[PATCH] modified: waf_generator.py Fix incorrect encoding of NET_CFG_GATEWAY_IP and change _IP_IP ending to _IP. Remove _IP_IP ending from NET_TAP_INTERFACE.
Gene Smith gds at chartertn.net
Wed Jun 24 05:04:51 UTC 2015
modified:   wscript
Re-generated from "./freebsd-to-rtems -m" based on
waf_generator.py
 waf_generator.py | 6 +++---
 wscript          | 6 +++---
 2 files changed, 6 insertions(+), 6 deletions(-)
diff --git a/waf_generator.py b/waf_generator.py
index 0be3367..ff55031 100755
--- a/waf_generator.py
+++ b/waf_generator.py
@@ -367,9 +367,9 @@ class ModuleManager(builder.ModuleManager):
         self.add('                net_cfg_netmask = rhs')
         self.add('            if lhs == "NET_CFG_PEER_IP":')
         self.add('                net_cfg_peer_ip = rhs')
-        self.add('            if lhs == "NET_CFG_GATEWAY_IP_IP":')
+        self.add('            if lhs == "NET_CFG_GATEWAY_IP":')
         self.add('                net_cfg_gateway_ip = rhs')
-        self.add('            if lhs == "NET_TAP_INTERFACE_IP_IP":')
+        self.add('            if lhs == "NET_TAP_INTERFACE":')
         self.add('                net_tap_interface = rhs')
         self.add('    bld(target = "testsuite/include/rtems/bsd/test/network-config.h",')
         self.add('        source = "testsuite/include/rtems/bsd/test/network-config.h.in",')
@@ -377,7 +377,7 @@ class ModuleManager(builder.ModuleManager):
                  '-e \'s/@NET_CFG_NETMASK@/%s/\' ' + \
                  '-e \'s/@NET_CFG_PEER_IP@/%s/\' ' + \
                  '-e \'s/@NET_CFG_GATEWAY_IP@/%s/\' < ${SRC} > ${TGT}" % ' + \
-                 '(net_cfg_self_ip, net_cfg_netmask, net_cfg_peer_ip, net_cfg_netmask),')
+                 '(net_cfg_self_ip, net_cfg_netmask, net_cfg_peer_ip, net_cfg_gateway_ip),')
         self.add('        update_outputs = True)')
         self.add('')
diff --git a/wscript b/wscript
index 8c653a4..86d3ccf 100644
--- a/wscript
+++ b/wscript
@@ -128,13 +128,13 @@ def build(bld):
-            if lhs == "NET_CFG_GATEWAY_IP_IP":
+            if lhs == "NET_CFG_GATEWAY_IP":
-            if lhs == "NET_TAP_INTERFACE_IP_IP":
+            if lhs == "NET_TAP_INTERFACE":
-        rule = "sed -e 's/@NET_CFG_SELF_IP@/%s/' -e 's/@NET_CFG_NETMASK@/%s/' -e 's/@NET_CFG_PEER_IP@/%s/' -e 's/@NET_CFG_GATEWAY_IP@/%s/' < ${SRC} > ${TGT}" % (net_cfg_self_ip, net_cfg_netmask, net_cfg_peer_ip, net_cfg_netmask),
+        rule = "sed -e 's/@NET_CFG_SELF_IP@/%s/' -e 's/@NET_CFG_NETMASK@/%s/' -e 's/@NET_CFG_PEER_IP@/%s/' -e 's/@NET_CFG_GATEWAY_IP@/%s/' < ${SRC} > ${TGT}" % (net_cfg_self_ip, net_cfg_netmask, net_cfg_peer_ip, net_cfg_gateway_ip),
     # KVM Symbols
2.1.0
