testing order for rtems-libbsd
Tue Jun 23 15:50:56 UTC 2015
On 6/23/2015 2:19 AM, Sebastian Huber wrote:
> On 23/06/15 08:28, Chris Johns wrote:
>> On 23/06/2015 3:55 pm, Sebastian Huber wrote:
>>> On 23/06/15 01:56, Joel Sherrill wrote:
>>>> Hi
>>>> I have it built now for pc386 but some tests run and others don't.
>>>> Any suggestions on the order to run tests in from simplest to
>>>> most complex?
>>> The ones covered by a "make run_tests" should work (there is a known
>>> issue with selectpollkqueue01).
make run_tests assumes you built with the Makefile which doesn't work
now. How are you building?
The waf tests end up with slightly different names in a different location.
So running them is different.
For now, I am just hacking the run_tests command and making it work
with waf build output.
>> On the Zynq some test kill qemu then the init task is deleted. I have
>> not looked into this yet.
> I fixed this problem.
> It would be nice to have some target to run the standard tests and check
> the END OF message (no network environment, finite test run-time with
> END OF message).
