libbsd Makefile issues
Tue Jun 23 18:18:05 UTC 2015
On 6/23/2015 1:09 PM, Gene Smith wrote:
> On 06/23/2015 11:28 AM, Joel Sherrill wrote:
>> Hi
>> I decided to take a look at this and spotted what I think are at least
>> two mistakes but when I fixed them, I got a build error.
>> Help appreciated:
>> Makefile.diff attached. But it then fails like this:
>> $ make
>> i386-rtems4.11-gcc --pipe
>> -B/home/joel/rtems-4.11-work/bsp-install/i386-rtems4.11/pc386/lib/
>> -specs bsp_specs -qrtems     -mtune=i386      -Wall  -O2 -g
>> -fno-strict-aliasing -ffreestanding -fno-common -Irtemsbsd/include
>> -Irtemsbsd/i386/include -Ifreebsd/sys -Ifreebsd/sys/i386/include
>> -Ifreebsd/sys/contrib/altq -Ifreebsd/sys/contrib/pf -Ifreebsd/include
>> -Ifreebsd/lib/libc/include -Ifreebsd/lib/libc/isc/include
>> -Ifreebsd/lib/libc/resolv -Ifreebsd/lib/libutil -Ifreebsd/lib/libkvm
>> -Ifreebsd/lib/libmemstat -Ifreebsd/lib/libipsec -Irtemsbsd/sys
>> -ImDNSResponder/mDNSCore -ImDNSResponder/mDNSShared
>> -ImDNSResponder/mDNSPosix -Itestsuite/include -DHAVE_RTEMS_PCI_H=1 -Wall
>> -Wno-format -MT freebsd/contrib/libpcap/scanner.o -MD -MP -MF
>> freebsd/contrib/libpcap/scanner.d -std=gnu11 -D__FreeBSD__=1 -DBSD=1
>> -DINET6 -D_U_="__attribute__((unused))" -DHAVE_LIMITS_H=1
>> -DHAVE_INTTYPES=1 -DHAVE_STDINT=1 -DHAVE_STRERROR=1 -DHAVE_STRLCPY=1
>> -DHAVE_SNPRINTF=1 -DHAVE_VSNPRINTF=1 -DHAVE_SOCKADDR_SA_LEN=1 -DHAVE
>> _NET_IF_MEDIA_H=1 -DHAVE_SYS_IOCCOM_H=1 -DNEED_YYPARSE_WRAPPER=1
>> -Dyylval=pcap_lval -c freebsd/contrib/libpcap/scanner.c -o
>> In file included from ../../freebsd/contrib/libpcap/scanner.l:51:0:
>> freebsd/contrib/libpcap/pcap-int.h:39:23: fatal error: pcap/pcap.h: No
>> such file or directory
>>    #include <pcap/pcap.h>
> Here's the things I did to fix the Makefile. I think you added the
> quotes (item 1) and maybe item 2. I think the error you are seeing is
> due to item 3 since it can't find pcap.h.
> 1) Everywhere the string "-D_U_=__attribute__((unused))" appears in the
> rules it needs to be quoted. It appears in almost every rule so there
> are maybe 100s of them. (I used single quotes, FWIW.)
> 2) Everywhere sting "freebsd/usr.sbin/tcpdump/tcpdump-D__FreeBSD__=1"
> appears it needs have a space inserted:
> "freebsd/usr.sbin/tcpdump/tcpdump -D__FreeBSD__=1"
> Quotes aren't required. Again, there a many of these.
> 3) Several include paths need to be added:
> COMMON_FLAGS += -Ifreebsd/contrib/libpcap
> COMMON_FLAGS += -Irtemsbsd/sys
> COMMON_FLAGS += -Ifreebsd/usr.sbin/tcpdump/tcpdump
> COMMON_FLAGS += -Ifreebsd/contrib/tcpdump
> COMMON_FLAGS += -Ibuild/arm-rtems4.11-realview_pbx_a9_qemu/testsuite/include
> (The last one contains the bsp name so probably needs to be more
> general, but seems to work ok as an ad hoc fix.)
I could repeat those steps but if you have a patch, I am
happy to push it.
Please.. patch. :)
Is it working for you on some target?
> devel mailing list
> devel at rtems.org
