Sendfile for Rtems
Sujay Raj
sujayraaj at gmail.com
Tue Jun 23 19:13:19 UTC 2015
I agree with Sebastian.
Using read write in a loop can only serve as a makeshift measure.
If we have consensus here, then I can work on getting sendfile backed up in
libbsd. (though, I have some serious background reading to do before I am
able to do it, but I think I can. )
Thanks and Regards,
Sujay Raj
On Wed, Jun 24, 2015 at 12:21 AM, Sebastian Huber <
> I would use the sendfile system call implementation from FreeBSD and add
> it to the libbsd. Its not a big win if you use read() and write() to
> implement sendfile(). This makes only sense if you can use kernel space
> zero-copy buffers.
> ----- Eduardo Silva <eduardo at monkey.io> schrieb:
> Sujay,
> Monkey use conditionals for each implementation: Linux, FreeBSD and OSX.
> My suggestion is that RTEMS may implement a sendfile based on FreeBSD
> format which can easily be emulated as a read() and further write() for
> socket operations. That will help not only Monkey, but also other software
> that requires such interface.
> I am not the best one to talk about RTEMS, but the Kernel always knows
> better it buffers capacity that the program on the other side.
> do you think is possible to do that on RTEMS ?
> regards,
> On Tue, Jun 23, 2015 at 12:05 PM, Joel Sherrill <joel.sherrill at oarcorp.com
> > wrote:
>> > On 6/23/2015 12:49 PM, Sujay Raj wrote:
>>> > I am working on porting Monkey HTTP server on rtems.
>>> > Sendfile is not specified in POSIX.1-2001 or other standards and its
>>> implementations vary depending on the unix/linux system being used.
>>> > Freebsd has sendfile in its libc.
>> > FreeBSD has a completely different API for sendfile(). Plus the source
>> > must be a regular file and the destination a socket.
>> >https://www.freebsd.org/cgi/man.cgi?query=sendfile&sektion=2
>> > This is a random discussion of sendfile() on various OSes. It mentions
>> > the assumption that the source must normally be able to be mmap'ed.
>> > Since you can't do that on RTEMS, you are stuck with a loop
>> > implementation. [1]
>> >https://groups.google.com/forum/#!topic/comp.unix.programmer/65oDSzpEzx8
>>> > So I opened this thread to discuss how should we proceed with this
>>> matter, if we should work on getting sendfile in newlib, or if there is any
>>> portable solution that we can use in its place.
>> > Given that (a) it is not POSIX and (b) there is no agreement between
>> > Linux and FreeBSD, it is highly unlikely newlib would accept an
>> > implementation.
>> > Given (b), I don't personally see merging it into RTEMS since we
>> > have to pick a winner and loser on the API.
>> > What's the feeling on having a default implementation in Monkey and
>> > using that as a backup? With [1] as a consideration again.
>> > [1] The size of the buffer user for read/write has to be accounted
>> > for. If this is on a thread stack, then it can't be too large or that
>> > imposes a burden on calling sendfile(). I can see an implementation
>> > doing a malloc() of the buffer and then free()'ing it.
>>> > cc to Joel and Eduardo.
>>> > Thanks and Regards,
>>> > Sujay Raj
>> > Joel Sherrill, Ph.D. Director of Research & Development
>> > joel.sherrill at OARcorp.com On-Line Applications Research
>> > Ask me about RTEMS: a free RTOS Huntsville AL 35805
>> > Support Available (256) 722-9985
> Eduardo Silva
> Monkey Software
> Phone : +49 89 189 47 41-16
> Fax : +49 89 189 47 41-09
> E-Mail : sebastian.huber at embedded-brains.de <http://lists.rtems.org/mailman/listinfo/devel>
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20150624/7e949826/attachment.html>
