c
>> index acfbfc0..96ca1ec 100644
>> --- a/c/src/lib/libbsp/arm/shared/mminit.c
>> +++ b/c/src/lib/libbsp/arm/shared/mminit.c
>> @@ -13,6 +13,28 @@
>> #include <bsp/linker-symbols.h>
>> #include <bsp/mm.h>
>> +#if (BSP_IS_RPI2 == 1)
> Such a construct in a shared folder makes no sense.
Thats right. Will change the integration for the two memory initializations
> +BSP_START_TEXT_SECTION void bsp_memory_management_initialize(void)
>> + /* Enable SMP in auxiliary control */
>> + uint32_t actlr = arm_cp15_get_auxiliary_control();
>> + actlr |= ARM_CORTEX_A9_ACTL_SMP;
>> + arm_cp15_set_auxiliary_control(actlr);
>> + uint32_t ctrl = arm_cp15_start_setup_mmu_and_cache(
>> + ARM_CP15_CTRL_A,
>> + ARM_CP15_CTRL_AFE| ARM_CP15_CTRL_Z
>> + arm_cp15_start_setup_translation_table_and_enable_mmu_and_cache(
>> + ctrl,
>> + (uint32_t *) bsp_translation_table_base,
>> + ARM_MMU_DEFAULT_CLIENT_DOMAIN,
>> + &arm_cp15_start_mmu_config_table[0],
>> + arm_cp15_start_mmu_config_table_size
>> +#else
>> uint32_t ctrl = arm_cp15_get_control();
>> @@ -27,3 +49,4 @@ BSP_START_TEXT_SECTION void
>> +#endif
>> \ No newline at end of file
>> 1.7.9.5
>> Rohini Kulkarni
>> devel mailing list
>> devel at rtems.org
> Phone : +49 89 189 47 41-16
> Fax : +49 89 189 47 41-09
Rohini Kulkarni
URL: <http://lists.rtems.org/pipermail/devel/attachments/20150623/c4071a2d/attachment-0001.html>
