Sendfile for Rtems
Gedare Bloom gedare at gwu.edu
Tue Jun 23 19:15:09 UTC 2015
On Tue, Jun 23, 2015 at 3:13 PM, Sujay Raj <sujayraaj at gmail.com> wrote:
> I agree with Sebastian.
> Using read write in a loop can only serve as a makeshift measure.
> If we have consensus here, then I can work on getting sendfile backed up in
> libbsd. (though, I have some serious background reading to do before I am
> able to do it, but I think I can. )
Yes this makes the most sense.
> Thanks and Regards,
> Sujay Raj
> On Wed, Jun 24, 2015 at 12:21 AM, Sebastian Huber
> <sebastian.huber at embedded-brains.de> wrote:
>> I would use the sendfile system call implementation from FreeBSD and add
>> it to the libbsd. Its not a big win if you use read() and write() to
>> implement sendfile().  This makes only sense if you can use kernel space
>> zero-copy buffers.
>> ----- Eduardo Silva <eduardo at monkey.io> schrieb:
>> Sujay,
>> Monkey use conditionals for each implementation: Linux, FreeBSD and OSX.
>> My suggestion is that RTEMS may implement a sendfile based on FreeBSD format
>> which can easily be emulated as a read() and further write() for socket
>> operations. That will help not only Monkey, but also other software that
>> requires such interface.
>> I am not the best one to talk about RTEMS, but the Kernel always knows
>> better it buffers capacity that the program on the other side.
>> do you think is possible to do that on RTEMS ?
>> regards,
>> On Tue, Jun 23, 2015 at 12:05 PM, Joel Sherrill
>> <joel.sherrill at oarcorp.com> wrote:
>>> > On 6/23/2015 12:49 PM, Sujay Raj wrote:
>>>> > I am working on porting Monkey HTTP server on rtems.
>>>> > Sendfile is not specified in POSIX.1-2001 or other standards and its
>>>> > implementations vary depending on the unix/linux system being used.
>>>> > Freebsd has sendfile in its libc.
>>> > FreeBSD has a completely different API for sendfile(). Plus the source
>>> > must be a regular file and the destination a socket.
>>> >https://www.freebsd.org/cgi/man.cgi?query=sendfile&sektion=2
>>> > This is a random discussion of sendfile() on various OSes. It mentions
>>> > the assumption that the source must normally be able to be mmap'ed.
>>> > Since you can't do that on RTEMS, you are stuck with a loop
>>> > implementation. [1]
>>> >https://groups.google.com/forum/#!topic/comp.unix.programmer/65oDSzpEzx8
>>>> > So I opened this thread to discuss how should we proceed with this
>>>> > matter, if we should work on getting sendfile in newlib, or if there is any
>>>> > portable solution that we can use in its place.
>>> > Given that (a) it is not POSIX and (b) there is no agreement between
>>> > Linux and FreeBSD, it is highly unlikely newlib would accept an
>>> > implementation.
>>> > Given (b), I don't personally see merging it into RTEMS since we
>>> > have to pick a winner and loser on the API.
>>> > What's the feeling on having a default implementation in Monkey and
>>> > using that as a backup? With [1] as a consideration again.
>>> > [1] The size of the buffer user for read/write has to be accounted
>>> > for. If this is on a thread stack, then it can't be too large or that
>>> > imposes a burden on calling sendfile(). I can see an implementation
>>> > doing a malloc() of the buffer and then free()'ing it.
>>>> > cc to Joel and Eduardo.
>>>> > Thanks and Regards,
>>>> > Sujay Raj
>>> > Joel Sherrill, Ph.D.             Director of Research & Development
>>> > joel.sherrill at OARcorp.com        On-Line Applications Research
>>> > Ask me about RTEMS: a free RTOS  Huntsville AL 35805
>>> > Support Available                (256) 722-9985
>> Eduardo Silva
>> Monkey Software
>> Sebastian Huber, embedded brains GmbH
>> Address : Dornierstr. 4, D-82178 Puchheim, Germany
>> Phone   : +49 89 189 47 41-16
>> Fax     : +49 89 189 47 41-09
>> E-Mail  : sebastian.huber at embedded-brains.de
>> PGP     : Public key available on request.
>> Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
>> devel mailing list
>> devel at rtems.org
> devel mailing list
> devel at rtems.org
